Getting rid of the computer so i want to reset to factory settings.
You can google search for "bypass computer password" or "reset computer password".
While bototing press the F8 key start windows repair tool then restore to factory settings
You can go into safe mode (F8 at logo when booting up) and enter as administrator and then go to accounts and change Windows password and that's with XP.
If the method above can't help you, you can use one of the tools:
Windows Password Recovery Tool
Windows Password Reset
SOURCE: Dell Dimension 9100 W/ linux, Wanna reset to Factory Windows XP
Contact Dell for a System restore Disk
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
SOURCE: just want to get rid
As soon as you press power, keep tapping F8 until another screen comes up. Select reinstal windows / operating system or restore factory settings from the list given.
Hope this helps and please rate.
PS this way you do not need a disc it reinstalls the OS that is already installed on your hard drive.
SOURCE: put back to factory settings
run sysprep under system32 folder, it will give you out-of-box Experience.
SOURCE: factory setting
a format of your hard drive to load nother operating system will remove any virus you have on your computer
if you want to load winows 7 make sure its compatible with windows 7
if its 3-5 yrs old might not be compatible and need minimum of 2 GB of ram
restart your computer
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos restart
note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults
after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
during the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS using the arrow keys load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
IDE0 means Pri master
IDE1 means Pri slave
IDE2 means Sec master
IDE3 means Sec slave
Hope this helps you
Follow these instructions:
Thank you!" - paul7of9
i have done this Anthony but i want to clear the computer of all personel details as its my recently deceased mothers computer and i will be giving it away or scrapping it
restart your dell and while it's booting press the F8 key repeatedly...run system repair utility then restore to factory condition...
