Sharp AR-5320 Black and White Copier
Problem for Sharp AR-5320 Black and White Copier
SHARP 5320 INK CARTRIDGE
By dawn_granber on Dec 01, 2008
We have 2 ink cartridges that supposily fit into this copier, but they do not fit properly. We do not have a number for the cartridge that is in there now and we are running out of ink. How do I get the proper cartridge for this copier.
Solution #1
posted on Dec 01, 2008
Not Rated)
t13ebb
Rank: Master
Rating: 86%, 42 votes
Depends where you are in the world, it would seem that if you are in Austailia or New Zealand it takes an AR202lt, anywhere else it takes an AR016lt, hope this helps
Was this helpful?
Yes
No
Popular Solutions for Sharp AR-5320 Black and White
Questions and Unsolved Problems for Sharp AR-5320 Black and White
Do you recommend Sharp AR-5320 Black and White Copier?
Answer
Answer
dark copies, copier pc-6re needs cleaning, no manual
Answer
sharp arm350-450 the imagistics versions adjusting of the printer void area lead & trail edge... (More)
Answer
SIr, I have the SHARP AR 5320E photocopier. How can i set the password to avoid the unauthorised... (More)
Answer
powersuply sharp ar-5320 14c471
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sharp AR-5320 Black and White...:
Top Copier Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
