Question about Dishwashers
Dishwasher not cleaning dishes good
I have a kenmore dishwasher . i usually will rinse my dishes off very good then place them in the dishwasher it still seems like its not cleaning them very good. What do i do?
    Sergeant:
    Champion:
  • 338 Answers
Ok in the dishwasher you will see you lower spray arm. take it off. now going up the back is the supply tube. you need to pop it off of thed top then the back and turn it clockwise to get it off the motor. after you do that you will see 4 torx screws. take all 4 out and you will be able to remove the fine filter. thats the normally grey piece with all the slots. after you remove the filter you will see two more torx screws. remove them they are for 2 seperate pieces one is the foreigh food seperator and the other is the chopper cover. remove both of them and clean the whole thing out. as yiou are puytting it back together. let me know if you get stuck
Posted on Dec 01, 2008
If it is a cheaper brand/model of dishwasher, you may have to rinse the dishes, especially if they have been sitting for a while. While there are dishwasher who are powerful enough to clean even crust off the dishes, most need to have the dishes rinsed off even just with cold water right after use....If you do not use alot of dishes per day and let the washer build up dishes after a few days then I would recommend a warm/hot water rinse even with a dish sponge and some soap. While some may think that this defeats the purpose of using a dishwasher, remember that a dishwasher is more sanitary that using a dish rag or sponge that had the opportunity to build up bacteria and other gunk over a period of time ;-)
Aug 28, 2013 | Kenmore Dishwashers
After dishwashing everything has a film on it.
I often get calls similar to this client: Over the past several weeks-months, have been getting a whitish film/deposit on pots, tops of some plastic cups, etc. You don't really see it on plates.
Typically this is caused when someone switches detergent usually to a liquid gel. It is almost always because we use too much soap.
One of my most appreciated recommendations follows:
My suggestion is to throw the liquid away and use the Cascade Complete or Finish tablets. Place one in the bottom of the dishwasher. Do not put them in the dispenser.
The reason for this is you want the soap (abrasive) at the front end of the cleaning process so that the last little bit of food that is left on the dishes (I'm assuming you are rinsing your dishes) is blasted off and then the dishwasher can "sanitize" the dishes with water that is too hot for you to handle. That is the real purpose of a dishwasher.
Keep in mind that if you rinse your dishes well before placing them in the dishwasher you can probably use the shortest cycle and save quite a bit of money on electricity and water over the course of a year.
Also, take a coffee cup and fill it half way with white vinegar and place it upright in the top rack with your next load of dishes. Do this for the next several loads and then once per month for as long as you own and use a dishwasher.
Sep 12, 2011 | Kenmore Dishwashers
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Dirty cups and baby bottles after dishwasher has been run
Hi and welcome to FixYa I am Kelly. One of the biggest causes of the symptom you describe is that there is a partial blockage of the drain. The blockage areas are most often in the "Air Gap" A device that looks like an inverted 5 oz Dixie cup on the back of the sink with no cone shape. Food particles collect in the very top of that and slow down the drain process. Because of that the dishwasher doesn't completely drain between cycles. So what you get is recycled previous cycle water in the rinse.
Other places where blockages occur are at the garbage disposal side inlet hole. And the last place is under the wash arm tower / mini riser in the pump impeller outlet area. To clean under the lower wash arm riser it requires diassembly and a good memory of how everything came apart / goes back together when your done cleaning.
Apr 18, 2010 | Kenmore 24 in. 17032 Built-in Dishwasher
Dish washer \does not rinse good leaves white flim
Hi:
Some things you can do to try to improve your dishwasher's performance:
1) Make sure your dishwasher rinse agent dispenser has rinse agent in it. The filler is usually close to where you put soap in the dishwasher.,
2) Consider switching brands of dishwasher detergent, if you are experiencing problems. Depending on the water condition in your area, certain brands work better than others. Ask your neighbors what works well for them.
3) try different wash cycle's with your dishwasher. Sometimes the economy cycle doesn't work as well as it should.
Dec 17, 2009 | GE Dishwashers
Our Kenmore dishwasher leaves a fishy odor on dishes
Go to Walmart gets some DISHWASHER CLEANER....works great...also clean out both screans and the water arms have holes...clean them out with a tweezers.
Sep 20, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Dishes not clean enough. as if rinsing in dirty
If your dishwasher drains it's water to a garbage disposal, give the disposal a spin while the dishwasher is pumping out. Check around the bottom of the dishwasher to make sure something is not clogging the drain.
May 01, 2009 | Kenmore Dishwashers
Kenmore Elite dishwasher 655.16463300 not cleaning dishes
The inlet screen is at the bottom of the unit. Clean it out and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 08, 2009 | Kenmore 24 in. 16463 Built-in Dishwasher
Dishes not getting clean or drying completly
I would fill the dishwasher only half full of dishes that are well rinsed off, run the sink water til hot before turning on the dishwasher, use a good quality dishwasher soap or tablet, and make sure the dishwasher is set to a full length setting like potscrubber as opposed to rinse and hold.
Feb 19, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Dishwashers Logo
88 people viewed this question
Top Dishwashers Experts
