I have a hp Lcd monitor (f2105) and it shows a blank screen. The power light remains on and if i turm it off and back on again, screen comes on for a split second goes blank again. I've plug it into another computer and still the same problem please help
  • Casey
    Casey May 11, 2010
    Screen come on for a split second as in
    1) Shows the desktop for a split second
    2) Powers up, but goes into sleep mode after a second
  • 69 Answers
sounds to me that the main board on your monitor needs replacing.
regards,
Philip
Posted on Dec 01, 2008
My hp f2105 monitor stays on for only 2 seconds and blacks out again how can i fix it?
The light comes from 4 luminiscent tubes. They are empowered by high-voltage power suppy. There is a circuit, that continuously monitor the lamps and the quality of the power from the low-voltage power supply. Either there is a faulty light tube, or there are inflated capacitors on the LVPS. First one is hard to repair due to need to open the LCD itself, which is hard and dangerous, the light tubes are hard to find and LCD is hard to clean perfectly when closing and appear dirty spots on the screen. The second one is easy - visually inspect the capacitors and if their top is not flat, then replace all of them with the relevant capacitance. I suggest to use capacitors for higher voltage (35V) thus making the PS lasting forever.
Apr 07, 2012 | HP f2105 21" LCD Monitor
Hp f2105 black screen after 2 sec on?
You've asked this question in two places. This is confusing--try to ask it in one place only.
I answered it in your other request.
Nov 20, 2011 | Rosewill R700J 17" Flat Panel LCD Monitor
MY HP f2105 21" LCD Monitor is blank, when I reboot, at the startup, I saw only one or two second of HP opening screen and monitor goes back like if there no connection. In I shut off the monitor and...
You may be having either the power supply failing due to bad caps, or failed backlight inverter circuits due to short circuits, loose connection due to bad solder joints, or failed lamp assmblies. You will have to open it up and inspect the inside. Do you have proper tolls for electronics repair, isolation transformer for safety so you do not get killed by high voltages inside the monitor?
You can see what your monitor look like here:
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
May 31, 2010 | HP f2105 21" LCD Monitor
My screen keeps going dark like it is going to sleep
Right click on any free space of desktop and go to properties and go to Screensavers tab and click on Power Tab and select Never in Turnoff monitor option and click apply OK.. now it will not go dark..
Soluzia.net
Jan 07, 2010 | HP f2105 21" LCD Monitor
Hp f2105 monitor works for about 1 minute and then blank screen. turning the monitor off and on again brings back the screen
It sounds like you have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts,replace any that look like the pictures and your monitor should work fine. The capacitors do need to be installed with the correct + and -connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $45 plus shipping. If your problem is not the capacitors then it would be the backlights and that is much more difficult to replace.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jul 08, 2009 | HP f2105 21" LCD Monitor
Screen comes on briefly then blanks out.
check inverter, memory, and powersupply.
May 31, 2009 | HP w1907 LCD Monitor
Hp f2105 only stays of for 2 seconds
Hi there mate i have a hp f2105 with the benq power supply in it which as gone faulty could u look at your power supply and tell me the numbers on the power ic which is ic651 thanks.
Jan 13, 2009 | HP f2105 21" LCD Monitor
Dell E173FPb 17" TFT LCD Flatpanel
Video cards that can handle two monitors at the same time have cables with two plugs on the monitor end.
If your video cable has two plugs on the monitor end, try the other plug.
Dec 29, 2008 | Dell E173FPb 17" TFT LCD Monitor
LCD Monitor
is it connected to a PC? is the power source good 110v or 220v?
Mar 30, 2008 | Computers & Internet
HP f2104 LCD black screen
Sounds like an inverter problem. If the power supply is internal replace the capacitors coming out of the voltage regulators. These are usually 1000mf and/or 470mf. If that doesn't do the trick look up the numbers on the 8-pin chips that drive the secondary transformers on the inverter to see if they are getting the right voltages.
Good Luck!
Feb 17, 2008 | HP f2105 21" LCD Monitor
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
