Question about Samsung DLP HL-P5663W 56" TV
Samsung hl-s5679W LED DLP TV not starting up/no sound
It was clicking 6-10 times before the picture would come on... we were gone for a long weekend and now it took 50min of clicking to come on and then with no sound once it had a picture... lasted about 5 min , then off with flickring blueish screen....still no sound...
Capacitors on circuit board? How do I remove and replace...
a little over a year old from ebay, refurbished... Thanks, Mike
SOURCE: Samsung HL-S5679W Check no. 3 fan message
Their is no more you can do.
You need a professional.
Stop using the TV until it is repaired.
Call the manufacturer to find you nearest authorized service center.
MR. TV Sales & Service Inc
Milwaukee, Wisconsin 53405
(414) 762-8600
Established 1974
Posted on Mar 24, 2009
Axle80
  • 73 Answers
SOURCE: samsung DLP TV won't turn on
This sounds to me like one of two possibilities. First, check your ballast. If you're going through bulbs faster than you think you ought to be, you may have a ballast that is overloading. Its the 3" x 8" circuit board that connects directly to the bulb. They are plentiful and often cheap. Thats what I'd try first. If that doesnt' do it, I would invest in a new power supply board. That the board that the tv power cable hooks directly in to. This should give you a start, Comment back if you still need further help. Good luck.
Posted on Jun 06, 2009
  • 195 Answers
SOURCE: Samsunb 4051: TV screen turns off sound stays on.
Most likely this set has an "integrated" inverter, as most samsungs do--and this DOES sound like an inverter problem. Make SURE thought, there are no more bad "10 volt" caps on the power supply...ALL of them need to be replaced no matter HOW they look.
Posted on Oct 15, 2009
  • 4234 Answers
SOURCE: samsung tv model# HL-S5679W all three lights on
The "lamp" in this set, I think, is called the "DLP" in the parts listings. That part is number: 4719-001960 and can be purchased from tritronicsinc.com for $249.75 plus shipping. Use the guest account to access this info.
Hope this helps,
Dan
Posted on Feb 17, 2010
ladywinn
  • 5138 Answers
SOURCE: Samsung HL-S5679W won't start - LED light blinking
Replace Lamp,but CK to make sure Fans are running if OK then replace Lamp Mats Has them for 99.00
1-800-628-1118
Posted on May 11, 2010
The picture on my Samsung HL-S5679W all of a sudden starts strobbing and then starts turning blue from the bottom and moves up over the whole screen. No issues before this
Sounds like T'Con fault. Contact any service technician to confirm. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 16, 2014 | Samsung Televison & Video
Hi I have a Hl-s5679w led-dlp and it just started turn on and off, I have been reading online and the solution keeps coming back to under-sized capacitors, now to my question Would I be able to upgrade the...
Yes you would. On the power supply board under the heat sink. Do not upgrade the UF but you can upgrade the volts so if the caps say 10v 2200uf go to the 16v 2200uf and always make sure they are 105c degrees.
Mar 03, 2011 | Samsung HL-S5679W 56" HDTV
Samsung HL-S5679W - Power-up issue
There can be a few causes. One of the LED Modules has gone bad, The LED Driver board has gone bad and or the Power Supply has gone bad. You will need to have a good tech look into it.
Apr 03, 2010 | Samsung Televison & Video
Samsung tv model# HL-S5679W all three lights on front panel blink, no pix or sound owner's manual says lamp may be defective this is a DLP-LED. No conventional single lamp
Hope this helps,
Dan
Feb 17, 2010 | Samsung DLP HL-P5663W 56" TV
Have Samsung HL S5679W 56 LED 1080p DLP HDTV Problem no picture maybe Power Box??
could be the lamp, ballast, smps board(power supply board) or the main board.
Nov 05, 2009 | Samsung Televison & Video
WILL NOT POWER ON, STANDBY, LED, TIMER LIGHTS ARE BLINKING.
Check the capacitors on the power supply first. If any have domed tops or signs of leakage, replace them. I had two go bad on mine. Call electronics parts supply stores first as these are not your average capacitors.
Jun 01, 2009 | Samsung HL-S5679W 56" HDTV
(414) 762-8600
Established 1974
Mar 24, 2009 | Samsung HL-S5679W 56" HDTV
Samsung HL-S5679W No video No sound
Jan 22, 2009 | Samsung HL-S5679W 56" HDTV
Samsung TV will turn on and off several times, then stay on.
First, need to check the power bar(if you use).
then. if don't use power bar, need to check the power board.
Dec 12, 2008 | Samsung HL-R7178W 71" HDTV
Samsung DLP HL-P5663W 56" TV Logo
96 people viewed this question
Henry  Thomas
Henry Thomas
