Question about Vizio L32 32 in. LCD HDTV
How do I turn off captions on vizio tv with remote?
Don't know how to do this
  • 218 Answers
With the television on and in tv mode, press the CC button on the remote. It's the button with a square on it. That should get you into the closed captioning menu.
You could also go into the main setup menu and find it there. For more information, here's a link to your user manual for the Vizio L32.
http://www.vizio.com/assets/0/92/94/120/ea3894d0-b0e7-4526-b80e-1dfd9bbd4bdd.pdf
Posted on Dec 01, 2008
4 Suggested Answers
SOURCE: My Vizio 37' flat Screen TV Closed Caption wont turn off
If you have a digital cable box, turn off the box but leave the TV on. Hit the "Menu" button on the front of your cable box and a setup menu should come on. Use the cursor buttons on your box's front panel to go down to the "Captions" option, which is probably set to "Enabled" and hit the right or left cursor button to change it to "Disabled." That should solve your problem.
Posted on Jan 10, 2009
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
Can I turn the caption mode off with the remote?
CC (Closed Caption)
To select the options in the CC sub-menu, press the MENU button or the #
button. A new menu will be displayed showing the following CC settings:
CC
The CC feature is available when watching regular analog (NTSC) TV.
Select from CC1, CC2, CC3 or CC4. Closed Caption for regular TV is
usually CC1 or CC2.
Digital CC Style
The Digital CC Style feature is available when watching digital TV.
Select either As Broadcaster or Custom. If Custom is selected then
you can customize the way Closed Caption is displayed.
Feb 14, 2015 | Vizio VF550M 55 in. LCD HDTV
How do I take the captions off my tv I pressed the cc button and didn't work and under the menu it doesn't give me that option
The closed caption may not be activated on your tv but it could be active on your cable/dish box. Use that remote and find the CC button. If that is the remote that you are using then find the original remote for the TV and turn it off with that one. Sometimes the remote has it named TEXT instead of CC.
Dec 05, 2014 | Vizio M3D651SV 65" Class LED Smart TV
I can't turn on the closed captioning on my vizio
The closed capation function should turn ON and OFF, by each press of the button one the remote control marked "CC". If not, check the remote control. It is not the fault with TV.
Jul 01, 2013 | Televison & Video
How to closed caption on mute vizio
Hello -
The remote control for your Vizio TV probably has a Closed Caption button. Is there a button with CC printed on it? If so, that is most likely the button to press for Closed Captioning.
Dec 23, 2017 | Vizio 42 in. LCD TV
My closed caption is on and I can't turn it off. I don'want the writing on the screen
Did you try turning it off with the closed caption button on the remote? Its labelled cc. If you dont have the original Vizio remote you will need to go into menu-settings and find the closed caption and turn it off there
Oct 24, 2011 | Vizio L37 Television
I have a Sanyo TV DP32648 and the closed caption won't turn off. i don't have the original remote and even now have a programable logtech remote. how do i turn off the closed caption
You will need to have CAPTION button on the universal remote control to turn on/off the caption, if it does not have that function then you will need the original remote.
SANYO remote model GXBJ is needed for this TV.
You can get used one for $20 on EBAY or a lot more for new one at:
http://remotes.com/remotes/servlet/rs?a=gmi&smodel=DP32648&brand_pn=SANYO_DP32648&mode=large&v=1&uuid=A13140757813801
Aug 23, 2011 | Televison & Video
I have an Orion 19"
You usually need the original remote. The trouble with universal remotes is that they generally control only the basic functions of a TV (power, volume, channel) but not much else. Without the original, you often lose other functions. You can try the front panel buttons if yours has them. On some sets the on-screen menus allow you to access caption settings.
But are you sure the captions are coming from the TV? Sure, the TV is displaying them, but if you have a satellite receiver, cable box or digital set-top box, the captions may be coming from that device. This is likely to be true if the captions just mysteriously started and you don't have or aren't using the TV original remote. These devices often don't allow a TV's built-in caption decoder to work properly, so they provide captions themselves. You may have turned captions on using that device's remote. Check the menu for caption controls.
Jul 10, 2011 | Orion1934 19" TV
My Vizio VA19L 19'' LCD Television's closed captioning isn't working. The closed caption isn't on the settings menu either. How can I get closed captioning on?
Just press the CC button on the remote. Some TV stations may not send out CC data. Pressing the CC button many times will cycle thru all the options including OFF.
Mar 05, 2011 | Vizio VA19LHDTV10T 19 in. LCD TV
Cannot turn CC ON/OFF via remotes
Try this combination.
1) Start with the cable box turned on and TV on tuned to the cable box.
2) Press the POWER button for the cable box and then quickly press the MENU button.
3) This should bring up the user setting menu. Use the arrow keys on remote to go to Closed Caption and press right arrow button this should bring up the closed caption menu.
4) Press the OK button and this should either turn CC on or off.
5) Once Closed Caption is turned off press LEFT ARROW button to return to User Settings Menu.
6) Press the POWER button to turn the Cable box back on and the Closed Caption should be gone....
Good Luck.....
Jan 17, 2010 | Vizio VW32L 32 in. LCD HDTV
Close caption problem
Use ur remote turn off CC functions on the remote.
Or go to the menu go to the caption turn everything off like Text or CC1 CC2.
Sep 23, 2009 | Vizio VW42LF 42 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
4,832 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
