Projector overheating and turns off after 20 mins
Quick Question oh mighty one, 2810 Compaq projector, manufactured 12/5/01. Overheating and turning off itself. Cant find a person to fix it in Ireland, surprised....not me!!!. Any quik solutions to the problem please. proxima DP9260 Same problem, Just replaced the bulb, ceiling mounted, already upside down, can the heat sensor be cleaned or disabled? where is it and what does it look like? I have taken this thing completely apart and cleaned everything, checked all the fans functioning properly.does anyone have a diagram or schematic of the proxima dp9260 ?
  • 2 more comments
  • Anonymous Dec 30, 2008
    My MP3800 Projector overheats and shutsdown after 20 minutes as well
  • Anonymous Jan 15, 2009
    i have a panasnic pt-ax100u and the same problem, i live in south america and no one here can fix it, i turn it on and it shuts off after a minute, i power it down and start over and i get 30-40 minutes more at best and then it overheats! i was able to watch it for hours at a time before! it's only 7 months old, help!!
    i have a pt-ax100u (panasonic) same problem, i get 40 minutes at best, i live in south america no one can fix it here!!help!!
  • Tragichamstr Apr 25, 2009
    Ours eats it about 30-40 minutes into a movie. Ruins Friday nights regularly. Hate it. When we turn it back on, it lasts about 10-12 minutes. Very infuriating.
I need number of my Benq mp610 projector power IC
Posted on Oct 05, 2009
It stays on for 15 or 20 mins then light goes out but sound still plays with light out,then 4mins later it comes back on
Sounds likely that the projector is overheating. Try removing and carefully cleaning the filters over the air inlets. Carefully washing them in warm water and squeezing dry is usually satisfactory, but DO NOT replace in the projector and turn on until the filters have had at least 10 - 12 hours to thoroughly dry out.
Mar 29, 2014 | Christie DS+60 Multimedia Projector
Compaq MP2800 DLP Projector
If the projector is not getting a source it might go on standby maybe check where you plug it in.
Projectors require quite a bit of power and should be on a single loop/outlet not hooked up to a powerbar with more things on it.
Hope that helped.
Dec 26, 2007 | Compaq MP2800 Microportable Projector sps...
Pt-ax200u projector turns off after 1 min of operation. the light turns red then green. After that, the power button does not respond and i have to cycle off the project. If I turn it on, it does the same...
your projector is detecting it is overheating, check that nothing is blocking the vents and that the fans are not clogged. If the vents and fans are dirty clean thema paintbrush and hoover. If they arent then the lamp maybe the culprit
Mar 07, 2011 | Panasonic PT-AX200U Projector
When i first turn it on the message (projector over heated will automatically shut off lamp) comes up and then shuts off after 2 mins
You have an overheating problem.To solve it
1) Ensure that there are clear air pathways around the projector
2) Clean the air filters.
3) Ensure that the fans are running. If the fans don't run the projector won't fire it.
It is likely that cleaning the filters will solve your porblem.
Feb 15, 2011 | Optoma EP716 Multimedia Projector
New bulb, fan working, after 10 mins of operation get posterized image; suspect overheating; dust has been cleaned out; has not been taken apart
Hi!
Is the projector placed in a box or an area where it could generate overheating? Is this projector still within warranty?
Please feel free to update me. Cheers!
Feb 04, 2011 | Optoma TX1080 Projector
Hitachi ED-X8250 - Turns off after 15 mins LAMP and POWER = RED
reset the lamp and filter timers. turn the projector off then back on.
Mar 29, 2010 | Hitachi ED-X8250 Multimedia Projector
My Epson EMP-TW20 projector has consistantly started cutting out 20 mins after being turned on, it then switches to stand by and I think the fans go on for about 5 mins. However, if I switch it straight...
clean it out with canned air. the dust keeps in the heat that the projector is trying to expell. you may need to replace the temp sensor, as the constant heat may have weakened the sensor.
Nov 01, 2009 | Epson EMP-TW20 LCD Projector
When you are watching on projector sanyo PLV-Z2 it goes off and
overheating. possible fan malfunction. clean out the projector with canned air. dust keeps in the heat.
Oct 24, 2009 | Sanyo PLV-Z2 Multimedia Projector
Infocus IN1 Gaming Projector
Hi, I just bought the same projector Infocus IN1 and after just 15 minutes of use it turned off due to overheating. It seems that the lamp is very ineffecient and produces too much heat. The ambient temperature in the room is only 16 deg. celcius.
The solution I came up with is to have a standing fan blowing air directly on the back of the projector from less than a foot away. The standing fan which we usually use here in summer was enough to keep the projector cool. The infocus IN1 did not switch off for the next 2 hours (the entire length of the movie), until i turned it off myself. I am not sure how this system will fare in summer when the room temperature reaches 30 deg. celcius.
Oct 21, 2008 | Compaq Microportable 2810 Multimedia...
I have a HP VP6111 projector that works fine on a table top but overheats ( overheating ) when turned upside down and hung from my ceiling. My solution...I went to Circuit City and bought two 80mm computer fans. I also purchased a 12V power supply from Radio Shack. I put one fan on front of my projector and the other on the back of the projector and wired them into the 12V power supply. I mounted both fans with velcro. The front fan pushes air and the rear fan pulls air. The projector now runs fine without shutting off. The fans are 12V and push 34 cubic feet per minute of air. I am very happy with this solution.
Oct 25, 2006 | Compaq Microportable 2810 Multimedia...
1,352 people viewed this question
jasbo
jasbo
