Matches 1 - 50 of 280 - Finding Honeywell Portable Generator Parts is simple with our online parts diagrams: 1. Click on the section of the machine for which ...
Is there B+ voltage on the heavy gage wire on the back of the alternator ? Possible blown fusible link. Plus the two wires in the connector go to the PCM - engine computer . One is the turn on signal ,the other is charge indicator control . Having the vehicle checked for DTC'S - diagnostic trouble codes should also be done .DTC P1637
The powertrain control module (PCM) uses the generator turn on signal circuit to control the generator. A high side driver within the PCM allows the PCM to turn the generator ON and OFF. When Generator operation is desired, the PCM sends a 10 volt signal to the voltage regulator via the generator turn on signal circuit. This causes the voltage regulator to begin controlling the generator field circuit. Once the Generator is enabled by the PCM, the voltage regulator controls generator output independently of the PCM. Under certain operating conditions, the PCM can turn Off the generator by turning Off the 10 volt signal on the generator turn on signal circuit. The PCM has fault detection circuitry which monitors the state of the generator turn on signal circuit. If the fault detection circuit senses a voltage other than what is expected, this DTC will set. The voltage regulator also contains fault detection circuitry. If the regulator detects a problem, the regulator will ground the generator turn on signal circuit, pulling the voltage low. This also causes the PCM to set the DTC.
Your best bet mite be to take it to a qualified repair shop.
Most likely your Generator has failed or you have a battery connection isssue.But based on the info you provided it sounds like the generator.You need to remove it or take the car somewhere & have the charging system tested.hope this helps
