Question about Epson Stylus CX6400 All-In-One InkJet Printer
Epson cx6400. Red exlamation light is on and Printer error.
Cycled power and checked each ink cartridge. Checked for paper jams.
Display also says to contact customer service.
Any ideas as to what to check for now?
Thanks for your help.
  • JodiBW Apr 13, 2009
    I'm having the [Printer error] message too. My son was hitting the buttons, nothing more than that, and I can't get it cleared by powering down. Could you provide me the software to reset the printer jacklee366?
  • Epson Master
  • 541 Answers
This means the wast pad is full and the printer needs to be reset let me no if you need the software to reset dont forget to rate
thank you
Posted on Dec 01, 2008
Epson Stylus PHOTO R220 red lights keep flashing
I hope this will help you :)
* Green Power light flashes- The printer is receiving a print job, replacing an ink cartridge, charging ink, or cleaning the print head.
* RED paper light is On- If the CD/DVD try guide is open, close the CD/DVD tray guide, load paper, then press the paper button. Your paper ran out or multiple sheets loaded at the same time . Load paper and press the paper butoon to resume printing.
* RED paper light flashes- Paper is jammed in the printer. Press the paper button to eject the jammed paper. If the light is still flashing , open the cover and remove all paper, including any jammed or torn pieces. Then reload paper and press the paper button to continue printing.
* RED Ink Light Flashes - One or more cartridges are low on ink. Check the message that appears on your screen to determine which cartridge is low, or follow the instructions in " Checking the Ink Supply". Make sure you have a replacement cartridge.
* RED Ink Light is ON- One or more cartridges are out of ink or not installed. If you have just installed a new cartridge, it may be incomaptible with the printer or incorrectly installed. Reinstall it or replace it with the correct cartridge
* RED Ink and RED paper lights flash alternately- The CD/DVD tray guide was left open when you turned on the printer or when printing on paper. Just simply close it/
* Green Power Light is Off; RED paperand RED Ink Lights flashing- Paper may be blocking movement of the print head. Turn off the printer, then open the cover and remove any jammed paper or other foreign objects. Turn the printer back on again. Or it may have an internal error. Turn off the printer, wait a few seconds, then turn it on again.
Jul 06, 2011 | Epson Stylus Photo R220 InkJet Printer
My r230 is having this trouble: the two red lights are blinking.
If the Ink Out light flashes, the printer is getting low on ink; if it is on solid, the printer is completely out of ink and you need to replace the cartridge; if it is flashing rapidly, the printer detected a print head unit or ink cartridge installation error. If the Paper Out light is on solid, you need to install paper in the printer; if it is flashing, the printer detected a paper jam. When both the Ink Out and Paper Out lights are on solid, the printer thinks that there is a carriage error; if both lights are flashing, there is a fatal error and the printer will need to be sent in for service Source(s): http://www.epson.com/cgi-bin/Store/suppo...
Mar 06, 2011 | Epson STYLUS R230 InkJet Photo Printer
Epson r230
Nov 02, 2009 | Office Equipment & Supplies
Epson CX3900 printer indicates paper jam
Check the paper road and paper sensor.Probably have a piece of paper or something else in the printer.
Sep 29, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Our printers epson c42ux red light is on stand still
A permanently on red light can mean several things. If the green light is also ON, it means that you heve no paper loaded, an empty or faulty ink cartridge, or a jammed paper feed. I presume you have loaded paper. You say you have changed the ink cartridges. Note that BOTH cartridges must have ink for the printer to work. The simplest way to check this, or to check for a faulty cartridge, is to try another new set of cartridges - compatible cartridges are very cheap on EBay - about £3 a set in the UK.
To check for jammed paper, remove the paper from the sheet feeder and look carefully inside it, and inside the printer (lift the lid) for scraps of jammed paper. Remove any you see. Press the ink/paper feed button and see if it goes through a paper feed cycle. Reinsert the paper and try it again. If it works, turn the printer off and on again, and it should now be OK.
If the green light is OFF, it means you have a Carriage problem, i.e. something is fouling the print head when it tries to go from side to side. Check this with manual movement. Turn the printer off. After a few seconds, turn it back on again. As soon as the print head moves, pull the power cord out of the back of the printer. You should now be able to move the print head across to the left side (gently!) by hand, then move it back to the right and see if it will go fully into its parking bay at the right hand end. You should be able to tell if someting is hindering its movement anywhere.
Please report back with a new comment if none of this solves the problem.
May 31, 2009 | Epson Stylus C42UX InkJet Printer
Nothing prints out on paper.
