Question about Dell 962 Photo All-In-One InkJet Printer
I have changed the cratridges already-and it still wont print.the display message says catridge error - error 1203.
    Guru:
  • 1,049 Answers
Check to insure that the ribbon cable which attaches to the print head is intact and secure. Ensure that you have removed all the protective tape from the cartridges before installing them, and that the ink carriage is clean. (no ink on the copper contacts of either the carriage or the ink cartridge itself.)
Posted on Dec 09, 2008
I cant print and get error message 1203 on my lexmark p315 model:any idea wat that error message is?
t's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again.
The refill ink work very well if you let it sit 24 hrs. Then before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Print the test page to see how it's look and way you go.
Be sure not to leave any debris of klennex on those holder contact panel.
Too bad that I also cound not find out how to reset the ink indicator. It's annoying to hit the OK button every time you want to print.
Try and see if it's work for you. Good luck......
Dec 22, 2010 | Office Equipment & Supplies
Hi my name is Hector,on my 2.5 inch display it say cartridge erro error #1203. I checked my users guide it dosnt say anything about error numbers.
Error 1203 is a very interesting error code. Here is what I found out about error 1203
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a problem and overlook.
Solution:
or try this other option:
Dell All-in-One Printer Cartridge Error 1203.
I found if you cover a copper contact on the color cartridge the error clears and the cartridge works. Looking from the contact side for the color cartridge 2nd row contact 2 from the left. I found if I use an ohm meter from 2nd to 3rd contact I measure 119 ohms. I believe that is a shorted cartridge. If you bought it New I would get it replaced. I use a SMALL square piece of Scotch tape. I believe this will work on Lexmark printers.
Jan 06, 2010 | Dell 966 All-In-One InkJet Printer
Installed Office Depot Dell all in one MK990 Dell series 9 all in one 926,v305,v305x,v305w and Im getting a 1203 error message. I put the old original dell cartridges back in and still get 1203 error...
I use the klennex with a few drops of water to dampen and clean off those contact on the holder and my printer work again. Before you print anything, you should run aligned the catridges a couple times then run clean catridges a couple times.
Nov 12, 2009 | Dell 924 All-in-One InkJet Printer
Error 1203 is a very interesting cartridge error. It means your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the cartridge
Solution:
Hope this helps and please feel free to rate me
Sep 12, 2009 | Dell 942 All-In-One InkJet Printer
Error 1203.
It's mean your catridges overflow even from brand new catridges after a several prints or right after you refilled the catridges. Check to see if ink are smeared on the holder where the contact panel with the catridge. I have the same problem which I think lexmark have a proble and overlook.
Solution:
Dell Series 5 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges.
Dell Series 5 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
regards
iversh
A very helpful rating is appreciated for answering your query...
Aug 22, 2009 | Dell 924 All-in-One InkJet Printer
Error 1203 how do I fix it?
try this solution:
Solution:
Jun 10, 2009 | Lexmark X4250 All-In-One InkJet Printer
My printer says error 1203 catridge error...can you help me with this...I can not find my owners manual?
The error 1203 error message on the operator panel could indicate a problem with one of the ink cartridges. Please follow the steps given below:
1. Please make sure the All-In-One is powered on.
2. Pull the control panel towards you, and then open the cartridge access door. The print cartridge carrier moves and stops at the loading position.
3. Pull the old cartridges towards you, and then lift them out.
4. With the cartridges out of the printer, shut the access door and the control panel.
5. Power the printer OFF and then back ON.
6. Please check the operator panel to see if the same error has returned or if a new message has appeared.
7. If the message displayed is 1203, there is something wrong with the printer hardware.
If the message now displaying is Cartridge Missing, do the following:
1. Reinstall the cartridges into the printer.
2. Insert the color cartridge in the left carrier. Insert the black cartridge in the right carrier.
3. Push back firmly on the cartridges until they snap securely into place.
4. Close the cartridge access door, and then close the control panel.
5. If the 1203 message is still present on the operator panel, you need to insert one cartridge at a time to determine which cartridge is producing the failure.
6. With one cartridge in the carrier, close the access door and control panel.
7. Please check the operator panel. If the 1203 error is displayed, this cartridge is the defective item. If the Cartridge Missing message is displayed, the second cartridge is producing the failure.
8. Please replace the defective cartridge.
May 18, 2009 | Lexmark C533DN InkJet Printer
Dell 946 error 1203
In this Case just unplug the Power Supply from the Printer...........
Remove both the catridges from the Printer........
Move the Catridge carrier which holds the catridge back and forth for abt 20 times as fast as u can....
Now Turn the Printer On it will work fine.........
Good Luck...........
Apr 04, 2009 | Dell 946 All-In-One InkJet Printer
Error #1203
Normi, The 1203 error as you suspected deals with the ink cartridge. This is a common problem and Lexmark has a troubleshooting procedure posted on their web site. Here is the link for the web page. http://support.lexmark.com/cgi-perl/knowledgebase.cgi?ccs=229:1:0:439:0:0&emeaframe=&docid=ENUS21870 Hope this solves your problem and please don?t forget to rate this posting.
Jan 20, 2007 | Lexmark X4270 All-In-One InkJet Printer
Dell 962 Photo All-In-One InkJet Printer Logo
63 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
