Trying to find a replacement 'Winfast mainboard secondry fan (A small thing) I got back to my pc that was left on & BSOD was displayed. Upon trying 2 restart it stops booting just before detecting hadrd drives. The bios had reset itself & the small fan in question struggles 2 spin. Often it spins a few seconds then stops.
  • 2 more comments
  • doomkinguk Dec 01, 2008
    The fan is on the mainboard just under the pci-e graphics card. Looks like an inch squared. It's a Foxconn Nforce board. 300+amd 64. I run Xp pro with SP2. Running a sli-tv tuner hybrid card & 3 IDE dricves, 2 SATA's & my doptical combo.
    Thank you Howardepgco :) Just wondering if anything has overheated too much? If so a new fan wouldn't fix the problem. Wonder what the damage is? Thanks again.
    Thanks Howardepgco but the fan doesn't sit on the heatsink but slots in the heatsink. It cannot be high profile as my GeForce 6600 SLI 256mb pci-e graphics card rests avove it!
    It's definately on the board. It's not the cpu fan (which works well) or on the graphics card. The heatsink got very hot & after BSOD screen i wonder if anythings overheated? It posts up to just after memory check ok. Just the familiar bios alteration beep then that's it.
  • Howard Lester May 11, 2010
    Is the fan on your video card or processor?
  • 341 Answers
That's a chipset fan and cooler. I found a good one on Newegg and it's only 7 bucks and it's a brand name no Chinese junk.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103155
Posted on Dec 01, 2008
  • Howard Lester Dec 01, 2008
    Yeah I wonder too.Maybe a motherboard is a good idea. That chip could give you lots of grief later on if it got too hot.
My computer's mainboard is ASUS M4A785T-M; Whenever I'm trying to boot the computer it gets stuck on boot logo. Its a green color screen on which the mainboard model no is showing (M4A785T-M). Again s
Try this solution, you have the Blue Screen Of Death (BSOD), which you cannot see on a green screen. It can be caused by a setup problem on the motherboard if you are sing SATA drives.
ASUSTeK Computer Inc Support
The same site gives details of the motherboard.
Oct 02, 2014 | Computers & Internet
Screen goes blank
This is most probaby because of a loose display cable connection .As the cable runs through the hinge slot to the mainboard of the laptop, open the laptop full and try pressing carefully on the left side of the laptop near the hinges area. this should give you the display back.
Mar 18, 2014 | ASUS Eee PC 1005HA-PU1X-BK Netbook
Turn on my computer, I can hear the fans, no beep noise upon starting. Screen says no signal found. I tried other monitor cables and monitor. No dice.
one of 2 things is happening a) if you have changed the cord and tried other moniters then the display port beit vga or dvi on you computer is broken you will either if you have agraphics card already installed then replace that but if you have no dedicated grapichs card you need to replace the mother bord
B) check your moniter to see if there is a source button if there is then push it to see if the image comes up repeat up to 3 times
ps: if you have a dedicated graphics card look at the back of you computer and if there are 2 different display ports be it dvi or vga (google image the terms "vga port" and "dvi port" to see what they look like) then plug it into the other on to see if the graphics card is broken
May 02, 2011 | Sony VAIO PCV-RZ56G PC Desktop
I recently had the water pump replaced which works great but ever since I have had a problem with the engine cutting out and then not starting. My mechanic just replaced the ignition sencer which helped...
You could try replaceing the fuel pump relay at least test it chevy has a strange disign with there fuel pumps relays and some times its back upper by the oil pressure unit as a secondry power supply for the fuel pump
Jan 12, 2011 | 1993 Saturn SL2
Pressing the start button the fans run and the keyboard lights momentarily after 2/3 seconds the fans stop the computer does not start Dell Optiplex gx270 I have the same problem with Phillips MT2400
first, try to replace keyboard. if not work try reformat the system and if still not work, there is a problem in mainboard maybe short circuit then replace mainboard.
Oct 10, 2009 | Dell OptiPlex GX270 PC Desktop
Gateway notebook problem
Black Screen of Death - BSoD Black Screen of Death or BSoD computer dictionary definition and information.
Dead or black pixels. Information about dead or black pixels on a lcd or computer display. ... Determining how many dead pixels are on the screen.
Good Luck, Please dont for get to Vote/Thank You.
Dec 22, 2007 | Gateway 450ROG Notebook
BEGINNING DUMP OF PHYSICAL MEMORY
Hi, Normally a blue screen of death (BSOD) with memory dump is indicative of a fault in the: Hardware- 1. Possibly memory; 2. video; or 3. motherboard. In some instances, Software- a. Drivers; or b. the Operating System itself. You may want to check the memory installed in your laptop. Some versions have them underneath the keyboard while most would have it at the bottom covered by a lid/plate secured with 1 or 2 small screws. The memory will spring out if you unlock the two side clips. You need to clean the little gold contacts with a pencil eraser. Re-insert back securely and try again. If the above does not correct the BSOD, you may need to replace them. Hope this be of some help/idea. Post back how things turn out or should you need additional information. Good luck and kind regards.
Oct 04, 2007 | Compaq Evo N110 Notebook
Computers & Internet Logo
41 people viewed this question
David Payne
David Payne
