Question about Lexmark Office Equipment & Supplies
Just bought a new toner cartridge for my lexmark e 120n.it came with a red plastic frame over the cartridge.. do Ihave to remove the frame before installing ??
    Scholar:
  • 81 Answers
Can you be more precise about what the 'frame' is and is the toner a manufacturer's toner or after market.
Posted on Dec 01, 2008
PRINT BECAME VERY LIGHT,HOW TO IMPROVE?
change new toner cartridge or good quality toner for better image.also before refilling make sure remove old toner from the cartridge and clean inside the cartridge with blower. you will get with a good quality image
Dec 12, 2015 | Brother DCP Office Equipment & Supplies
Cartridges error on a lexmark
Error: "Invalid Toner Cartridge"; Error: "Invalid Refill"; Message: "Change Cartridge"
Solution
One of these error messages may appear on the printer display immediately after or shortly after a new toner cartridge is installed into the printer. Note: This may not be specifically a toner cartridge problem; the error may be due to a stuck cover open switch on the printer.
To see if the cover open switch is the cause of this problem, open the top front cover and observe the message on the printer's display panel. The display should read Close Door or Insert Cartridge.
If this message is not displayed, the top cover open sensor and switch will need to be replaced. In addition, the printer may have damaged the new toner cartridge. If the cover open sensor is not operating properly, a new cartridge can be incorrectly flagged as a refilled cartridge by the printer. If this happens, the new cartridge will continue to cause an Invalid Refill or Invalid Cartridge error even if you try reinstalling it or installing it into another printer. If this should occur, please contact the point of purchase of the cartridge to find out how to get the cartridge replaced.
Caution: If the cover open sensor is not operating, do not install another new toner cartridge until you have completed the directions below. Inserting another new cartridge can cause that cartridge to stop working as well. Should this situation arise, please take the following actions:
Place the original working cartridge (the empty or near-empty one) back into the printer. This should clear the error message.
Turn the printer off. Doing this will disengage the cover open sensor.
With the printer switched off, open the top lid and remove the old toner cartridge.
Now replace the old cartridge with another new Lexmark toner cartridge.
Power the printer back on. The printer should now read this cartridge as a newly installed toner cartridge and the error should be cleared. The printer and toner cartridge should function properly now, but the top cover sensor on the printer will still need to be replaced.
If your printer is still under warranty or covered under a service contract, please contact Lexmark Technical Support or your service provider for further recommendations and instructions. Until you can get the cover open switch replaced, remember to have the printer powered off whenever you replace the toner cartridge.
If the top cover switch appears to be working fine, or if you have followed the above steps and your printer continues to post an Invalid Toner Cartridge or Invalid Refill error, make sure you are using a new original Lexmark toner cartridge. A toner cartridge remanufactured or refilled by a third party can cause this error.
To help identify a refilled cartridge, look for the yellow label attached to the toner drum and the body of the toner cartridge. If this is damaged or removed, the cartridge may have been refilled.
If you are using a third-party refilled or remanufactured toner cartridge, it is recommended that you install a new Lexmark brand toner cartridge. Lexmark cannot guarantee the compatibility of any third-party toner cartridges with our printers.
OR
1 Switch on the Lexmark X83 printer.
2 Lift open the cartridge door at the front of the device, below the scanner unit. The printer automatically moves the cartridge carrier to the correct position.
3 Pull each ink cartridge toward you to unclasp it from the carrier. Lift the cartridge out of the cartridge carrier.
4 Clean the copper contacts on the bottom of each cartridge with a clean, dry lint-free cloth. Use a gentle, circular motion to clean the contacts.
5 Insert the ink cartridges back into the cartridge carrier. Push back firmly on each cartridge until it snaps into place.
6 Repeat each step in this procedure again. Close the cartridge door.
Oct 04, 2012 | Office Equipment & Supplies
I have red light the second (toner) and the last lamp (exlamation). The first one i don't care, it was red since i charged it, but since the exclamation is red doesn't do anything and the green...
