Question about Honeywell Heating & Cooling
I HAVE A HONEYWELL TH2110D1009 AND I DONT KNOW HOW TO SET THE HEAT AND WE ARE FREEZING.
  • 85 Answers
Ensure fan is on auto, switch is on heat, then press to desired temp, then press hold. This manually hold that temp, you have to follow directions on operation manual to set program. Do you have a manual?
Posted on Dec 02, 2008
I have the Honeywell ct31 replacing my lux 500. I have no ac. when fan is on auto there is a 3-5 minute lag between it and heat in both starting and stopping the burner. is that planned or is somet
Why would you want to set the thermostat below 40? They do that so people won't freeze pipes keep in mind if it's 40 upstairsit's probably near freezing in your basement if applies. Did you label the wires from your old Tstat or take pictures? You can't always go off colors. If this is a heat pump you may need a pro or you'll end up causing damage that may get expensive vs trying to save and doing it yourself.
Nov 12, 2014 | Honeywell Ct31a Heating & Cooling House...
Have a honeywell thermo 7 day .how to change for centerage to farenheight
1. Turn system off.
2. Simultaneously press up & down arrows for 3 seconds.
3. You will then see a display with a large number to the left and a small number to the right.
4. You should then see a large #1 and a small #1.
5. You want to change that 1(Celsius) to a 0(Fahrenheit).
6. Do that by pressing up or down arrow.
7. Once you've changed that small 1 to a 0 you then press both the up and down buttons for 1 second about three more times to take thermostat back to original screen.
8. Now you should see your room temperature reading in Fahrenheit.
Nov 02, 2014 | Honeywell TH2110D1009 PRO 2000...
Does thermostat have to be on Auto or On to make my heat come on?? Dont know if i have thermostat problem or Furnace problem. Furnace clix on whenever it wants to, doesnt use the schedule i have...
If the thermostat is wired correctly, and matched to the type of heat you have ie electric, heat pump, boiler, forced air, gas or oil, the heat should run in either Fan ON or AUTO. Maybe you can explain your system a little more in depth...furnace type, M#, & thermostat brand w/ M#.
Dec 12, 2013 | Honeywell Programmable Thermostat Heater
I installed a honeywell CT87N thermostat. The
the burners light? if the burners dont light than it's working right the blower on the furnace comes on with the a\c
Jun 19, 2010 | Honeywell Electronic Programmable...
Lost program instructions freezing
Hi, on a programmable stat, you should be able to raise the temp with the arrow and then push hold temp. feature. This will hold the desired temp and get you heat unless you have a stat problem. Try this and let me know the settings.If this didn't work, make sure the stat is in the auto-heat posistion. Push program and set the time.press again and set the day of week. Repeat this step and set the desired temp for each day of the week and week-end and push run program.You should hear it click on. It takes a min. or so on heat as there is a delay. Make sure the batteries are strong as they run the program. Let me no. Best of Luck, Sincerely, Shastalaker7
Dec 04, 2009 | Honeywell Programmable Thermostat Heater
User manual for Honeywell ST6400C
Honeywell ST6400C
Times set on thermostat does not turn on or off the heating or hot water at the set times, but any time of the day
Sep 17, 2009 | Honeywell Electronic Programmable...
Honeywell thermostat
Go to www.honeywell.com and search their data base for your model of thermostat. You wil need all the numbers of your thermostat to be able to search. Once you find it, download the installation manual.
Good Luck.
Dec 03, 2007 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
330 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
