Question about Philips Televison & Video
Set channels - Philips Televison & Video
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Often channel setting is inside the Menu/Setup, Channel Memory. It is however very specific depending on the model or if you are using a cable box.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Dec 01, 2008
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • Philips Master
  • 13,433 Answers
Setting channels? Can you post me the model of your philips projection television and also clarify your problem please. And I will be able to provide you with a solution.
How do I Change the frequency on a Rkio Nike TWo way radio
Hi Gary - I copied this from the RIO NIKE manual:
mode button
Press MODE to select the setting you want to change.
The normal display is replaced by the adjustable setting.
Use the + and - buttons to adjust the settings.
These are the settings you can change.
1. Main Channel (1-14)
2. Sub Channel (1-38)
3. Channel Scan (ON/OFF)
4. Sub Channel Scan (ON/OFF)
5. Button Confirmation Tone and Roger Beep ON/OFF)
6. Vox (OFF, ON LO, ON HI) (psc[communicate wxonly)
When you have proceeded through all adjustable settings, the normal display will reappear. Or, press TALK at any time to return to the normal display.
select main channel
There are 14 main channels.
To select main channels:
1. Press MODE until CHAN is displayed.
2. Press + and - keys to select the main channel.
select sub channel:
Each main channel has 38 sub channels, sometimes called
CTCSS channels. Select one of these sub channels to transmit
on a channel that is free from traffic.
To select sub channels:
1. Press MODE until SUB CHAN is displayed
2. Press + and - keys to select the sub channel.
Note :If you select channel "0," you will be able to receive transmissions from all the sub channels of the main channel you selected.
Download manual:
Jan 27, 2014 | Rio Nike PSC Communicate (14 Channels)...
Kenwood TM-281A cant set memory channels
Great to hear you have resolved the issue, Jason.
Cheers,
Peter
Aug 16, 2012 | Kenwood Tm-281a Vhf 65 Watt Mobile Two Way...
I lost the remote to my Toshiba cz27t31. I bought an RCA universal remote. The RCA manual says the tv should be set to channel 1. But I can't change the channel without the remote. So I am SOL! How...
  • You have to set the channel you want as a favorite first and you can do this from the TV. This is why the channels skip as you press up and down. Sometime or another those were someones favorite channels.
  1. Press "MENU" on the TV until "SET UP" appears on the screen.
  2. Now press ^ or v until "FAVORITE CH" appears in purple.
  3. Now press < or > to display the favorite channel FAVORITE CH menu.
  4. You will use < or > to got between "SET and "CLEAR."
  5. So now go to "SET" and press ^ or v until you get to channel 1.
  6. If you want to delete a channel first then select "CLEAR" and then add the channel you wish.
  • What your doing when you push the channel up and down on the TV buttons is going through the favorite channels. So make one of the favorite channels channel 1 and program your remote.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 20, 2011 | Toshiba CZ27T31 27" TV
Whats the process to change RF to channel 4?
1 Press POWER to turn the power off.
2 Press TV/VCR, current VCR Output Channel will appear on the LCD display.
3 Each time TV/VCR is pressed for 2 seconds, the LCD display changes as follow
clock press tv/vcr RF3 2 secondes later RF4.
• VCR Output Channel is automatically set during EZ Set Up.
1. If Channel 3 (or 4) is an active broadcast channel in your area, the Channel 4 (or 3) will be set.
2. If both channel are the active channel or none active channel, the VCR Output Channel will be set to Channel 3.
• Cancelled the EZ Set Up by pressing POWER during EZ Set Up before setting the Output Channel.
• VCR Output Channel will not change to previous VCR Output Channel if TV/VCR is pressed continuosly for more than 2
seconds.
May 27, 2010 | Sharp VC-H965U VHS VCR
Don't know how to set channels w/new cable box.
Use channel 3 or 4 or hook up the RCA jacks. If you use 3 or 4 leave it on that channel and use the cable box to change channel. Use RCA jacks (best) turn the channel on the recorder to line in ether LINE1 or LINE2 with one you plug it up to and leave it on that channel.
Jul 23, 2009 | Toshiba RD-XS32 DVD Recorder
Tried the RF Out setting and now Ican't reset it or even get the STB to respond to set up or anything.
If you changed the RF out channel setting on the DTV converter and now can't see the output of the converter try changing the channel on the TV set. THe DTV converter boxes are designed to output either RF channel 3 or RF channel 4. If you were on channel 3 and changed the converter output to channel 4, you will have to change the TV channel to channel 4 to see it again.
Hope this helps.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
Get channel 3 on tv with autoprogramming
When you select channels, the one that comes in the channel number will be green and if you manually select 03 it will probably be red. Hit menu and add channel 03
Jan 16, 2009 | GE 32GT740 32" TV
Magnavox 15MF400T/37 Channel chosen is not correct channel
Check the instrucitons to verify if the channel table is pre-setable to designate your own numbers.
Most TV sets have an autoprogramming for the channels. Look in the menu for the auto programming and let the set re-program the channels if your set has that option. This feature will re-program the channals, and re-set their defaults.
If the channels are not able to be pre-setable to a custom table, then this indicates that there is a pre-scaling fault in the tuner or in the uPC. In this case, the set will need service.
Jerry G.
Mar 25, 2008 | Philips Magnavox 15MF400T 15 in. LCD...
Problems setting up
Please post what Make/Model of television you have, and I will gladly help you. Thanks!
Jan 20, 2008 | Televison & Video
Channel set
Apparently your TV is set to the "standard TV" position. Before you auto program your set, set it to the cable mode and then do the autoprogramming. In the standard TV setting, you just get off the air channels 2-13 vhf and 14-83 uhf.where as in the cable mode you get vhf channels 2-13 plus your cable channels. Stargazer
Mar 17, 2007 | Daewoo DTQ-13P2FC 13" TV
Televison & Video Logo
16 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
