Question about Magic Chef Ovens
Contune to beep F-1 flashes
Magic Chef Stove model # 3468xra-x Serial # 14c328098725 I can't find my manual does this mean when it beeping
    Sergeant:
    Champion:
  • 338 Answers
F-1 codes are usually a temperature issue. you should try ohm'ing out the temperature probe you should have about 1260 ohms. if you are off by 40 ohms then replace the temperature probe. if it is close then you may have a bad control.
Posted on Dec 01, 2008
C clock will not stop buzzing. 15 year old magic chef oven. do not know model number because manual does not identify it. the only thing I have is a number at the bottom of the installation manual. Not...
Beeping from ovens is an indication of function buttons in user. Observe the entire feature function either as cooker still in operationality where beeping is warning as haven been completely secured from functionality. Refer with an expert with condition over impressive.
Mar 01, 2011 | Magic Chef Ovens
My oven will not stop beeping F 1. It's a Magic Chef wall oven. Electric
Hi
Thanks for using FixYa. Error code F1 means failed thermistor/transistor in control. To resolve this issue you'll have to replace the Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 08, 2010 | Magic Chef 9815 Electric Single Oven
MCO160UQ magic chef oven how to mute the beeps
Sep 05, 2010 | Magic Chef Ovens
Error code F1 flashes and beeps on control panel
Hi
Error code F1 means a faulty keypad or connection problem with the keypad. You will need to check the connections of the keypad with the main board. Pressing Start/Cancel key may temporariliy resolve the issue, however, to resolve the issue you might need to change the keypad if the wiring to the keypad seems ok.
1. Disconnect power to oven.
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
If it still shows as F1 then you'll need to replace the keypad.
Hope it helps...
Daniel
Aug 13, 2010 | Magic Chef Ovens
We have a Magic Chef glass top electric oven and the past few nights it has been beeping and showing a F-1 on stove top area
Hi
Thanks for using FixYa. F1 error indicates that the touchpad membrane is defective. To resolve this issue you’ll have to disconnect the ribbon strip: after disconnecting if there is no fault code then the membrane should be replaced, if the fault code still appears then the control board should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 08, 2010 | Magic Chef Ovens
Our magic chef oven starts beeping and gives us a F1 on the display
f1 indicates a shorted touch pad ,if you want to make sure ,unplug unit ,disconnect touch pad from computer board ,if f1 goes away touch pad is bad.if not replace board
Sep 13, 2009 | Magic Chef 9815 Electric Single Oven
My magic chef oven flashes F-5 when we try to turn on the oven!
Hi
Thanks for using FixYa. Error code F5 means Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC)
ERC - Electronic Range Control. Watchdog - a combination of hardware and software which acts as an internal scheme, disconnecting the systems output from the process in the event of a malfunction.
Turn off the Oven for 2-3 hours, the oven will reset itself. However, if the error still persists then follow the procedure to troubleshoot the error code--
  • Disconnect power to stove
  • Gain access to the back of the clock (electronic range control or ERC).
  • Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
  • Make sure everything is clear and will not short out when power is turned back on.
  • Turn power back on to stove.
  • Watch for the F5 and listen for the beep.
  • If you get the F5 and beep, replace the ERC.
  • If after approx. 30 minutes you do NOT get the F5 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks Rylee
Sep 13, 2009 | Ovens
I have a majic chef oven, when i turn it on it beeps and flashes
Self clean on some older models can cause some issues. F-3 is a sensor error. This could have been damaged by high heat or in some cases if the sensor is ok, the control doesn't know it's there.
Mar 14, 2009 | Magic Chef 9815 Electric Single Oven
I just got a used stove and its a single magic chef eletric stove. when I plug it up it will beep and on the display screen it says L1. what does that mean. im not sure what model it is though. its a older...
Usually L1 is a code for power on. So try to clear it by pushing enter or clear and see if it helps.
Please rate me accordingly if this helps and good luck.
Mar 13, 2009 | Magic Chef 9512 Electric Single Oven
"F1" error code on Magic Chef gas range Model 3488XRA
the burners on my magic chef stove work but the flame is not as high as it should be on one burner. I switched the top of the burner with another and it did not solve the problem.
Jan 03, 2008 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
112 people viewed this question
Top Magic Chef Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
