Question about Whirlpool LEQ9858P Electric Dryer
BELT REPLACEMENT WHICH BELT GOES ON TOP AT PULLEY
I ORDERED THE BELTS BUT i THINK i HAVE THEM ON WRONG, PUMP RUNS EITHER WAY BUT THE AGITATOR DOES NOT. oDDLY THE SPIN DOES?? i AM NOT SURE IF i PLACECED THE CORRECT BELT IN THE CORRECT PLACE - i KNOW WHICH GOES TO EACH LOCATION JUST NOT ON THE METAL PULLY. dOES THE PUMP BELT FIT IN THE TOP SLOT OR THE BOTTOM ONE??
(sorry about caps above - not yelling just inept)
  • 641 Answers
Try the following site, Not sure it will help but gives you a parts breakdown. http://shared.whirpool.com/assets/pdfs/literature/Repair Part List-8180371.pdf
Posted on Apr 04, 2009
I have a whirlpool ultimate care ii heavy duty super capacity plus washer that fills, and agitates, but will not "spin" or drain water. What do you guys think needs replaced?
"If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it."
May 04, 2015 | Whirlpool Washing Machines
No spin agitate or drain just motor noise
The noise coming from the motor means it is running but cannot drive the drive pulley and the pump pulley because the drive belt is either broken or has slipped off. The drive pulley and the pump are driven by a single belt. Replace the drive belt if broken or loose and has slipped off. Disconnect power then drain the water manually by placing the end of the drain hose into a bucket or a shallow basin. Position the bucket/basin as low as possible to extract as much water from the tub. Once drained, lay the machine on its back to access the belt under the machine. When replacing the belt, wrap it on the motor and the pump pulleys then on the drive pulley. Turn the drive pulley in such a way that the belt wraps around the motor pulley, pump pulley, and the drive pulley.
Nov 11, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Won't spin, agitator won't turn. Repair it or just get a new one? 8 yrs old.
Hello,if your washer won't spin first check to see if the motor is running, then proceed as follow.
1. If the motor is running, your washer probably has a frozen pump pulley or broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely or if it is frozen or stiff replace it.
If the pump belt is broken or looks quite warm, replace it but be sure to check the pump pulley before you change the belt.
AGITATOR: If the agitator won't turn, the likely cause is "Lid Switch" because if the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Thanks
Jun 09, 2010 | Maytag SAV2655A Top Load Washer
Drum doesn't spin or agitate. Only drains. Timer works.
It doesn't spin If your washer won't spin, check these: It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows: If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt. If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. It doesn't agitate If your washer doesn't agitate, check these: Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys
Jan 02, 2010 | General Electric WJRR4170GWW Top Load...
More on my frozen maytag spin, motor seems to continue to run (i.e. the pump belt is turning), but the agitator belt is slipping. I assume this is the switch that is screwed down to the motor, about $60....
Okay here is another thought... are your sure that it isn't the pum that is getting tight and seizing up when you turn it in that direction?? Maybe you need to disconnect the coupling and spin just the motor and just the pump to see which it really is that is causing the problem.
Still don't think it is the brake...
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 24, 2009 | Washing Machines
Washer won't spin or agitate
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
Apr 27, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Motor cuts out after spin cycle engages
yes the pulley system needs replacing theres a kit available that has all the washers etc you may have refitted in the wrong order.hope this helps.
Mar 26, 2008 | Maytag Performa PAV2200
Plastic pulley melting
Whatever the pulley is attached to has seized. Either the water pump or tub drive, or something else has stopped spinning. The belt continued to run because the motor kept pulling it, and the friction from the belt melted the plastic pulley. Hopefully its the water pump, as its the most inexpensive. You should change the belt along with this fix, it has also got hot and probable will not last as long as it should.
Mar 15, 2008 | Maytag Atlantis MAV9750A Top Load Washer
Kenmore agitates, but no spin or drain
Your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley you should remove the pump from the washer and try to rotate its pulley manually. If it doesn't turn freely(frozen or stiff) it should be replaced. In case of a broken pump's belt or belt looks quite worn, replace it. In any case,check the pump's pulley before you replacing the belt. Good luck !
Aug 16, 2007 | Kenmore 24872 Top Load Washer
New belt
First put the belt around the small pulley, shd be the motor pulley i think. Then ease the belt around the big pulley & gently move clockwise if the pulley is on the left side; anti clockwise if you are inserting on the right side. The belt will fall into place. Actually it is very simple.
Apr 18, 2007 | Maytag SAV4655A Top Load Washer
Whirlpool LEQ9858P Electric Dryer Logo
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
