Question about Sanyo DS31590 31" TV
White line thought the screen
I have a sanyo mts31590 I was reading someone else problem with the same thing we cannot locate the heater pack or what ever it is called if yo ucan help me locate it that would help a lot or give us the number thatnkyou for your time.
  • Sanyo Master
  • 5,138 Answers
Replace vertical IC also 100uf 35v cap ,1uf 50v 2.2uf 50v and low ohm resistor.
Posted on Dec 01, 2008
My 55in Sanyo has white lines top to bottom of the screen the color of the screen changes while cable is on and then turns black with big white and blue lines in the middle when jst the tv is on
T'Con board fault.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 18, 2015 | Sanyo Televison & Video
I have a 55in Sanyo flat screen when I turned it on today the picture went light orange with white line over entire screen top to bottom then screen turns white with lines but has good sound plz help
T'Con board fault. Replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Where is the heater/ac fan resistor located on a 1999 vw beetle
Attached to the blower motor is a device called the Resistor Pack...
It has a 4 wire connector...Wire colors are...Yellow...Green...White/Blue...And Blue.
Inside this resistor pack is a fuse. If you use an ohm meter.
One probe on Yellow wire and other on the Blue.
If it reads "open" the resistor pack is defective.If you read resistance
the pack is Good. Main power to the circuit is supplied via fuse #25 (25A) located in the under-hood fuse box. So simple answer is .The blower motor resistor is located close to the blower.
Let me know.
Dec 28, 2011 | Cars & Trucks
The film on the inside of the microwave oven door has bubbled & is raised off the glass. Is it safe to use.
No, that must be patched or replaced. It's critical.
The film protects the door screen from getting food, grease or moisture in it, which can lead to corrosion and arcing.
The screen prevents microwave energy leakage, which can cause arcing and fire.
If the bad spot is not too big, you can cut it away and clean it squeaky clean and patch it with clear packing tape.
If it's too bad to patch, you'll have to see if you can get new film, or if you need to order the inner door panel or whole door.
You can locate Sanyo manuals, part distributors and authorized servicers here.
You can find Sanyo UK microwave owner's manuals here. You can find Sanyo UK support, parts and authorized servicers here.
Oct 29, 2009 | Sanyo Microwave Ovens
We need to know a repairer to fix our microwave which made a noise and then would not heat up any more, we live in Midland W.A.
I would suspect that your high voltage rectifier diode has shorted.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html
Your local Yellow Pages should also list a servicer, but you may need to look under Appliance Repair.
Sep 13, 2008 | Sanyo Microwave Ovens
25 inch sanyo tv
If the horizontal lines going through the picture are fine white lines, then I would suspect the picture tube as having a heater to cathode short or some other problem. Since some sets have had a 3 year warranty on the picture tube, you may be lucky unless the labor to replace the tube is more than the set is worth. Sanyo is usually not a good name in consumer electronics anymore, so if you're looking for a replacement I would look elsewhere.
Mar 31, 2008 | JVC AV-32F704 32" TV
Orion TV model TV_798 sl (thin line no picture)
problem is with the vertical output circuit. take it to a repair shop and have them fix it.
Sep 15, 2007 | JVC AV-27D302 27" TV
SCP-7050 screen reads backwards like a mirror image
I had the same problem with my phone, had it fixed once under warranty a few months later had the same problem. They told me it would cost a fortune to fix, I was about ready to give up until i examined the phone a bit further, it seemed as though the contacts on the battery were somewhat worn, I simply packed some paper between the battery case and the top of the battery, seemed to fix the problem for now.
Aug 03, 2007 | Sanyo SCP-7050 Cellular Phone
Sanyo DS31590 31" TV Logo
53 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Jerry Greenberg
Jerry Greenberg
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
