Question about iLO DVDR05 DVD Recorder
How to install ilo dvdrecorder/player
I purchased this dvd recorder/player so that I could view and record diffferent shows.I had to disconnect it and now I can't get in connected again. Is there some where I can get the manual for it.
5 Suggested Answers
SOURCE: Replacing dvd player/burner on iLo DVDRH04 DVD Recorder
I Have ILO DVRHD04 and my front buttons sto to work when i use the remote works ok... when the unit is of I turn on from the front paner works ok try to turn off from the front buttons is not work and the lite in the front go crazy only when i pres stop & play button and on fo button... what is the problem... The remote work ok play stop edit or recodring
Posted on May 09, 2008
SOURCE: ilo dvd player/recorder
OK I called the Philips and since mine is already programmed he walked me thru how to retreive code. He said 1906 on the VCR button. Hope it works for you KCGIRL.
Posted on Jul 03, 2008
SOURCE: User Manuel
I have a manual for ILO DVDR04 that is in pdf file. It is not a very good copy because it was copied through an inexpensive fax machine. But it is perfectly legible. If you want it, you should send me your email address to and I'll send it to you (free, of course).”
Posted on Dec 14, 2008
SOURCE: User Manuel
This is the website to download manuals for the ilo DVD Recorders. Took me forever and alot of different searches, but here it is:
Posted on Apr 10, 2009
SOURCE: ilo dvd recorder manual
I GAVE UP on Fix Ya's doubletalk.
Found the perfect solution elsewhere.
FixYa can stop following up now, Please.
Posted on Oct 02, 2009
0 characters
1 Points
Cannot record on ilo dvd recorder with any blank dvds
Try another brand of blank dvd's a -R or +R as this is a compatibly issue
If all else fails buy verbatims as they are universal
Oct 12, 2009 | iLO DVDR05 DVD Recorder
When I place a DVD disc in it shows (no disc or unkown disc). It will play the DVDs that I have recorded on it but not those I purchased. Ray
this item will not play store bought disks it is for recording and burning blank disks you need a normal dvd player
Jul 04, 2009 | iLO DVD Recorder DVDR05
Ilo dvd recorder do not recognize any dvd
According to that this unit is very picky on what discs it will record on. Look up unit and read the large number of reviews in DVD Recorder section
Dec 25, 2008 | iLO DVDR05 DVD Recorder
My ilo recorder wont take any disc
If it won't play any disc including prerecorded movies, then try cleaning the lens.
Nov 02, 2008 | iLO DVDR05 DVD Recorder
Dvdrecorder and convertor box
If the clarification request is correct. The only thing i can suggest is. Plug aerial into converter box. plug converter box into TV using either scart or coaxial cable. then connect converter box to dvd recorder using scart or coaxial cable depending on what you used to plug converter box into TV with. Then plug dvd recorder into TV. I don't know if you have to set-up the converter box to start receiving i'm not sure. But try this anyway.
You'd probably have been better off getting a free-view box and your dvd recorder. Because as long as you've got a free-view box you'll always get digital. Hope this helps
Jul 29, 2008 | DVD & Blu-Ray Players
Can't get picture to show up . .
You should be connecting video in of Dvdrecorder to video out of Tv.
Feb 29, 2008 | Lite On LVW-1105HC DVD Recorder
I purchased the DVDRo4 and its been pretty reliable so far.
These R04 are fickle,some Brands of DVD discs won't work in ILO,try another brand.Also clean laser in iLO it may be dirty,use commercial cleaning disc,put a drop of rubbing alcohol on brushes.Do not use any other chemical.
It is possible you laser is defective or starting to go.If that's the case you need to replace burner/loader.
Some dvd recorders formulate a little differently,I have made recordings in my iLo that won't work in all brands of players/recorders.
Aug 14, 2007 | iLO DVDR04
When I burn a dvd on the ILO it works fine, but can not be viewed on any other dvd device.
check the program you are using it might not be compatible to other system.
Feb 16, 2007 | iLO DVDR05 DVD Recorder
iLO DVDR05 DVD Recorder Logo
122 people viewed this question
Top iLO DVD & Blu-Ray Players Experts
matt martin
matt martin
Steven Wander
Steven Wander
Are you an iLO DVD and Blu-Ray Player Expert? Answer questions, earn points and help others
