Question about 3Com Wireless LAN Access Point 7250 802.11g/b (3crwe725075a-uk)
Frequent wireless disconnections 802.1X WPA TKIP
We have implemented 3com wireless access points in our network using 802.1X WPA TKIP settings. Windows IAS server is providing the authentication service for the wireless stations; the IAS server is integrated with windows active directory. Furthermore, the wireless stations get the IP from a centralized DHCP server. So far all is working fine. The problem is that Sometimes the wireless stations get authenticated and got the IP from the DHCP server but again disconnected and then start the process again and again. Sometimes the user is successfully authenticated and got the IP but when it disconnect from the wireless it fails to connect again We have setup the access points at different locations in a city. A user successfully authenticated in one location failed to get connected when roam to a different location. Note that all the IAS DHCP and Windows active directory are centralized. Furthermore we the wireless users have verity of laptops like DELL, IBM, Toshiba, HP. Kindly advise.
  • 21 Answers
Try using predefined IP addresses. Let each pc make it's own IP address and see if the conflicts continue, if they do, post again. :)
Posted on Feb 11, 2007
I want to know how i can make my Linksys Router WRT160N work as access point
By default Linksys router behaves as Access point. On some router you have to enable the wireless function.
So the following to configure the router Wireless Access Point
Click the below link
http://192.168.1.1
Now it will ask for username and password
Enter username = ( blank) and password = admin
If you can't login using this credentials then you will have to reset the router
If you logged in . Then click on Wireless > Wireless security
On this screen select
Security Mode : WPA Personal
WPA Algorithm : TKIP
WPA shard Key : "enter a password here"
Group Key Renewal : set to default
Click on save settings. After that restart router .
Now your wireless network is secured and you will have to type the WPA shared key inorder to connect to router when it prompts. You can connect as many devices as you wish since it is a access point
Thanks
Vote me If it helps
Apr 26, 2011 | Linksys WRT160N Wireless Router
What's the difference between WEP and WPA? What should I pick?
WEP is a weak securtiy protocol that is outdated and can be easily broken
WPA is a newer security protocol that is much harder to break with AES encryption
WPA is always recommended mode for operation over WEP.
Use WPA2 which is latest version if it is supported by device.
Mar 12, 2011 | Belkin N1 Wireless-N Wireless Router
My Sony vaio has limited access to Internet but all my family's computers working are fine, help
Make sure your connecting to the right network and check if the security type (WEP,WPA,WPA-PSK) and Encryption type (TKIP,AES) setting were the same with the other computers, you can also check the setting on the router to make sure :)
Jul 18, 2010 | Sony VAIO (PCWA-A200)
What is a wpa key password
WPA is a type of security for a wirelss router to keep people out of the network without the key password. The password is used to log onto the router and allow the computer to communicate with the router and internet. The key is created using the wireless router settings menu and can be found on the same menu. If you do not know the key then you will need to hook the computer directly up to the router and use the router settings menu to find out what the key is.
Oct 06, 2009 | NetGear WGT624 Wireless Router
I have plugged in a wireless adapter for the 360 but...
A red steady light on the adapter means it is ready to be connected to a wireless network. If it fails to connect then the WPA key is not correct.
WPA automatically changes keys on a frequent basis for security purposes. So you need to take note of the SSID (wireless network name) and the Wireless security settings (WPA and passphrase) from the wireless access point/router.
Once you have the wireless network settings on the access-point/router, go to the System area to enter those settings.
If all settings are correct, exit the System area. Your console should now be connected to your wireless network.
Hope this helps! Good luck!
Oct 01, 2009 | Microsoft Wireless Network Adapter Xbox...
How do i set up a secure network
Hi! you can setup a secure wireless network by accessing the linksys setup page and go to wireless setting, it will ask u what kind of security settings, like, wep, wpa, wpa, use the wpa2 and tkip then set the password, change also the router username and password so that no one can access ur wireless router setup page, only u..
Aug 08, 2009 | Linksys Wireless-G WRT54G Router
Can't scan
To test the hardware, use the product to copy a document.
1.open the scanner lid.
2.put a document face down on the glass.
3.close the scanner lid.
4.press the copy button.
make sure that the product connects to the network
ethernet connection
1.Disconnect the network cable from the back of the product, and then wait a few seconds.
2.Reconnect the network cable to the back of the product.
3.Make sure the other end of the network cable connects securely to the router or switch
4.Make sure that the lights on the router or switch are on.
5.Continue to "Step three: Print a network configuration page and find the IP address."
wireless network
  1. Make sure that the router or access point is on.
  2. Position the router or access point closer to the product.
  3. On the product, press the setup button , and then select the network option.
  4. Select the wireless setup wizard option. The product searches for the router or access point.
  5. Select the 'enter the new network name'(SSID) option.
  6. Type the service set identifier (SSID) or the name for the wireless network, and then select 'done' . The product searches for the network.
