Question about Eureka Altima Upright Vacuum Model 2996AVS Vacuum
Handle broke off when Vacuuming?
So what do you do when the handle snaps clean off when you are vacuuming? My husband was vacuuming the front room and when he pulled it back the handle came to him, but the vacuum landed on the floor, with a thud. Any ideas, why or how this could happen? Any suggestions on how to fix it?
  • 1 more comment
  • dusty_low Dec 01, 2008
    model number 2991
  • dusty_low Dec 03, 2008
    The screws where there, it broke off near the top, so we just used lots of duct tape, not so pretty, but it works. I guess we could order a new part, but again, since the vacuum is only 85 dollars new, and yearly filters total upwards of 40, we'll just buy a replacement after a year. Thanks anyway, not really sure why I posted on this forum, other then I found the site. Just thought it was interesting that the handle would just snap right off.
    Thanks.
  • David Cleary May 11, 2010
    What is your model number?
    Scholar:
  • 55 Answers
Two screws hold that handle onto the machine. Maybe they weren't installed when the machine was put together.
If it broke part of the dust compartment, it's probably not worth fixing.
If it broke part of the handle you can order a new one for about $30.00. It's part #75765-2.
Posted on Dec 02, 2008
  • David Cleary Dec 03, 2008
    Filters on a lot of those bagless machines are way too expensive. The are made to sell filters. Bagged units were always better filtration, and less expensive. But if you have to have bagless, you might look into a Bissell next time. Usually the primary filter on those are foam washable filters, and they should only run you about four dollars if you have to replace one. Just something to think about.
How can I lower the handle of my kenmore vacuum cleaner to the vacuuming position?
Left lower side is a handle/pedal wich you push with your feet!
May 02, 2014 | Kenmore Vacuums
My Hoover Linx handle broke.
Not sure what you mean by a broken handle, but if you mean the plastic is cracking where the handle connects to the main body than I have a suggestion. We have had this happen a couple times and I tried various fixes that did not work. However, recently I found a cheap product that will strength the handle to make it stronger than new. It called Fiber Fix tape (its on Amazon). Wet the tape and wrap the handle. It is a quick set epoxy in a fiberglass like cloth. Dries very hard. Not pretty, but it works great.
Jun 19, 2012 | Hoover Platinum LiNX Cordless Stick Vacuum
Power cut off after handle was dropped on floor while vacuuming
connections inside the handle came loose. happens to me all the time. take the handle apart and connect the wires back.
May 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Dyson DC07
Hi.
If you look at the front left side of machine there is a removeable inspection port it will have 2 coloured buttons you press these in & pull it up to remove.
Now pull handle back as if vacuuming the floor.
Now where the inspection port was you will see that there is a square hole pull forward on the flap in front of square hole it pivots just behind the round rubber seal.
Slowly lift handle back up at the same time The part with the 2 long grooves in it must go under the flap as you lift handle.
Chris.
http://dysonmanuals.llc.nu/
Oct 10, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Handle broke
Part # for the handle is 75765-3. You should be able to order thru a local service repair shop.
Jun 08, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Brush roller won't turn
On my Dyson, there is a brush reset button on the top right hand side (if you are looking at the front) that you can press to reset the brush. I was vacuuming and too lazy to move a toy and this worked for me once I freed the rope from the brush.
May 18, 2008 | Dyson DC07 All Floors Bagless Upright...
Vaccum head stuck in down position
Hi.
Chris.
Nov 25, 2007 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Putting new vacuum together position of the handle
The handle should be attached so that the open portion of the handle is facing towards the brushs( away from user)
Sep 03, 2007 | Dyson DC14 Full Access Bagless Upright...
Eureka Altima Upright Vacuum Model 2996AVS Vacuum Logo
103 people viewed this question
Top Eureka Vacuums Experts
charlesjo336
Level 1 Expert
JoeVacs
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