Did you remove the little sticky tabs from each new cartridge? They allow air in, and ink out.
May 31, 2009 | Epson Stylus CX6400 All-In-One InkJet...
Epson CX7450 paper jammed
In some cases, this is cause by a nozzle that got clogged during the jam. You can run head cleaning utility either from the printer or from the computer.
1. Make sure that there are no error lights (red lights), just a solid green light.
2. Take out all cartridges from the printer and put them back in.
3. Once the printer is done charging the inks and you have a solid green light again. Hold down the Ink Button for 3 seconds, after this you'll hear movements within the printer, this is the head cleaning process.
4. Once the printer stops making noises, and you have a solid green light again. Power Off the printer
5. Once the unit is OFF, hold down the paper button while turning the printer ON. Once you see the blinking green light release BOTH buttons. The printer will then print the nozzle check pattern.
* Note: The nozzle check pattern should display all colors in the printer and there should be no gap or break between the lines itself.
6. Do this step 3-4 consecutive times. and that should resolve you concern
Feb 21, 2009 | Epson Stylus CX3200 All-In-One InkJet...
Not workin'
I assume you've checked and done all the basic things like a power down and power up reset and checked to make sure all the ink cartdridges are properly installed and seated.
The user manual discusses your error message and suggests you do the following: Open the scanner unit to make sure any tape securing the ink cartridge holder has been removed; close the scanner unit/ press the ON button to turn off the CX6400, then turn it back on . If the error message still appears, contact your epson dealer or Epson tech support. If so,then you may want to get direct support and information from Epson at this website : http://er.epson.com:8001/start?TM=false&CMD=iSearch&CB=1886098358&LG=1&TP=NoviceCase&Q1-1-1886170412=1886170410&FI=1&firstQuestionID=Q1-1-1886170412&firstAnswerID=1886170410&category=allinone&model=cx64__&displaymodel=Epson+Stylus+CX6400&referralmodel=Stylus-CX6400&restart=yes
Technical Support line_dkblue.gif spacer.gif United States Phone Number:
(562)276-4382
Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT) Canada Phone Number:
(905)709-3839 Hours: Mon.- Fri. spacer.gif 6AM-6PM (PT)
Sep 23, 2008 | Epson Stylus CX6400 All-In-One InkJet...
EPSON R230 PRINTER
ONCE PRINTE COMMAND IS GIVEN PAPER IS ROLLED IN AND THEN PAPER JAM RED LIGHT BLINKS. CAN NOT PRINT ANYTHING.BUT NOZZLE CHECK PRINT CAN BE PRINTED.
Jul 23, 2008 | Epson Stylus Photo R200 InkJet Printer
Help Epson CX3200
I just like to ask to where specifically you can see the red light. It will help us determine what cause the red light. To give you heads up as well, the Printer's LCD screen can help us determine what exactly the offline condition of the CX3200 is:
Error message: No color or black ink cartridge-->Press the Color Copy button to install a new ink cartridge.
Solution: The indicated ink cartridge is not installed. Please install the necessary cartridge(s).
Error message: Color or black ink out -- >Press the Color Copy button to begin replacing the ink cartridge.
Solution: The indicated ink cartridge is out of ink. You will need to replace the necessary ink cartridge(s).
Error Message: Ink cartridge error -- > Press the Color Copy button to begin replacing the ink cartridge.
Solution: There is something wrong with the ink cartridge. Make sure the cartridge is genuine Epson ink. Also, try reseating the cartridge (remove it, and then reinstall it).
Error Message: Paper jam or misfeed -- > Press the Color Copy button and clear the paper jam by hand if necessary.
Solution: Paper is jammed. Check for any obstructions under the unit's cover, and in the paper tray.
Error Message: Paper out -- > Load paper in the sheet feeder and press the Color Copy button.
Solution: Load paper in the sheet feeder, and then press the Color Copy button to continue printing.
Error Message: Scanner unit open -- > close the scanner unit
Solution: Carefully close the scanner and press it down until it clicks securely into place.
Error Message: Scanner error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Unlock the transportation lock, if necessary. If it is already unlocked, toggle the lock back and forth, 5-10 times. Turn on your Stylus CX3200 again.
Error Message: Printer error -- > See your documentation and call service if necessary.
Solution: Press the ON button to turn off the Epson Stylus CX3200. Disconnect it from power, and then reconnect it to power. Press the ON button to turn on the Stylus CX3200.
May 23, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Epson Stylus CX6400 All-In-One InkJet Printer Logo
1,405 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
