Question about Garden
Loose Fuel Line
The fuel line in my chain saw gas tank is disconnected and laying loose in the bottom. I do not have a manual, and do not know how to remove the tank and reconnect the fuel line.
  • jonh515 Dec 08, 2008
    identical problem, i.e., gas filter with about 5" of tubing just by itself in the gas tank; not connected to anything. Don't see a way to connect it back up. Any suggestions would be greatly appreciated.
  • 211 Answers
Hi rhopdo
Check where is the hole for the fuel line on the gas tank.Take off the fuel filter.Try to reconect the fuel line.
best wishes savumihai71
Posted on Dec 02, 2008
How do you hook up the fuel filter line inside the tank on a cs400
If you go online and search for the drawings for that saw you will see that the fuel pipe enters the tank at the top through a grommet. You will have to pop out this and then pass the pipe through this after passing it up through the hole from inside, long nosed pliers or tweezers will assist. Once you have that done stuff the grommet back into the hole and don't pUll it out again!!!!!!!!
Apr 03, 2015 | Echo Chain Saw. 18 in. 40.2 cc Gas Chain...
After replacing the fuel lines on a mac3200 gas is running out of the bottom of the saw, after the tank emptys the fuel quits leaking. the saw runs great though
This is usually because you used a fuel line that is too small to seal the holes they pass through in the fuel tank. When they pass through the holes in the tank they should be very tight so gas cannot leak past the lines.
Jan 31, 2011 | McCulloch 16 Inch Gas Chain Saw MCC1635AK
Need to know how to re-connect primer bulb on McCulloch Model # B00032-32, Ser # 11-100258 (McCulloch Gas Powered Chain Saw)
Take the line off of the primer that goes to the tank and leave loose for a moment. The other line to the primer comes from the carburetor and it should be be tried on either port on the primer until it will pull fuel into itself when pumped. If neither port works, the primer pump may be faulty, the carburetor is plugged internally, or the fuel line from the tank to the carburetor is decayed or the fuel filter is plugged. When the primer pulls fuel into itself, reconnect the return line that goes back to the tank. Hope this helps!
Dec 03, 2010 | Garden
Need to replace all gas lines
  1. Empty the fuel tank on the chainsaw of any remaining fuel. Pull the cap from the tank and turn the unit upside down. Drain the fuel into an approved fuel container. If the fuel is old (more than about a year) dispose of it according to local regulations for hazardous materials. (It can be kept longer by adding a fuel stabilizer.)
  2. Pull the fuel line where it attaches to the carburetor using the end of the needle-nose pliers. The old fuel line may take some force to pull free from the metal tube.
  3. Push on the fuel line to feed it into the fuel tank. Hold the chain saw upside down. Shake the unit to get the fuel filter into the opening of the tank. Pull the filter free of the tank. Feed the remaining fuel line through the access hole at the bottom of the tank. Dispose of the filter and old fuel line in accordance with disposal regulations.
  4. Feed one end of the new fuel line into and through the bottom access hole of the fuel tank. Push approximately 6 to 8 inches into the tank. You can pull back any excess line later. Grab the end of the plastic line with the needle-nose pliers. Bring the line through the gas tank fill opening.
  5. Attach the new filter to the end of the new fuel line. Feed the filter back into the fuel tank. Pull any excess line from the tank. You will want approximately 3 to 4 inches of fuel line inside the tank.
  6. Route the new fuel line to the carburetor. Cut the line to length with the cutters on the needle-nose pliers. Attach the line to the metal tube.
  7. Fill the fuel tank with fresh gas-oil fuel for 2-stroke engines and start the chainsaw. It may take a few pulls to prime the new line with fuel.
  8. Some models come with a priming bulb. Make sure you press the priming bulb three to four times before trying to start. This will prime the gas lines and remove any excess air trapped in the lines.
Nov 15, 2010 | Poulan P4018WT Wild Thing 18Inch 40cc...
Husqvarna 350 chain saw will only start if I manually put gas in the carb. and then it dies! I've clean the carb twice! The piston ring is within specs and the muffler is not dirty.
Typical fuel system:
8492ae1.gif Sounds as though there is a pin hole or crack in a fuel line.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The hose in the tank with the filter on the free end connects directly to the carburetor input connection.
  • If the saw is equipped with a primer bulb, an output line from the carburetor connects to the suction side of the primer (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill as it inflates).
  • The pressure side of the primer returns displaced fuel to the tank as it is depressed.
Take lots of notes and a few digital photographs to help with reassembly. It can also be an air leak, inspect for a loose or defective carburetor manifold or loose carburetor. If those are good then the likely cause is internal parts of the carburetor are dirty or have failed. HTH
Lou
Dec 19, 2009 | Husqvarna Chain Saw 20" Bar
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Husqvarna 145bt my gas line has come loose from the gas tank?
Hello etatum1634:
This File should Help.
The Following is a Basic Instruction File I made for Replacing the Fuel Lines and the Filter on Chain Saws and Trimmers. Any Input is Appreciated.
>>The Fuel Line is Pushed and Pulled (I Use Long Needle Nose Pliers) Through the Small Hole Until the Hose is Out the Fill Hole about a 1/2".
>>You can Also Use a Coat Hanger with a Small J at the End to Hook the Filter in the Tank and Pull the Filter and Hose (if Detached from the Carburetor) Out the Tank Fill Hole Enough to Replace the Filter.
>>Then Attach the Filter and Pull the Hose Back Until the Filter Lays at the Bottom of the Tank Just Below the Fill Hole (or so it is in the Bottom of the Tank and will Rest in the Fuel Mix when Turned at Common Angles the Unit May be Turned to During Operation.
>>**Hint: Use Plenty of Spray Lubrication at the Small Hole as you are Feeding in the Hose. It Slides Easier.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Apr 24, 2009 | Homelite 'Yard Broom' Leaf Blower
Saw stops when i give it gas.
  • plugged fuel filter
  • cracked/loose fuel line allowing air (instead of fuel) into the carburetor.
  • poorly fitting fuel cap
  • plugged or disconnected/broken pumper line
Feb 16, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Feb 13, 2009 | Husqvarna Chain Saw 20" Bar
Loose Fuel Line In the Gas Tank
hi rhopdo
try to find the spark plug near the muffler(exhaust)
check where is the hole from the gas tank, connect the fuel line to the carb.
yours savumihai71
Dec 01, 2008 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
73 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
