Question about Yamaha Audio Players & Recorders
My yamaha rx-v1900
In my speakers setup menu i have a PRNS r and l what are they or what do they do also in seting up the spearers if i have a setting i like in dolby digital if i change to 7 ch enhancer they all change its strangs it will come back like front r will be 5.5 and front l will be 3.5 without any changes
I have a problem in setup which prompt error "memory guard".
How to solve it and i can access to all setup
Posted on May 04, 2009
Message volume fixed
Zone 2 Setup on the RX-V773 using the ZONE2/PRESENCE Extra Speakers The RX-V773 extra speaker terminals can power one set of speakers for Zone 2 or Presence speakers. If the extra speaker terminals are utilized then the RX-V773 cannot be set for Bi Amp (Surround Back/BI-AMP terminals). Setting the Extra Speaker Terminals Note: The RX-V773 remote control will be used to access the On Screen Menu of receiver. 1. Press the On Screen button on the remote control to enter the On Screen Menu. 2. The On Screen display should be displayed on the TV/Monitor. 3. Press the Arrow Down button on the remote until Setup comes up in the screen. 4. Press the Enter Button on the remote control. 5. The Setup Menu will come up across the TV/Monitor screen. 6. Use the Arrow Left & Right buttons on the remote to navigate to Speaker. 7. Press the Arrow Down button on the remote to select Manual Setup. 8. Press the Enter Button on the remote control to enter Speaker Manual Setup menu. 9. Speaker Manual Setup menu with Power Amp Assign highlighted will come up. 10. Press the Enter Button on the remote control to enter Power Amp Assign menu. 11. Speaker Manual Setup, Power Amp Assign menu will come up with Basic highlighted. 12. Press the Arrow Down button on the remote to select 7ch+1ZONE. 13. Press the Enter button on the remote to select 7ch+1ZONE. 14. Press the On Screen button to exit the on screen menu. To control Zone 2 using the RX-V773 remote, the switch at the upper left side (above the BD/DVD Scene button) of the remote must be set to Zone 2. To see the operations on the front of the Yamaha receiver you must press the Zone Control button on the front of the receiver. Note: Only analog signals can be sent to Zone 2. If you want to output the sound from Zone 2, connect an external component to USB Thumb drive, USB iPhone/iPod, Network, AV 5-6 or Audio 1-2 by analog connection. For AM/FM radio the antennas must be attached.
Aug 19, 2012 | Yamaha RX-V773
Does the yamaha RX-V1900 have analog zone two output
Yes your amplifier has assignable multi zone capability .You have to go into the initial setup of the amplifier and select if you want to assign any one of the amplifiers ( eg: rear back amp ) as zone 2.
May 22, 2011 | Yamaha RX-V1900 Receiver
How much is a FM/AM tuner replacement part for a yamaha RX-V1900. My connection are broken on current unit.
If you mean the where the aerial goes in, it will be much cheaper to replace that, then buy any board, even if they are still made.
Have a look in Maplins (uk) or Radio Shack (USA) to see if you spot something like it. It will just need soldering on!
Jun 14, 2010 | Yamaha RX-V1900 Receiver
Yamaha rx-365 reciever not showing all speakers
I,m not familiar with the Yamaha but most receivers are set up the same way. In your setup menu are the speakers marked on in the display?. Your DVR needs to be transmitting in 5.1 to start with. If this is the case then make sure you select the correct audio function on the receiver.
Mar 04, 2010 | Yamaha Rx-v365 A/V Home Theater Receiver
Rx-v1900 hdmi hdtv problem
On most modern receivers you must select which signal type you want it to process.
for example on my Denon, I have to go into the on screen menu and select the input I want ie: video 1.Then tell it which signal I want it to use ie: s-video, component or HDMI input for video and then which input corresponds to the audio signal for that component ie: analog, digital, optical or hdmi.
Its complicated and a pain in the ****
Hopefully that helps call Yamaha they will usually walk you through the process while on the phone.
Feb 14, 2010 | Yamaha RX-V1900 Receiver
How do I link mt remote (rx-v1900)with my tv
OK. So did it come with instructions? If not, it is a rip-off. I suggest you contact your retailer in that case.
-K.R.
"I know what I know because I know what to do!"
Feb 07, 2010 | Yamaha RX-V1900 Receiver
I have a Yamaha RX-V863 receiver connected to a
Do you have all 5+1 speakers connected? You need to go to the Setup menu of yamaha and set which speakers you have and which you don't. For example if you don't have the Center speaker connected, receiver will redirect and mix the sound to the other speakers.
Blue-ray film over HDMI should automatically output via all your configured speakers (nothing to be configured).
Nov 26, 2009 | Yamaha RX-V863 Receiver
HDMI out jack physically broken on my rx-v1900. Fixable?
An audio repair shop should be able to get a replacement connector and swap it for you. I doubt that the part is available from Yamaha (and it would be pricy if it was). The connector shouldbe available generically. Digikey or Mouser should be a good source.
Dan
Nov 18, 2009 | Yamaha RX-V1900 Receiver
No volume in Zone 2
Get the original Yamaha remote, go to Set menu, manual setup, speaker setup, and look for "extra speaker." it needs to be set to "zone 2." This is off the top of my head, so it should be pretty accurate. Get used to doing this, though, as this amplifier assignment to zone 2 is prone to resetting itself in those Yamahas.
Sep 05, 2009 | Yamaha RX-V661 Receiver
Hi where can i downlowd a manual for the rx-v1900
I would start at the www.yamaha.com web site's support page. Find a Support page, and then look for Downloads. Be prepared to enter specific info about your device, like model number, serial number, etc.
If that fails, enter something like: yamaha rx-v1900 user manual in Google and you should see many different references to it. Spend a few minutes browsing the most likely places by reading the headings.
Aug 21, 2009 | Yamaha RX-V1900 Receiver
69 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
