Question about Whirlpool 24 in. DU930PWP Built-in Dishwasher
My whirpool dishwasher model du930pwps2 stopped working
It stopped during the drain cycle. There is water at the bottom. It won't start, no lights at the controls, noises or movement...
dishes were fairly clean, so it must have happened towards the end of washing.
  • goflo5 Dec 06, 2008
    Hi- I opened up the control and i don't see a fuse. Any idea where to look? I am electronically challenged.
    Sergeant:
    Champion:
  • 338 Answers
Sounds like the fuse on the control blew. you can replace the fuse for around $20 or you can cut and splice the wires for free. If that doesnt work then you may have a loose conection in your junction box under the dishwasher.
Posted on Dec 01, 2008
  • Robert Artiaco Dec 07, 2008
    yes on the side of the control board there would be a plastic clip either white or grey. if it is white then it has 2 wires plugged into it and you would test that.
    if it is grey then you have the little round thermostat that is attached with usually tan or brown wires.
    let me know if this helps
Whirpool built-in puddle of water in bottom, food on drain
see this causes and proceed according. God bless you
Belt, Water Pump Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Drain Pump If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable Pump and Motor Assembly If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Check Valve If the dishwasher won't drain the check valve might be stuck closed. The check valve is a small plastic device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is the device that the drain hose is attached to on the dishwasher.
Check Ball If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Oct 16, 2012 | Whirlpool Dishwashers
For Miele Dishwasher G2470SCVI Need help with remaining water in the bottom. Model# G2470 SCV1 SF Type-HG03. Runs through the entire cycle,long,short ect..everything is clean and dishes look great but
see this causes and fix it. God bless you
Drain Valve The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Drain Hose If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Sep 28, 2012 | Dishwashers
Dishwasher won't drain.Leaves several inches of water in bottom of unit after cycle is complete
Check for blockages in the base of the dishwasher under filter etc.
Also make sure the kitchen drain is clear and if you have garbage disposer run it prior to running the dishwasher.
Also need to confirm if the dishwasher pump is actually operating during the drain cycle. If the pump is faulty then it will not drain. Provide full model number of dishwasher if you need further assessment of the problem. Good luck.
Aug 30, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Feb 13, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Not all of the soap dissolving, some left in dispenser and bottom
Kitchenaid lists 130 dishwashers with this model. Need the rest of the number
KUDSO1DLxxxx
Back in the day, when I worked on K Dishwashers, the drain valve was the problem typically.
It would get a piece of glass, from broken glass or other item, or a toothpick, whatever stuck in the drain valve. It would not completely close. During the wash cycle, water would be trickling down the drain and by the time the soap dispenser opens, the water would be gone or nearly gone.
Check this. When you hear the dispenser snap open, stop the dishwasher and open the door.
If you have little or no water, you are losing the water during the wash cycle.
Let me know.
Gary
Nov 22, 2008 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishwasher switched itself off during cycle - no power now
It is possible that some of the pips have been washed down into the drain pump and jammed the impellor, follow the drain hose back to the pump underneath of the dishwasher make sure the d/washer is switched off at the power supply before you attempt this, if you have reasonable mechanical skill you should be able to remove front of pump to clean it.
Oct 09, 2008 | Bosch Dishwashers
Whirpool 1100TXP Dishwasher.
is your water temp set at 120 degrees
Apr 07, 2008 | Whirlpool 24 in. DU1100XTP Built-in...
Whirlpool 24 in. DU930PWP Built-in Dishwasher Logo
314 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
