Question about Honeywell Electronic Programmable Heat/Cool Thermostat - CT3300A100 Heater
No ac or heat
Me centeral air or heat will not come on i changed the thermastat and still nothing the breakers are also good
  • 96 Answers
If the system is not to old it could have a fuse on the control board or it could be a bad transformer
Posted on Dec 01, 2008
Unit has no power, we had a power outage, power coming to unit is good.
Break A Breaker No Power To Air Conditioner Tripped AC ...
? 5:08
https://www.youtube.com/watch?v=nS2pBg2QbnM
Jun 2, 2013 - Uploaded by KungFuMaintenance
Break A Breaker No Power To Air Conditioner Tripped AC Can I Get A ... I have a GE model # AEM14aQL1 air conditioner wallunit 14,200 BTU ...
HVAC HELP! Unit has no power and Fan, Heat and AC are all ...
www.city-data.com > City-Data Forum > General Forums > House
Jul 1, 2012 - 10 posts - ‎8 authors
Now, when I attempt to turn on the AC I get no response from the unit. Nothing is blowing out of vents, even when fan mode is set to on. So far I ...
No power to outside AC unit - DoItYourself.com Community Forums
www.doityourself.com > ... > Air Conditioning and Cooling Systems
Jul 5, 2005 - I have an outside AC unit that appears to not get power. The circuit breaker is OK, and the fuse "appears" to be fine, but do not know if there is ... A/C problem, thermostat has no power
Aug 5, 2009
central a/c unit has no power
Sep 29, 2004
More results from www.doityourself.com
Dec 29, 2015 | Heating & Cooling
Breaker trips when heat goes on all other function are fine.....should I replace the heater's element?
heaters are normally on a independent breaker,inspect the element,any wiring .is the breaker the right size?possible short in switch are thermastat.may want a heat and air guy to look at that.
Jan 25, 2015 | Pool & Spa
My ac comes on for a second or not at all. Changed thermastat but is still doing it. The fan works fine and so does the furnace
APPEARS TO BE AN ELECTRICAL ISSUE=CHECK YOUR POWER-SINCE YOU HAVE 2 AC UNITS, I ASSUME 50 AMP SERVICE. FURNACE IF GAS POWER BUT ELECTRICAL FAN DOES NOT REQUIRE A LOT OF ELECTRICITY. CHECK ELECTRICAL FIRST. WHY DID YOU REPLACE THE THERMOSTAT?? ARE YOU SURE OF YOUR THERMOSTAT WIRING? WAS IT AN IDENTICAL REPLACEMENT UNIT?
Jun 22, 2014 | Dometic Rooftop RV Air Conditioner
Corvette troubleshooting
if no air in the system from internal heater or other places
new thermostat and radiator cap
good firm coolant hoses
old school air bleed
you fill coolant system with motor running
heater on in the car and thermostat open
burp the hoses until bubbles are no more
if still no better
what about these possibles
faulty coolant temp sender
head gasket failed
clogged radiator
cooling fans not spinning fast enough
or not coming on soon enough
Mar 20, 2017 | Cars & Trucks
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
Im not getting any heat blows cold air. i changed the thermastat and nothing. it was blowing out hot air in the vent setting but nothing now.
need to check your blend air door located behind the dash on the passanger side, if that checks out good then you have a blockage either in your heater core or hoses to/from the heater core.
Jan 17, 2010 | 1999 Ford Taurus
No Power to Duo-Term Thermastat
Can you give me model #'s of thermostat & AC unit, as well as upper unit? Number of or at least a description of thermostat, and numbers for ceiling assy should be visible when filter taken off, as well as # for upper unit should be tagged on bottom of unit on roof.
Jul 17, 2009 | Heating & Cooling
Thermostat
Heat pump Thermastats have Terminals RYW/OW2 G C. I run into this a lot with people buying tStats at home depot. To wire three sages of heat you must have correct tstat. one stage cool and three stage heat. You have to have enough wires at the Tstat. I use white first stage brown second and grey or black third. Make a diagram where each wire goes. Remember to trun of air handler power or you will short the transformer or blow low voltage fuse. Yellow cool, green fan, most of the time blue is c unless it is a battery tstat. orange is O. Red R ot power wire. Rusty
Jun 03, 2009 | Heating & Cooling
AC Problem
possibly faulty fan or fan relay also check that 24 v are coming out of the transformer
Sep 03, 2008 | Carrier 38CKC036 Air Conditioner
Heating & Cooling Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
