Question about Maytag LAT3600A Top Load Washer
Washer will not work after filling it with water
I filled my Maytag LAT8416AAE washer with water. Now it will not run. I checked the breaker, it was fine. Ran the time switch to every cycle, still nothing. It seems as if it does not recognize the fact it is ready to go through a wash cycle.
    President:
  • 878 Answers
Shawnie, sounds like your lid switch is giving you problems. They revised the switch, it comes in a kit with instructions. Part number 12001908. Take a small screw driver with the lid closed and push in on the actuator to verify that this is the problem. Catriver..post back.
Posted on Jan 27, 2007
  • jlyles09
    jlyles09 Feb 14, 2014
    what about the new valve tha was installed. should I change the valve?
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
My Neptune Top Load fills the water, the motor doesn't start.
If i understand correctly you are stating the breaker shut down which means the house breaker for the outlet power kicked out. You might try plugging something else into the outlet to see if it also kicks out, say a vacuum cleaner of a drill.
You need a amp clamp to test for something shorted or grounded (or ohm out windings) which requires trained service........you do not want to get a shock
Jan 20, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag washer, will not fill w/waterit runs in
Check your drain hose. It only goes into the drain stand pipe from 4 to 6 inches. Insertion any further will creat a siphon and constantly drain the tub. The stand pipe needs to be at least 36 inches from the floor.
Dec 30, 2009 | Maytag HAV3460AWW Top Load Washer
D/washer fills with water rinses when heating shorts out house
If this machine has been installed and worked for a while, are you sure nothing else has been pluged into the same circuit as the dishwasher and overloading it. If the element is actualy heating up I doubt anything is wrong with it to kick out the breaker. Check out what other stuff goes out with the breaker off.
Oct 29, 2009 | Maytag 24 in. MDBH970AWS Built-in...
During the fill cycle, the washer leaks water?
I've repaired leaks from bad rubber washers on the fill hoses as well as loose hose clamps on the back of the fill solenoids that run into the tub. Check closely.
Jun 27, 2009 | Maytag Washing Machines
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Washer trips circuit while filling tub
Sound like the inlet valve coil may be shorted. Remove console and check wires from water valve to control. If wires look ok, the inlet valve has a problem
Mar 18, 2009 | Maytag PAV2300 Top Load Washer
Maytag Atlantis MAV7600AWQ Washer. Delayed fill
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
Mar 07, 2009 | Maytag MAV7600 Top Load Washer
Maytag Washer/Dryer stackable
well i am having about the same problem, but mine won't even fill, the dryer works but the washer won't fill or turn on at all. my husband had it all apart, too the control assembly to parts place and they said that hardly ever goes bad so it is still sitting unusable with no answer or money to spend on it in site.
Jan 15, 2008 | Maytag LSE7806A Top Load Stacked...
Maytag LAT3600A Top Load Washer Logo
197 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
