Question about HP Computers & Internet
The wireless lan on hp pavilion media center pc is getting a low signal one bar out of five. How do I determine if its the antenna or the 802.11 card that is faulty?
  • Casey
    Casey May 11, 2010
    How far does the signal have to travel in order to get to your HP? Also, through what does it have to travel?
    Try moving your hp if it isnt to much of a hassle.
  • Enrique Torres
    Enrique Torres May 11, 2010
    The real questions are as follows:
    1. How far is the PC from the wireless source?
    2. What kind of construction is between the wireless source and the PC(ie sheetrock, brick, wood, steel)?
    3 Also are the wireless router and card compatible (ie is the router a wirless B and your card a wireless G)?
    4. Were you previously getting a better signal? if so what has changed since you are now getting a lower signal.
    Might consider getting a signal booster
    Scholar:
  • 81 Answers
Move either the router or the pc around. If this is a personal wireless you can buy or make antenna extenders to increase the range. You can also try a different firmware like dd-wrt which allows for greater control of the wireless.
Posted on Dec 01, 2008
Wireless internet is always poor
If you have a laptop you may need to check your wifi cards antenna connection, Or you may need to replace the wifi card or get a USB wifi card they are relatively cheap.
Jun 21, 2012 | Compaq Computers & Internet
Why is my signal stength very low?
Sounds like you need a new wireless card in the one that shows low signal strength. You can buy a good usb wireless card that gets a great signal for less than $30.00
Mar 26, 2012 | HEWLETT-PACKARD Pavilion p7 Quad PC 25 GHz...
Have a dv6-136 1sb hp pavilion Entertainment pc. i am able to access the internet via wireless internet access when i am close to the router. however when i go three rooms away i get no internet access. at...
The issue here may not be the laptop but the router strength of it's wireless radio. Do you have another laptop or a freind who can come over and test his connection? The DV series laptops have pretty decent antennae and wireless cards. Try to update the drivers for the WLAN card, make sure the antennae leads have a good secure fit at the ends where they attach to the card. If the router is a couple to several years old, it may need the firmware updated.
Jul 05, 2010 | HP Pavilion dv6000z Notebook
To my HP Pavilion Media Center A1430N, I lost ALL video signal
Hi:
One quick thing to check is to see if your Video card is fully seated down in the motherboard? Sometimes they can pop up a bit, and you lose your output.
If that doesnt help, you could remove your memory, one stick at a time, to see if that helps. This could be the cause if you added memory from the old computer.
Oct 30, 2009 | HP Pavilion a1430n (ER900AA) PC Desktop
I keep losing the internet signal and going offline. LAN indicates pending??? How do I perform a system reset with Linux??
Power cycle the system by shutting it down and switching it on after at least thirty seconds. Check network settings to verify the IP address and other related information. Determine if the network card is working adequately. Identify the malfunctioning adapter by disabling the cards one by one. Move one of the portable hosts--such as a laptop--closer to the router. If it works better, interference or low signal strength is the reason for poor Internet access. Inadequate signal performance can be caused by several factors including cordless devices working within the frequency range (2.4 GHz) of a wireless network, shiny surfaces and too much distance between hosts and access points. Resolve this issue by using a wireless repeater?a device that amplifies wireless signal so it reaches distant areas within the premises. Minimize signal interference by maintaining a distance of at least one meter between cordless devices and the router. Alternatively, buy gadgets that function at frequencies other than 2.4 GHz. Try changing the WiFi channel for better results. Check the functioning of wireless router and access points. Adjust the router antenna to get an optimum signal. Most wireless routers come with omni-directional antennae to send signals in all directions, a situation appropriate for a square-shaped network. If hosts are arranged in a linear fashion, use an antenna that sends signals only in one direction. Some portable routers have internal antenna, giving more freedom to users who are on the go. Use an external antenna with such routers. The market now offers antennae with varying strengths, implying some are more powerful than others. See if using a more powerful antenna fixes the problem. Aside from increasing the range of transmitted signals, the reception capacity of hosts can also be enhanced. External WiFi-enabled antennae attached to laptops are now available for this purpose. Change the location of the router and access point. They should ideally be placed centrally between all computers. As the signal bounces off smooth and shiny surfaces, routers and access points should be placed away from windows, doors, mirrors and other metallic surfaces. Examine signal performance by using the monitoring utility that typically comes with the access point. Check that the devices show correct lights. Device lights are an indicator of accurate connections. Different lighting patterns indicate different things. For example, some network cards show green light on successfully establishing a connection. Similarly, the router's wireless LAN (WLAN) light is turned on at all times, even if no device is connected to it. Further, this light blinks when a host communicates with another host. Unexpected lighting indicates a problem. Go through user manuals to get familiar with this feature and make sure the devices show desired lighting behavior. Use wireless Internet utilities to check the SSIDs and channels neighboring wireless networks are using. Change your network's SSID and/or channel if they are the same as that of other networks in the vicinity. See if correct drivers have been installed. Check configuration settings for encryption keys.
Sep 24, 2009 | ASUS Eee PC 2G Surf Notebook
WHAT PCI CARD TO GET WIRELESS INTERNET ACCESS ON
You can get this adapter from Linksys its WMP54G so you can make the computer wireless, but you can also check some adapter from Ntegear , Belkin and Dlink...
Aug 16, 2009 | HP Pavilion 734n PC Desktop
SEARCHING FOR WIRELESS LAN
get the model# for ur wireless card
Apr 23, 2008 | HP Pavilion dv6000z Notebook
Lost internet on my desktop which uses wireless lan card and antenna to connect to linksys wireless g
Just a question, did your girlfriend accidentally kick your computer off the network by accident?
Mar 23, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
