Question about HP Compaq ProLiant ML530 Server
Compaq Proliant ML530 will not start up. I have a green blinking light on the power supply and the unit will not power up. There seems to be some power getting to the mother board because i can see some LED's lit. Right next to the power button on the front of the machine the there is an amber light like it's ready to start up. I hit the button like i would normally do to start the maching up but i get nothing.
  • 1 more comment
  • almasi Dec 22, 2008
    I have the same problem, do you know the solution yet?
  • amolsamp Dec 28, 2008
    My server giving red light indication on front side
  • kipot Jan 15, 2009
    i have some problem here
Scasi
Posted on Aug 04, 2009
How to enter in bios to boot change sequence in ProLiant ML 530
Press F10 during post boot if you have smartstart installed in the partition. If not, you need to boot from SmartStart CD.
May 08, 2010 | HP Compaq ProLiant ML530 Server
When i start it show 2 redlight and its blinking
The Firmware Maintenance CD, which shipped with Rapid Deployment Pack - Windows Edition 3.50, allows the iLO 2 firmware to be successfully upgraded using the "Upgrade ProLiant ML/DL/BL Firmware" job in RDP.
For more information on Rapid Deployment Pack - Windows Edition, refer to the following URL:
http://h18013.www1.hp.com/products/servers/management/rdp/index.html
Jan 25, 2010 | HP Compaq ProLiant ML530 Server
Compaq proliant 5500 server wont power up
In my experience when a server/computer does absolutely nothing when the power button is pressed it is a dead processor. That may not be the case in your situation. It could be as simple as a defective power switch. Is the switch a soft touch or does it push in and click? Does the switch feel normal when pushed? One of the power supplies could also be bad. Do you have any good power supplies to test in the server? Were there any power outages recently that could have caused damage to the PSU? I would start with checking the switch. You could hook up a circuit tester and see if the switch completes the circuit when depressed. Also take a look inside the server and look for any loose connections on the mainboard. It is possible the wire for the power switch has come loose.
Sep 05, 2009 | Compaq ProLiant 3000/5500 Redundant...
WHERE CAN I GET THE MANUAL
go to the site below and choose your model then it will give you the option to download the manual:
http://h10025.www1.hp.com/ewfrf/wc/pfinder?lc=en&dlc=en&cc=us&tool=&query=proliant+ml530
Jul 16, 2009 | HP Compaq ProLiant ML530 Server
Compaq Proliant ML530 driver downloads...
Start at support.hp.com. Select your location, then search for your model.
There are 2 types of ml530
http://h10025.www1.hp.com/ewfrf/wc/pfinder?query=ml530&dest_page=product&lc=en&cc=us&dlc=en
Jun 06, 2008 | HP Compaq ProLiant ML530 Server
What is it worth?
Honestly, it depends on the make (g1, g2, g3) and configuration (how many processors, amount of memory, how many disks, type of RAID card, redundant power and if it woks) I remember these machines were pretty bulletproof. Find out the config for each, then you can make a fair comparison using ebay.
Apr 20, 2008 | HP Compaq ProLiant ML530 Server
Removing cd rom
Preparation Steps before removing CDROM:
1.Power down and remove power to the system.
2.Remove access panel.
3.Remove CPU fans and fan basket.
4.Pull the system tray out until it stops.
To remove the CD-ROM drive:
1.Disconnect the power and signal cables from the CD-ROM drive.
2.Loosen the thumbscrew located in the fan basket area to release the metal locking bracket.
3.Slide the metal locking bracket away from the center of the server.
4.Push the CD-ROM drive out of the front of the chassis from the interior of the system.
5.Pull the CD-ROM out and away from the chassis.
Apr 12, 2008 | HP Compaq ProLiant ML530 Server
ML530 Startup
Check your Hardware configuration.  This usually happens when you tell the system BIOS that you have for example, a second floppy or Hard Drive, when you do not.  So it stops and asks you what to do next.
Hope that helps.
Eddyfix
Oct 12, 2007 | HP Compaq ProLiant ML530 Server
Adding a network card in compaq ML530
If you have the tower model. Swing open the front bezel left to right. Then lift up to remove it. Chap 3 of your manual. Using a #15 Torqx allen wrench provided on the back of the unit remove the cover plate screws to gain access (Chap 2 of your manual). The rest should be simple.
Sep 15, 2007 | HP Compaq ProLiant ML530 Server
HP Compaq ProLiant ML530 Server Logo
654 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
