We have a Panasonic TX-51P100H that has a convergence problem (rear projection) Tech says convergance processing ic is faulty.Can we source one any where? Any tips/advice Thanks Laurie
  • 1 more comment
  • Soman Dec 01, 2008
    Good day
    Thanks
    I've received your reply
    I've replaced STK 392-040 IC from the section but I've need a convergence alignment, I've open its in service mode but when the cursor on left side right data moving and all line cannot moves proper way.could you please advise me how can i do this or is the convergence processor is faulty?
    TV model no: TX-51P100H.
    Thanks for your reply,
    I've replaced the STK-392-040 but I need to align the convergence.Both top and bottom lines are bent in wards.
    In service mode when the cursor is on left side the data moves on right side and vice verse.I cannot get alignment to move the correct way. Can you please advise me how to correct this or is it the convergence IC faulty.( model: TX-51P100H)
  • Soman Dec 04, 2008
    Top Expert:
  • Televison & ... Master
  • 77,202 Answers
Don't waste your money, the repair will end up costing around $600, buy a new LCD, been there had same problem.
Posted on Dec 04, 2008
  • 4,234 Answers
The fact that the top and bottom are still bowed indicates that replacing the STKs did not resolve the problem. Check the area for resistors that are open (smalll Ohmed resistors that measure high or infinity). Also check that there is a 24V supply going to the STKs. There are many causes of this problem outside of the STKs themselves. Please post the results after you check the resistors and voltage.
Thanks,
Dan
Posted on Dec 01, 2008
    Sergeant:
  • 217 Answers
I got this link from internet which has all the allignment instructions with proper diagrams just check out this link  for alignment problem in tv projector http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
thanks.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your concern over repair of the convergence circuitry of a Panasonic TX-51P100H which is an E3D Chassis would involve:
  • replacement of the two (2) STK392-???;
  • here is an illustrated step by step how-to;
  • it would be to your advantage to buy the repair parts as a kit which include the match pair of STKs plus the resistor. Often the resistors near the STKs also get burned;
  • in some versions, there would be pico fuses underneath or on the board that would also require check/replacement.
  • parts could be sourced from http://servicemanuals.vstore.ca/ who would also provided you with a instruction sheet on parts replacement. Pls look for Slinteriors who is also a member of this site.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
  • Louie  Role
    Louie Role Dec 01, 2008
    The link for the illustrated Panasonic repair, pls try here.
  • Louie  Role
    Louie Role Dec 04, 2008
    Hi again,
    Any updates or developments so far?
  • 4,472 Answers
Yes you can, are you trying to repair this yourself? It is the smartest idea to have the professional work on the television. I would get the service manual and from there you will be able to service the television yourself though I advise a professional.
https://www.manualsparadise.com/ShowProductsForModel.do?model=M74375532
You can purchase the service manual for your television at that link. This will give you all the information you are looking for.
Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
  • 13,433 Answers
This page will guide you on the IC replacement http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
let me know if you need anything else after you have read the page
PANASONICV that now has a "blurred" screen. We can see the channels but it looks like it's has a shadow around the images. The screen in in a red hue with green blur. TX-51P100H 51"...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 29, 2011 | JVC AV-56WP74 56" Rear Projection...
Dear i have a Panasonic Projection T.V Model # Tx-43P800X problem is that in my set all words are showing three time and same time same lines are displaying on uper said ,dwon said .please tell me what...
Ur tv have a problems known as Convergence problems,it dead.The tv convergence board,the 2 STK convergence ICS some or all it resistors are dead.These parts must be changed on the convergence board to solved ur tv 3D like pictures,colors shadows pictures.The shop will cost u $300-350 for parts and labors.
Jun 28, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Panasonic rear projection-red convergence-moves horizontal only!?
The convergence ICs have failed. You will need to install a convergence repair kit. You can get the convergence repair kit for your model Panasonic from www.tvrepairworld.com which contains both of the Convergence ICs , the associated resistors and the cD with detailed repair instructions.
Dec 26, 2009 | Panasonic PT-53WX53 53" Rear Projection...
Picture looks almost 3-D
When convergence out ICs stop working in rear projection TV, picture looks 3D affects.
Need to test/ check supplied volts on convergence out ICs on main board and if volts are OK, replace both ICs.
I'm not sure if you are going to repair TV by yourself or will ask local tv tech to fix it. Let me know please.
Thanks.
Sep 14, 2009 | Panasonic PT-47WX53 47" Rear Projection...
HOW TO FIX CONVERGENCE IC FAULT & HOW MUCH COST APPROX
Panasonic Flashing codes:
1: ----------------- +140 v.
2: ----------------- Low DC
3: ----------------- Convergence
4: ----------------- HHS
5: ----------------- IC 4011
6: ----------------- IC 4018
3 is convergence, either one of the two convergence ICs faulty, or something else (capacitor etc.) has blown on convergence board.
Jul 13, 2008 | Televison & Video
Convergence for Panasonic 47"
Yes it is that set uses the same IC STK392-110 You can get the new ICs at this link and they will provide free installation instructions with pictures as well as free on line tech support instant messaging while you do the repair. heres the link.
Apr 14, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Convergence board
samsung convergence /deflection board has the flyback transformer and convergence ic's mounted on it you change it as a unit and must realign your convergence after if you don't have the service manual call a tech .
Apr 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Panasonic rear projection tv convergence problem
Check the regulator and convergences ICs....accordianman
Feb 26, 2008 | Televison & Video
Red and Green Spots
Not a fix for do-it-yourselfers, but check with Panasonic as there is a new fix. Requires tech to come and reprogram the eprom (I think).
Cheaper than a new optic board.
Jan 03, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
CONVERGENCE ic CHIP
if you can remove the rear panel assy. look for the convergence ic's they start with stk--- and you got the part number you need a source panasonic is 814 source and the number on the ic's stk 390 ----/
Aug 22, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
95 people viewed this question
Top Televison & Video Experts
Electro Med Services...
