Question about HP Compaq Evo n610c Notebook
BATTERY is charged, but will not work without being plugged in
BATTERY is charged, but my computer will not work without being plugged into the wall. How can i use the battery so I can take the thing with me?
  • Anonymous Dec 07, 2008
    BATTERY is charged, but will not work without being plugged in problem, and notify you when a new solution is offered.I replaced the battery and the problem is not solved.
  • HP Master
  • 32,281 Answers
Your battery is old and worn out, even though it indicates as fully charged. The battery capacity is practically zero. Rechargeable batteries have a finite number of charge and discharge cycles.
You need to buy a new battery if you wish to use the laptop without connecting to the mains.
Posted on Dec 01, 2008
I have a GC-XA2BU and the camera will not cut on? I have purchased a replacement battery but neither work.
As soon as you connect a camera to a computer, it will stop working, because the USB connection will be used to charge the battery.
If your computer is not correct wired on the USB port, or when you are using a hub, without an external power supply, the battery will not be charged. So you end up with an empty battery and a camera that does not respond.
Try charging the battery on an external charger and remove the USB cable, before switching on the camera. Also check if the USB connector on the camera is free. Avoiding the camera to "think" there is still a USB cable connected.
Feb 11, 2014 | Cameras
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
Fuji jx520 wont charge
Your battery probably is in the wrong way.So take it out and look on the bottom of it.You will see 3 copper cubes.Next look in to the slot where the battery goes and you will see 3 metal wires.Now take your battery and carefully line up the copper slots with the metal wires.Then push the battery in and close the battery slot.And your done go plug it into your USB slot and you will see a white battery symbol and you will know that it is charging.
Simple fix for a simple problem.
Aug 29, 2012 | Fuji film FinePix Z70 JX520 JV200 Z900EXR...
My emachine em350 battery is not fully charging. it started by charging to 89% then 86% now its at 65% I bought it 5 months ago. What should I do?
Here's how Dell
recommended a reset. First, power down and remove baterty. Second, unplug
AC Power adapter from computer AND wall. Third-Wait till green light goes
out. In my case, went and got coffee and watch a show. Fourth plug adapter
into wall and computer and power up WITHOUT the baterty installed. After
boot up, insert the baterty. It worked?!!?!
Sep 07, 2011 | Acer eMachines 350-2074 Netbook
I have a new e627 used only once before today. Battery connection was partially out and screen indicated low battery. After five minutes screen went black and now I cannot power up.
Maybe your battery is totally drained.
Try to connect the AC adaptor of your laptop and plug it to the wall outlet and let it charge for 3 hours or more. When you plug it on the wall socket, it won't show the laptop's led blinking since it was totally drained. But after 3 minutes or more, it will start to show the blinking led to indicate charging. When blinking stops led light disappears, it is fully charged and ready to use.
Remember: Do not use your laptop while it is plugged in to save your battery life. When at home, remove the battery while it is fully charged and plug the AC adaptor directly to the wall outlet. It will still work without the battery as long as it is plugged directly to the wall socket.
Feb 23, 2010 | Computers & Internet
My Sansa c250 won't charge properly. Initially when I bought it, I used it with a Windows XP PC, no sweat. That computer died and I began charging it with an OSX instead. It worked for a while, but after a...
I had a similar problem. My Sansa c250 would charge, when plugged into the computer. It would read that it was writing but the computer did not recognized that the Sansa c250 was connected. I switched to a different USB port and got the same results. I then realized that the two ports I was using were 1.0 port and idmedeatly when inserted in the 2.0 port it began charging and the computer recongized the Sansa c250. I know this won't solve every charging problem one may have. Changing the battery would be easier in some cases. Especially if they were sold like the AA or AAA.
Jun 08, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Want stay charged
Sounds like a bad battery cause its not keeping a charge. Try a new or known good battery and see if it will charge and then unplug the ac adaptor to see if the laptop stays on.
If the laptop stays on with a different battery charged then your old battery is bad. If your laptop doesn't stay on with a known good or new charged battery without the ac adaptor hooked up then its a bad motherboard.
Feb 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
Battery problem
You can get a new battery from ebay and it very cheap hope this helps
Dec 27, 2008 | Sony PlayStation Portable (PSP) Console
My charger won't work so now my computer wont turn on
Unplug you ac adapter from the wall and plug a lamp in to verify that the wall plug is working correctly. Pick up the adapter to see if it feels warm. Most adapters will feel warmer than room temperature if they are working,
If the cords on your adapter can be unplugged from the adapter, reseat them. Try the ac adapter in another wall plug to see if it comes on. The adapter may have an LED on it that indicates whether or not it is on. If it doesn't, about the only way to check it is to use a multimeter to see if there is any voltage on the plug that goes into the back of the laptop. If something else will work in the original wall plug and the adapter won't work in another wall plug, you will need to obtain another ac adapter.
Once you've tried these things, let me know and we'll go from there.
Nov 11, 2007 | Acer Aspire 3680 Laptop
HP Compaq Evo n610c Notebook Logo
104 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
