Question about Infinity Reference REF 6913I Car Speaker
Infinity 6913i speakers sound very quiet compared to front speake
Hi guys:
I got a pair of reference 6913i rear car speakers but when connected they sound very low in relation to front speakers. I balanced and fader to middle everything and tried them in my home stereo and still low volume!! Any help? I heard these are top speakers? I'm ready to trash them!! I appreciate any hints!! Thanks.
Dioni
3 Suggested Answers
  • 3 Answers
SOURCE: Speakers won't play ''loud at all '' Just Very faint
they dont sound loud because you need to use the DUAL voice coils and make it 2 Ohms. Google " how to bridge a dual voice coil sub"
Posted on May 25, 2009
  • 45 Answers
SOURCE: I have a 2002 Chevrolet Camaro with the Monsoon
one of those wires on your speakers is the common ground for both sets of wires in your camaro, Just take the negative wire from both sets of wires and run it to the single wire on your new speakers. The other 2 are positive from each wire. good luck
Posted on May 25, 2010
Dodge infinity
The Infinity system includes a CD/cassette receiver or a CD receiver in the dash, and a complement of 7 speakers: 3-1/2" speakers in the dash (left, right), a 2-1/2" center dash speaker, two 6"x9" woofers in the front doors, and two 5-1/4" speakers in the rear doors. You'll have to remove a section of the dash to install a new stereo, as you do with the non-Infinity system. You'll need a special adapter to connect a new car stereo to the Infinity factory amp http://www.crutchfield.com/p_120CHTO02/Axxess-CHTO-02-Factory-Integration-Adapter.html?tp=3486
Dec 25, 2013 | Cars & Trucks
42.1i passenger side rear has power but sound is very quiet and tinny. all 3 other speakers work fine.
It sounds like the woofer part of the speaker is bad, while the tweeter is still good. You are going to have to replace the speaker. Speakers are generally sold in pairs, so it would be best to replace both rear speakers at the same time.
Jul 18, 2012 | Infinity KAPPA 42.1I Car Component System
Need full stereo wiring diagram
Hi there:
2004 Infiniti I35 Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Yellow
Car Radio Switched 12v+ Wire: Violet
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/White
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: Green/White
Car Stereo Amp Trigger Wire: Green/White
Car Stereo Amplifier Location: Under the rear deck.
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White
Left Front Speaker Negative Wire (-): Black
Right Front Speaker Positive Wire (+): Green
Right Front Speaker Negative Wire (-): Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Black/Red
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Black/White
Hope this helps.
Mar 06, 2012 | 2004 Infiniti I35
What is the button on the front of the 653.7i kappa series
The button you might be referring to is actually a little speaker. Its produces the high frequency sounds from that area.
If you look up infinity 3 way you will see 2 "buttons" in the front, smaller one is the high frequency sounds and the middle sized one is the mid frequency.
Mar 03, 2011 | Infinity Kappa 653.7i Coaxial Car Speaker
I need a 5'' mid range for an infinity reference six speaker
you can buy only the membrane. Is available in all professional sound repair stores
Nov 01, 2009 | Audio Players & Recorders
I have 2 infinity kappa speakers in the rear deck of my car. i had a stereo system in the trunk but it didnt really do much except throw more bass in with the music even then it wasnt that much bass. i...
You sold the subs, or sold the infinity kappas? After selling a sub system it is often more than disapointing to go back. It often does sound quiet. You can either deal with it for a couple months until you get used to it, or I'd go with a set of MB Quart to replace your kappas.
Oct 08, 2009 | Infinity KAPPA692.9I Coaxial Car Speaker
I hooked up a 4 ch alpine amp MRP-F600. The back speakers play nice but the front speakers play very low. What could be the Problem?
1)When you connected the amp to the head unit, did you run two pairs of RCA cables for front and rear reference or did you only run one set of RCA cables from the rear out to the amp?  2)If that's not the case and you did ran two sets, on your amp, swop the rear and front RCA cables. If the rears go quiet and the fronts are loud you now know the issue is either in the cables or how the head unit is set up. If the fronts are still quiet, check your Amp's gain, frequency and filter setter settings (if available). If those settings don't change anything you may have a faulty amp. 3)Check speaker connections, seems trivial, but you never know.
Message me back if nothing works and/or you get stuck.
Ciza
Nov 04, 2008 | Alpine Car Audio & Video
6x9s cone not working!
can you swap speakers with other one?if so do this and if speaker still sounds bad it is definately the speaker. there is really no way to take speaker apart and repair
Oct 02, 2008 | Infinity Reference 6412cf Coaxial Car...
No sound from main speakers.....
WHEN YOU SET ZONE 2 ON DID IT ASK YOU TO OUT PUT ZONE 2 ONLY OR MAIN + ZONE 2? IFF SO TRY SWITCHING MAIN ON AND IFF THIS DID NOT WORK MAKE SHURE SPEAKERS ARE SWITCHED ON IN MAIN MENU.
I KNOW THIS IS 2 LATE 4 YOUR NEW YEARS PARTY BUT I JUST FOUND THIS SITE 2DAY.
HOPE THIS HELPED.
CABLE GUY.
Dec 25, 2007 | Onkyo TX-SR601 Receiver
Infinity SM 255
you will have to sell them and buy a new set of speakers for better quality sound
Mar 05, 2007 | Infinity SM 255 Speaker
Infinity Reference REF 6913I Car Speaker Logo
185 people viewed this question
Top Infinity Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Colin Stickland
Colin Stickland
Are you an Infinity Car Audio and Video Expert? Answer questions, earn points and help others
