Question about Ovens
Oven showing error code CAL on display. Maytag Model number MEW5627DDB. Tried turn off power for 24hrs, no change. How to fix?
5 Suggested Answers
taran_2005
  • 10515 Answers
SOURCE: Oven displays F7 error code and does not function
Unplug the Oven, Disconnect the Power Supply and then Turn the Oven Back, say after 30 minutes. If the code still appears it could be either Faulty Touch Pad or Computer.
Now,
To check, Turn OFF the Oven as we did earlier, then remove the Control Panel . Disconnect the Ribbon like Cable from the Touch Pad. Disconnect it from the Computer. Turn the Oven, and if Code appears Replace Computer Unless Replace Touch Pad.
It is a Valid Model Number. You could buy the same from :-
http://www.repairclinic.com/Appliance-Parts?s=t-JT950B0A1BB-%3d%3d
http://www.cashwells.com/
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Dec 20, 2009
Powerman
  • 68 Answers
SOURCE: F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Posted on Nov 04, 2007
  • 1314 Answers
SOURCE: Jenn Air Oven Model WM27260B Error code F7 plus beeping
f7 is a shorted key-stuck function on control
Posted on Feb 19, 2008
SOURCE: Maytag oven will not light
Having same problem.  Broils works.  Oven set to 350 then registers 100.  No gas no heat.  does anyone know the fix?
Posted on May 15, 2008
SOURCE: Whirpool GBD307 - Display not working
We had the same error codes F2 E6. We were told to turn off the breaker to the oven for 5 minutes and then turn it back on and it will reset itself. We tried it and it worked! Whirpool wanted to send someone out on a service call. Thank goodness we didn't!
Posted on Aug 01, 2009
My power went off today and when it came back on, my Kenmore oven shows error code "PF 5 AB". None of the buttons work that I press. Burners turn on, but can't turn on oven. Suggestions?
Could that be PF power failure 5AB in the Sabbath mode. That's a new one.
Your model number is useless. Sears has a big 3 digit product code followed by 8 digits.
But let me dig up my 5AB notes:
Here is what I have:
To
provide sabbath feature (or to cancel this setting):
1. Push the PREHEAT pad and set the oven
temperature to 500°F/260°C or more using the UP
ARROW pad.
2. Push the PREHEAT pad within the next 2 seconds
for 3-4 seconds. A beep sounds and a number
appears in red to the right of the display. For the
conversion, "3" must be displayed. If another number
is displayed, push the PREHEAT pad and select
"3".
3. Push the UP or DOWN ARROW pad to change
from 12 hour to 9999 in the display, for no 12 hour
shut-off.
4. Push the CANCEL pad to confirm your choice.
Other Displays:
When proceeding through steps 1 and 2 in the
Temperature Scale Conversion or in the elimination
of the Sabbath feature /12-hour Shut-off time limit,
two other words can be seen in the display. One is ESC
with O in red. It cannot be changed. The other is USE or
SALE with 3 in red. This one is for factory use and should
stay on USE.
Hope this helps
Mar 19, 2011 | Kenmore 40494 / 40495 / 40499 Electric...
Thermador C302U error code
most of error codes disappear when a hard reset is done.
did u try a hard reset first?
Jun 28, 2008 | Thermador C302U Electric Double Oven
Tip
My oven displays error code 5AB
Hi.
I am publishing this tip because of the many users asking me about the code 5AB on Amana, Maytag and other ovens.
Error 5AB in fact does not exist , and what you see written on display isnot 5AB.
The beeping sound is a warning because the oven is in lock condition. The oven is not faulty, and the code is not 5AB, but SAB.
SAB means that the oven is in Sabbath mode, and the control board will be locked for 72 hours with SAB on display.
If power is disconnected a new 72 hours cycle will start.
Depending on the model, there may also be a beeping sound when you try to operate the oven.
Push and hold the Clock button for about 10 seconds, until the display clears, that will reset SAB mode.
If that does not work leave the oven connected and off for 72 hours. If the oven does not unlock after three days, then the electronic control may be stuck in SAB mode because it is faulty, in that case contact the manufacturer at the number listed on the owners manual.
Regards.
on Mar 05, 2010 | Ovens
We installed kitchen aid microwave convection oven model kems308. it is displaying error code F6E0, "Lost communication". Any idea on how to fix?
Turn the power to the oven off. It usually is not possible to unplug the power chord for the built-in appliances so go to the main switch board and just turn off the oven power for about 5 minutes and then turn on the switch. The error code should disappear. Mine did!
Chander Mehta
Jun 06, 2010 | KitchenAid 27 in. Built-in...
Now,
Hope i helped you.
Dec 20, 2009 | GE Ovens
When the oven is turned on to preheat, the buzzer goes off and an "F1" error message is displayed and the oven turns off. The model # is MGR5750ADW. Is there something we can do to fix it?
An "F1" error code means you have a defective clock assembly (also called ERC- electronic range control). You will need to replace the clock assembly, and they are not cheap, around $200. Hope this helps you, good luck.
Oct 04, 2009 | Maytag Ovens
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
Mar 28, 2008 | Whirlpool RBS245PDS Electric Single Oven
Display Panel Light
There is a replacement display assembly, i think its around $150-$200. Its pretty easy to change if you are at all mechanically inclined. Good Luck!
Oct 29, 2006 | Jenn-Air W30400P Stainless Steel Electric...
Ovens Logo
129 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you an Oven Expert? Answer questions, earn points and help others
