Question about Refrigerators
Kenmore refrigerator ice/water in door not working
My ice maker works fine, but the water and ice dispensers in the freezer door stop working from time to time. May stop working for 10 minutes, or 10 days.
  • jmmr108 Dec 19, 2008
    Water is getting to the door. Nothing on the door works. Auger, water, light, nothing. Checked for loose connections between the door hinge and the icemaker board, found none.
    Model number is 253.44513600
    The refrigerator is a Kenmore Elite
    Sergeant:
    Champion:
  • 247 Answers
Welcome-
what type of kenmore do you have (brand and model number)? this way it is easier to find infomation for you.
thanks and happy holidays
Tom
Posted on Dec 19, 2008
  • Thomas Dec 19, 2008
    here is a way for you to fix your fridge:
    Take the bottom kick plate off the refrigerator. The water line comes from the back, and goes up into the freezer door, under the freezer door, or a little under the refrigerator front, should be a quick connect. Pop it off, and then ask for water, and see if it comes out over there. If not, and you hear the valve kick in, in the back, the water tank inside the refrigerator, behind the bottom crisper draws could be frozen. Get a blow dryer, and heat it up, and then see if the water comes out of the tube, that you took off. If so hook it back up, and see if it comes out. When you do take the line off, and the water does come out, the water is frozen in the freezer door. Take the food off of the door, and get a blow dryer, and heat up the inner door liner, and then check it from time to time and see if the water comes out. If either of these work, turn the temp down a little. If this does not work. It will either be the dispenser switch, or the water valve.
    thanks Tom
  • The Slawman Feb 10, 2011
    Or, if your ice maker AND water aren't working, make sure one of your kids didn't hit the lock button before you try ALL OF THESE solutions.....like I did! Doh!
    Genius:
  • 1,847 Answers
Check under your freezer door hinge or kickplate grill in the front, there should be a quick disconnect to take off and see if your getting water at least to your door.
Posted on Dec 01, 2008
  • 91 Answers
There is a sensor that detects if there is ice in the dispensor and also one that senses if there is water pressure, on models about 2 years ago they had a problem with them freezing up, contact kenmore and get the updated parts to fix that problem.
Posted on Dec 29, 2008
    Guru:
  • 449 Answers
From what I can gather your lever to operate the solenoid switch is likely broken or cracked. This happens quite often. Take the front cover off and take a close look. If you can get water to come out by depressing the micro switch the lever should press, you will just need a new lever. If not it will be the switch. Phone the nearest GE parts depot with your model number and they should be able to get it for you. Hope this help good luck
  • Jerry Parmanand Dec 19, 2008
    the micro switch below the fill spout is worn or the lever that actuates it is cracked.
  • 153 Answers
It might be because the door is not closing properly r any loose connection
    Genius:
  • 1,199 Answers
This sounds like a connection check all hoses and conectors
    Sergeant:
    Champion:
  • 338 Answers
Sounds like you have a loose connection in the door for the switch that activates the dispenser.. what is your model number located inside the refridgerator .
  • 1,800 Answers
Check ou this link this might help u out
click here
Kenmore Model 78862891 freezer defrost drain keeps freezing up every month.
It can be issue with water valve its clogged and not letting the water to stop running and that is causing the overflow of water and that is getting freezed and then clogged.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 22, 2012 | Refrigerators
Kenmore model 106.72009010 leaking water onto floor
Defrost is not working and that is causing the leak.
These will help.
Thanks,.
Ice maker kitchenaid super ba is not working . Chilled water dispenses but no water seems to enter ice maker.
These will help.
Thanks,.
Dec 22, 2012 | KitchenAid Superba KSRG25FK Side by Side...
Ice maker stopped working
if the water dispenses from the water dispenser I would say its the. Ice maker control module...try here
www.techray1.com and the link is on the guru guy on the left
Jun 15, 2009 | KitchenAid Superba Architect KSCS25INSS...
Internal water dispenser stopped working
I lowered the temp on the freezer to 4 overnight, by morning water dispenser is working fine. I think that when we changed the temp to 7 (in order to make more ice ) it froze the water pipe going to the dispenser. I am going to keep both fridge and freezer at 5 ,and hope this will not happen again.
Dec 31, 2008 | Amana AFD2535FES Stainless Steel Bottom...
ICE MAKER NOT WORKING
Check to make sure you freezer is at 0 to 5 degrees. If it is not the water valve to the ice maker will not even open.
Nov 20, 2008 | Kenmore 53642 / 53644 Side by Side...
GE GSH22SGRE - water dispenser not working but ice cube maker working fine
check the water valve on the back of the ref. it sends water to the ice maker and water in the door one can work and the other one not
Apr 30, 2008 | Whirlpool ED2FHEXN Side by Side...
Kenmore Refrigerator stopped dispensing water
Look up through the ice despencer on the front door of the freezer. Is the flapper door open? If so it needs to be fixed. If its not then try leaving the freezer door open for 3+ hours to defrost the frozen line in the door. If that doesnt work, the water valve must be changed.(located behind fridge, take off back cord board panel at bottom, the valve is blue)... GOODLUCK!
Dec 31, 2007 | Refrigerators
Either your water tank in the fridge froze up, the waterline that goes up the freezer door from the bottom hinge froze, or the switch that your glass hits is damaged. Do you hear any humming or noises when you put your glass up to get water?
Oct 27, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
1,773 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
