Panasonic Lumix DMC-TZ3 Digital Camera
Problem for Panasonic Lumix DMC-TZ3 Digital Camera
Lens inside dirty
By ptse on Dec 01, 2008
lens inside dirty
Same Problem
Jan 05, 2009
-   Camera fell into water, got it all clean now but the lense is dirty and fogged from the inside. How can I take the housing apart?
-   philipwal
Solution #1
posted on Nov 05, 2009
Not Rated)
dupalopez
Rank: Guru  Panasonic Expert
Rating: 94%, 18 votes
Unfortunately you would need to strip the lens completely to get to all glass elements inside to clean them. This is fairly fiddly operation and although I rate TZ3 lens as one of the easiest to dismantle I wouldn't recommend it unless you're really really comfortable with fiddly stuff. Actually, it's easy to take apart-putting it back together is more tricky - I learned the hard way :)
I would suggest getting a TZ3 with e.g. a broken screen from ebay and use it as a donor to get working lens and replace the one on yours.
Unfortunately I don't think there's an easy way to fix this.
Good luck,
Raf
Was this helpful?
Yes
No
Solution #2
posted on Jul 13, 2009
Not Rated)
Hacklet
Rank: Master
Rating: 91%, 4 votes
Well... The service manual is here:
http://tsn.pasc.panasonic.com/viewing/ALL/DMC-TZ3P/SVC/DSC0703019CE_PRINTB/DSC0703019CE.pdf
before you do it, can I suggest popping the end of a shop vac over the lense as it is pulled out and seeing if that helps at all? It probably won't but it's a lot easier than pulling this to pieces, especially since the lense is not that accessible.
I wish you luck, it's not a fun task!
Was this helpful?
Yes
No
Popular Solutions for Panasonic Lumix DMC-TZ3
Questions and Unsolved Problems for Panasonic Lumix DMC-TZ3
Do you recommend Panasonic Lumix DMC-TZ3 Digital Camera?
Answer
Answer
After being dropped, shutter will not open & close. Can you buy a shutter part? Camera... (More)
Answer
ring around the lense is bent and lens won't telescope open anymore
Answer
The shutter is not opening all the way....so you see dark edges on the pictures. What should I... (More)
Answer
I lost the PHOTOfunStudio CD for my DMC-TZ3. Where could I get that?
Answer
Panasonic Lumix TZ3. I can´t find pictures. About 25 of them are missing but when I tried... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Panasonic Lumix DMC-TZ3...:
Top Digital Camera Experts
Rank: Guru Guru
Solutions: 761
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Digital Camera Experts
Top Camera & Camcorder Repair
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
(915) 239-6199
CamerasAndParts.Com Specializes in the Service /...
CamerasAndParts.com
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
