Question about Maytag Neptune MDE5500AY Electric Dryer
Dryer Drum Wont Rotate
I have Maytag Neptune front loading dryer and the drum does not rotate when the dryer comes on. The heater is working fine.
  • 55 Answers
Did you check to see if the belt was not broke? if not possibly the motor went out.hope this helps
Posted on Dec 01, 2008
Drum not going around
Drive belt may be broken or slipped off or your motor brushes may be worn and need replacing.
Dec 27, 2012 | Maytag MAH6500 Neptune Front Loading...
Maytag Neptune Electric Clothe Dryer Model MDE6700AZW Problem: Drum will not turn, no heat produced. When I start the cycle, there is one audible *click* sound and then nothing: no heat and no tumble....
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 09, 2011 | Maytag Neptune MDG9700A Gas Dryer
The beater bar in my Neptune dryer modeL # MED5500AYW has come off and needs to be replaced.
It sounds like you are referring to the drum baffles when you say "beater bar". If that is so, you need to remove the front panel then raise the top cover to access the baffles mounting screws outside the drum. Below is the link to the procedure I posted previously.
Maytag Neptune Dryer Front Panel and Top Cover Removal
Sep 09, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Maytag neptune dryer making banging noise on each rotation on the left side facing the front. its almost like a thumping noise what do i need to do please?
The drum baffle screw has unscrewed itself and the head is thumping against the inside top panel. Pull door, lift lid, rotate drum to find screw sticking out and tighten.
Aug 03, 2010 | Maytag MDE5500AYW Electric Dryer
Maytag Neptune MDE3000 electric dryer replacement of belt
The top comes off then the front panel is next.
remove the drum by pulling it out to replace the belt. replace the tensioners pully as well for it has a bearing that wears out then squeals loadly when old and dried up
Mar 27, 2010 | Maytag Neptune MDE4000 Electric Dryer
Maytag dryer won't rotate after blower wheel replacement
Check the drive belt and belt tensioner. From the way you describe it, the belt is loose and with a load in the drum, it will not rotate due to belt slipping.
Jun 03, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Dryer making vibrating noise while working
a bearing in the back for your drum sounds like what you describe. It needs to be taken apart and the bearing lubricated with high temp grease
Feb 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Changing the drum rollers on a Maytag MDE4000AYW Neptune Dryer..
The instructions above are perfect for most Maytag Dryers, but the Neptune MDE4000AYW is built differently from most. To open it, undo the two screws that run through the door hinges, and remove the door, then undo the two other screws that are on the opposite side of the doorway. With these four screws out, you can lift the front panel UP and out. Make sure you unplug the dryer first :-)
Dec 01, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Change rollers on a Maytag Neptune Dryer
You have to work from the front. Pull the top then the front then you will be able to see everything. Pretty self explanatory.
Loud noise
First, UNPLUG YOUR DRYER! Now open the dryer door and remove the 2 screws at the door hinges... remove the door and set aside, then remove the 2 screws opposite the hinges. Grasp the front panel near the top, just below the top panel and pull it toward you... do this on both sides. Tilt the panel forward then lift it off of the lower clips.
With the front panel gone, you'll see a 5/16" screw just below the top panel on both sides, top left and right. Remove these and the clips too... now you can lift the top panel like the hood of your car.
To gain further access, remove the 6 (3 on each side) screws holding the front drum support/blower vent panel, then set this aside.
If you want to remove the drum... first, take a flashlight and look closely at how the belt is routed around the idler pulley and the motor shaft. (You'll have to re-route it for reassembly.) Reach in there with both hands, with one hand rotate the spring loaded idler pulley back to release tension off the belt, then with the other hand remove the belt from the motor shaft. Now lift and pull the drum out the front of the cabinet.
Check to make sure the rollers in the back rotate freely. You can remove the rollers, buff the roller shafts with emery cloth, lube the shaft with light oil (like sewing machine oil) and reinstall the rollers. Lube the idler pulley also. Rotate the motor by hand and listen for the squeak you described.
Also check the front drum support panel you removed earlier. The drum rides on this as it rotates... As you are looking at the drum support from the drum side, inspect the 10 o'clock to the 2 o'clock area closely. If the glides (teflon) are worn it'll squeak when it rotates.
Hope this helps. Oh yeah! Almost forgot.... the belt won't squeak at all. It'll be the motor, rollers or drum glides.
Nov 02, 2007 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
146 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
