Question about Dishwashers
My kenmore dishwasher isn't cleaning the dishes very good
  • leojean Mar 22, 2009
    We have the same problem of our dishwasher no longer cleaning as well. We had originally had the maintenance contract so I (the wife) watched the person do this cleaning once. I was trying to take mental notes so I could do it myself periodically. It did not look all that complicated and "Marchy"s description fits with what I remember. My husband and I are just now trying to remove the bottom washing arm but we turn adn turn and turn the center post screw and it does not seem to be coming off. However, it does seem slightly looser so I don't think we can just quit and leave it the way it is. It seems like it might be threaded a bit "off" because we are getting some plastic shavings off the center post screw. Any suggestions? The model number is 16462. THANKS!
  • Anonymous Apr 26, 2009
    How do I remove if ther is a turbo zone?
  • 9 Answers
Your broblem is probably the cutter/chopper filter. This is located under the bottom cleaning arm assembly.
Remove the baskets.
Remove the bottom washing arm. Unscrew the centre post and lift off the arm
Remove the conduit to the top arm(s). Remove screw at top and at back. Rotate the conduit assembly 45 deg right and lift off.
Remove 4 screws (Star T-20 bit) and lift whole assembly out. Pop off screen and clean.
Remove cap over cutter/chopper. There is one screw at left front under assembly just removed. Remove it and the plastic cap (Needs some wiggling to free it up). Remove the cutter and filter. It is on a spring loaded pin. Pull in foreward and also lift the filter disc up and out. Thoroughly clean the filter.
Reassemble
Posted on Jan 02, 2009
dutchman05
  • 487 Answers
SOURCE: Kenmore dishwasher series #168790 not cleaing dishes
Hiya,
Please clean filter in the bottom of the machine.
Even can clean out the pump. than start a wash empty and as soon as it has filled up put 3 cups of vinegar in the machine. Let it run on hot.
this should fix the problem
Also please take out the arms and make sure all the holes are not obstructed.
This is a simple way of cleaning but effective
Posted on Apr 26, 2008
  • 677 Answers
SOURCE: new dishwasher leaving powder residue on dishes.
the problem is hard water and there is a new product out called the dishwasher filtration system. it actually filters the water going into your dishwasher and leaves your dishes spot free. after the first load i was amazed that the white film was gone and my dishes were sparkling. you can get it at www.dishwasherfilter.com.
Posted on May 21, 2008
  • 117 Answers
SOURCE: kenmore dishwasher not cleaning properly
Look in the inside for any screen that would be easily removed, some dishwashers have a self cleaning filter so you may not find it. I have a lot of other tips for you if your dishwasher is not cleaning so check it out.
http://tclaundryrepair.com/dishwasher
Posted on Feb 26, 2009
  • 677 Answers
SOURCE: dishwasher does not clean good anymore,leaves dirt film on dishes
the problem is hard water. www.dishwasherfilter.com has a new product out that solves this problem once and for all. it filters the water going into the dishwasher removing the hard minerals that leave those spots. it is very affordable and guaranteed to work or your money back. you will love the way your dishes look.
Posted on Aug 22, 2009
  • 4345 Answers
SOURCE: I have a kenmore 17032 dishwasher. Lately, it has
The key is to not use the dishwasher as a garbage grinder.
I suggest that you witness the volume of water being discharged from the machine. If low volume, look inside for plugged screens.
Also, be sure to remove all food particles from the sprayer tips, which is not an easy task, get each and every piece, run machine and check again. then quit putting dirty plates in the machine, quick rinse = seriously better cleaning, and less unit maintenance.
Doc
Posted on Sep 09, 2009
The top shelf of dishes in my CDA dishwasher isn't coming out clean any more
Look at you manual. How to remove the top spryer to clean it, re-install and presto. (I hope)
Jan 13, 2013 | Dishwashers
Dishwasher does not clean dishes. Some soap remains in soap dish. Have tried on the enrgy saver cycle and 1 hour cycle.
Hi jerry1413,
Firstly, make sure you are using powdered soap, and not the 3 in 1 tablets. The 3 in 1 Tablets only release certain parts of itself on certain temperatures, and because all dishwashers aren't alike, they won't have the best of results on all makes & models. Cycles aren't run the same way on every Make, and don't follow the same order either. Trust Me ;-) , stick to Powder.
Furthermore, check the following link for some advice and suggestions on getting your dishwasher to clean properly again:
WHAT TO DO IF YOUR DISHWASHER ISN'T CLEANING WELL ANYMORE...
Kind Regards :-)
* If you found this solution helpful, please rate it?
Jun 18, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
Dishes on14859 top shelf dose not come out clean as before
Hi jq14859,
If your dishwasher isn't cleaning properly anymore, there is a few things you can check.
Check this tip:
Hope this helps :-)
If you found this solution helpful, please vote accordingly :-)
May 11, 2011 | Bosch 24 in. SGV43A03 Built-In Dishwasher
Not cleaning properly
take a good look at the two spinning washers they are easy to remove i would suspect they are clogged clean and replace.adrian,,,,
Jul 14, 2010 | Kenmore Dishwashers
Kenmore 17033 dishwasher will not clen dishes
USE JET DRY and clean the system every once in awhile by running it through a cycle with no dishes and use washer cleaner for that model.
Jan 07, 2010 | Kenmore 24 in. 17033 Built-in Dishwasher
Kenmore Elite Dishwasher leaving crud on dishes
yes it is under warranty so call whomever sears i imagine and raise hell you bought it in good faith so tell them to fix it right or replace it with a new one.if Sears they are pretty good re complaints so get on the phone and get it done good luck
Dec 12, 2009 | Kenmore Dishwashers
Our Kenmore dishwasher leaves a fishy odor on dishes
Go to Walmart gets some DISHWASHER CLEANER....works great...also clean out both screans and the water arms have holes...clean them out with a tweezers.
Sep 20, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Cloudy dishes
Hi there.
You will need to get some cleaning detergent so you can clean the jets and the internals of the machine, once the clean has been done you should end up with clean dishes.
Good luck and thanks for using FixYa!!
May 11, 2009 | Kenmore Dishwashers
Dishes on top rack don't get clean
The following suggestions will greatly enhance the ability of your dishwasher to clean all of the dishes thoroughly:
1. Rinse all of the food off of the dishes before you put them in the dishwasher.
2. Run the hot water into the sink until it is as hot as it gets before you start the dishwasher.
3. Do not pack the dishes into the dishwasher, just put in a reasonable number without crowding or stacking them on either shelf.
4. Pull the top shelf all the way out to be sure that the water connection at the rear of the top shelf is connected. Sometimes, this connector comes disconnected preventing the water from entering the top spray assembly.
THese things should make a huge difference.
Good luck with this and please rate my answer. Thanks. Joe
Feb 03, 2009 | Kenmore 24 in. 15079 Built-in Dishwasher
Open Questions:
Dishwashers Logo
1,875 people viewed this question
Top Dishwashers Experts