The toner cartridge is not installed, or the printer detects a toner cartridge error. The error is caused by a defective cartridge, an unsupported cartridge an invalid refill, or a cartridge meant to be used in another geographic region.
If the toner cartridge is not installed, install it. If the toner cartridge is installed, remove it and install a new toner cartridge.
For Cartridge errors, Press and release the right button twice briefly to display secondary error codes.
For further assistance, please contact Lexmark Technical Support.
Jun 29, 2011 | Lexmark E120n Laser Printer
EVERYTIME I TRY TO PRINT....RED WET INK COMES ON THE PAGE
best bet is the red (Magenta)toner cartridge is leaking. Depending on where you bought it most locations will exchange it for a new one. Give them a call and ask. If they will not I would contact lexmark (support.lexmark.com) and ask them for help.
Best of luck
Nov 30, 2010 | Lexmark C522n Laser Printer
HOW DO I FIX THE ERROR 004-332...???
1. Reseat and clean the 4 toner cartridges and verify the orange plastic covers have been removed.
2. Reseat the toner cartridge carousel position. By doing the following:
Lift the handle of the first available toner cartridge or toner cartridge attempting to be installed and remove the toner cartridge.
Close the front cover. Power off the printer. Power on the printer.
An LCD message Insert <toner color> Toner appears. Open the front cover. To reinstall the toner cartridge, align the arrows on the cartridge with the corresponding arrows on the printer, guide the cartridge in until it snaps into place, and then push down the right lever to lock the cartridge in place. Close the front cover. The toner cartridge carousel rotates to the correct toner position.
3. Verify the developer rotor frame is not bent. If it is bent then the printer should be replaced, it would not be cost effective to replace the frame.
4. If it is not bent. Open the front door, try to rotate the carosel. It should NOT rotate. If the rotation is rigid and feels broken, then the printer should be replaced. If it rotates smoothly, the developer latch should be replaced. If the carosel does not rotate but still gives the error the rotor control board should be replaced.
Jul 16, 2010 | Dell 3010cn Laser Printer
I changed the toner on my Lexmark E250dn and now it has the "!" light on all the time and won't print. It's a new cartridge what is going on?
"!" means error.
Try removing cartridge and installing it again and might be one of the cartridge missing.
Try operating manual. Might helps, there are lots of reason for the error
ftp://ftp.lexmark.com/depot/LXK/E250_Depot_Repair_rev092606.pdf
Suspected
Follow the link on dispute about wrong cartridge due "Toner cartridge region mismatch"
http://www.techsupportforum.com/hardware-support/printer-support/379157-lexmark-e250dn-amp-quot-toner-cartridge-region-mismatch-amp-quot.html
Hope this helps
May 21, 2010 | Lexmark E250dn Laser Printer
Unable to print red.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled (the absolute worst possible choice) or third party cartridges (2nd. Worst possible choice) that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Mar 04, 2010 | Lexmark X1270 All-In-One InkJet Printer
My hp color laser jet2605dn has a brand new magenta ink cartridge yet does not print the red in pictures on my brochures
One solution is to make sure you have removed the orange plastic strip from the toner. The cartridges are sealed with a plastic strip when shipped and it needs to be removed from the toner side before installing.
Jul 13, 2009 | HP Color LaserJet 2600n Printer
Toner cartridge doesn't work
It's the chip (circuit). It's terrible quality control that you would get 2 the same. Lexmark makes the printer for Dell, however some chips are proprietary (Lexmark Only, etc) Interested to know if this is supposedly a universal cartridge . Maybe Lexmark E232, 332, etc.? Somehow they must have mixed up the chip supply in the remanufacturing process, and these are Lexmark chips only???? Just guessing.
Anyway, the chip is the problem. I'd return it and go somewhere else for the compatible, but it's up to you.
*please rate me :)
Mar 26, 2009 | Dell 1710 Laser Printer
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
