Question about Akai PT4298HD Rear Projection Television
Tv turns off when i turn it on
I have a problem with my 52" akai tv turning off and on. I turn it on then a little while later it turns off can you help with the problem
  • mckenzie6640 Dec 02, 2008
    my akai turned off and it will not turn back on
  • 20 Answers
Do not panic! Do not throw your TV away like I wanted to! Here is whatmay be the solution for most of the members who have posted theircomplaints here recently. I am not an expert, but I followed all blogsfrom various websites and forums, and the conclusion was the same;replace the convergence board for this model. I purchased it fromwww.partstore.com and since this Akai is the same model as a comparable SamsungModel, buy the Samsung comparable Convergence boardfor $77. It came to about $85 after shipping. Call them if you need the exact model #. The Convergence board hastwo black STK ICs and two colors of wires, a gray kind and a blue kind,all which have 'pins' and can easily be unplugged from the circuit boardin the TV. It is basically a complete system that takes less than 30minutes to install. It is a simple swap procedure, with no soldering.You only need the new board and a screwdriver! Remove the lower backboard of your TV where the cables are plugged in (do not unscrew allthe screws for the screen, as it is unnecessary, and might just damageyour screen if you are not careful.) It has a u-like shape and comesoff easy. Detach the gray wires connecting your old board to the restof the circuitry, and detach the blue wires connecting the old board tothe circuitry. On the old board, there are connectors marked, fromleft, blue, green and red. Detach those from the old board, and markthe wires so that you may connect the correct the wires to the newboard. You then unscrew the only screw connecting the board to the TV,and unhook the board from the TV. Hook the new board to the hooks whichheld the old board, and screw the lone screw to the board. Plug thegray cables from the new board to the connectors where the gray cablesfrom the old board were,and do so for the blue cables. Connect themulticolored cables to the blue, green and red, just as was done on theold board. Reattach the cover and test the TV. Please do not replacethe two STK ICs only. When I removed my old board, I realized thatthere was a burn mark, where the ICs were, but maybe it was a fuse. Youmay replace the ICs only to discover that it was another problem. Goodluck, and I wish you all the best in the repairs. I just saved about$100 for a repairman just to show up.
Posted on Dec 11, 2008
Lost the remote to my akai tv was able to turn off and on yesterday i couldn't get it to turn off so i unplged it from the wall later came back home plug the tv back up and now the power light doesn't
Hi Tamara,
Mosty likely when you turned it off from the wall,it must blown the fuse because of the way it was shut off suddenly.
If you can open it up if not than take it to a qualified Tech to get it fixed.
thanks,
G..
Nov 21, 2011 | Akai PDP4294 42 in. EDTV-Ready Plasma...
We have the Akai 52"
Replace the lamp, after you replace the lamp reset the lamp hour meter good day and best regards.
Aug 28, 2011 | Akai PT5492S 54" Rear Projection...
Akai lct2721ad The TV was working fine when we turned it off and now it won't come back on. No red lite. The tv has had very little use. Is there a master power switch that might be tripped. thank...
Check the power source?Yes.Try tv unplug,replug it back an hour later.The tv now resetting it back to factory setting.The tv should work now.Not,than the power supply board is dead.That the board,where the power a/c cord plug into.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacemrnt.
Sep 08, 2010 | Akai LCT2721AD 27 in. LCD Television
AKAI MODEL CFT2716. AT POWER ON TV COMES
AKAI MODEL NUMBER PT50DL24 it turns on then goes off n all th screen says LAMP TEMP WHAT DOES THAT MEAN N WHAT DO I ND TO GET IT WORKING
May 10, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
2002 akai 54in. rear projection tv wont turn on
Unplug,replug the tv back an hour later.The tv should reset itself.More problems repost,see if i can help u.
Feb 20, 2010 | Akai PT5492S 54" Rear Projection...
52" RCA big screen tv turns on and few seconds turns off by itsel
if you heard a hissing or like static sound your board probably has a hole in it now. the board on the left side with the flyback fransformer. the hole is from where a prong has come loose an is arking over an it burns the board the ark is the sound you heard.
Apr 23, 2009 | RCA R52WM24 52" HDTV Projection Television
50" Akai rear proction tv
you may have a short in your poser supply best thing to do is take it to a shop and have them repair it
Sep 21, 2008 | Akai PT4298HD Rear Projection Television
Akai PT4298HD Rear Projection Television Logo
47 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