  7. Select the relevant authentication protocol, also called the security mode. Supported protocols include WEP (64 bit and 128 bit) and WPA-PSK (WPA1 or WPA2, AES or TKIP). Networks that do not use an access point or a router, known as ad hoc networks, support WEP encryption only.
  8. If the network uses media access control (MAC) address filtering, make sure that you have the router or access point set to allow the MAC address for the HP product.
  9. Follow the instructions to configure the product for your method of network security:
  10. WPE: Log on to the router or access point from the computer, and then find the wired equivalent policy (WEP) key set within the router or access point. If you specify the WEP by using 10 or 26 hexadecimal characters, make sure that the characters are 0-9 and A-F. Use the on-screen keyboard on the control panel display to type the WEP key on the product.
  11. WPA: Log on to the router or access point from the computer, and then find the Wi-Fi Protected Access (WPA) passphrase set within the router or access point. Use the on-screen keyboard on the control panel display to type the correct WPA passphrase.
make sure that the product is connecting to the network, print a network configuration page from the product and find the IP address on the page.
1.On the product control panel, press the Setup button
2.Select Network , select Network Settings , and then select either Print Network Settings or Print Network Configuration Page . The network configuration page prints
3.Make a note of the IP address for the wired or wireless connection. The IP address should resemble the example: http://192.168.1.1
4.If the computer connects to the Internet using a wired connection, the IP address displays in the Wired section.
5.If the computer connects to the Internet using a wireless connection, the IP address displays in the Wireless section
Jul 21, 2009 | HP Officejet 4315 All-in-One Printer
Zebra QL 420+ wireless printer works only without cipher/TKIP
Hi
With Label Vista
  • Go to Printer Tab
  • Define the com Port settings (use serial or usb)
  • Go to Printer settings
in network tab :
  • Put your network configuration ( IP address or DHCP,submask, gateway; ESSID, port number .....)
In 802.1X WPA
  • Select WPA WPA2
  • Authentification PSK
  • Put the username and password in EAP section
Mar 16, 2009 | Zebra QL 420 Plus Thermal Label Printer
Security connectivity issues
is the PC connection you're able to maintain once upgraded to WPA a PC that is physically connected to the router? if so, that would make sense because WPA (and WEP for that matter) are only wireless security protocols and have no protections for hard-wired connections.
In order to convert your system to WPA security, you must first make sure all of your hardware is WPA compatible (that isWPA Drivers are available for it).
For your PC wireless connection, if you're running Windows XP you can go to the microsoft website and download the WPA client. It is available in the Microsoft Knowledge Base Article 815485. install the update and reboot. you will then be able to enable WPA security on your client.
Then you'll possibly need to update the drivers for your hardware for WPA support (router, wireless NIC, etc) if they did not already come enabled.
next you get to configure the router for WPA. you'll want to make sure you're set to WPA with preshared keys (no authentication server required), use TKIP as the algorhythm, and leave group key renewal at it's default value. and of course Select a key that is not likely to be guessed. write the key down as you'll need to configure your NIC using it.
to configure your NIC, once you're in the configuration menu select WPA-PSK for your authentication, TKIP for the encryption mode, in data encryption set it to TKIP, and in the network key put the key you selected earlier.
At this point you should be able to access your wireless router (or other access point). These instructions were kind of generic since i do not have the specific router you're using available to me, but the settings i discussed should be pretty universal when it comes to WPA security.
Jul 01, 2008 | D-Link DI 514 Wireless Router (DI-514)
Encryption on/off
First you must choose a common encryption strategy for your home network. (Yes I am assuming Home Network)
In most consumer routers you activate encryption on the wireless services of the router. After doing so you must also actiate encryption services on the wireless adapters that communicate with the wireless router. The names of the encryption services in the wireless router and wireless adapter are WPA and WEP. It is important to assure all wireless adapters to connect to the wireless router can handle the encryption chosen because the router will only perform one. There are options within each technique such as the number of bits of the keys -- the longer the better but only as long as the shortest device can support. WPA is preferable to WEP because it was designed to correct weaknesses in the WEP standard and implementation. However if there is even a single device to be connected that cannot do WPA you must do WEP or replace the device WPA in home systems often have a couple of other attribute being WPA-PSK and algorithm of TKIP -- which again every wireless adapter and the wireless router/access point must support.
To procede further in a sane manner you need to identify all wireless devices that will participate in your wireless network and determine their capablities for encryption. This is generally done searching manufacturer websites under support looking for user guides and firmware updates. Sometimes a devices capabilities in the manual require firmware updates to be true for the device. Once that is figured out the standards for your network can be set and the actual implementation can proceed. You will probably want a working wired computer to maintain access to the outside world for assistance if anything goes wrong. You also want to track your changes and know how to back things out incase things become too difficult.
If you have any additional questions or would like to a review of your plan or assistance determining a plan gather up the appropriate manufacturer's names and models and I will assist as time permits.
I hope this helps.
Dec 16, 2007 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
3Com Wireless LAN Access Point 7250 802.11g/b (3crwe725075a-uk) Logo
259 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
Håkan Sterner
didi2005
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
