Question about Kenmore 24032\24036 Top Load Washer
While in spin cycle agitator spins, but tub does not
Does fine until the spin cycle. Agitator spins, but tub doesn't
  • Anonymous Mar 13, 2014
    After Machine fills and Starts wash cycle tub tries to spin but doesn't then tries to reverse spin but doesn't. Agitator engages and spins than reverse spins...repeat...repeat. Question is this, a noise accompanies the tub trying to spin, than the agitator starts agitating but the tub doesn't. Spin cycle is fine.
  • 20 Answers
Hello, it is the drum shaft collar or what the tub rests on. It is on the top of the shaft. You need to remove the shell, the plastic collar that rests on top of the drum, the agitator, then the nut that holds the drum down, and then pull the drum out, and then you will see the collar. I know it is hard to get to so I would call a pro for this job unless you think you can do it. The part is cheep it is the labor that will cost you. Thank you
Posted on Dec 08, 2008
Agitator quit working during wash cycle. If I move timer to rinse and fill with water then move timer to spin the agitator works fine and drains water from the tub
depends on what u mean by agitator works fine on spin? it doesnt do anything on spin cycle cause its not suppose to? if ur saying ur not getting any wash agitation? then I suspect ur cam dogs inside agitator are bad? remove the 7/16 bolt nut and remove top of agitator and u will see the cam dogs underneath it. there fairly cheap like 5-10 bucks for a set, if u can push the agitator back and forth when its all together in tub, and its catching the teeth and not easy to move back in forth, their not bad, but if u have no resistance then they are bad
Feb 19, 2015 | Washing Machines
Maytag washer tub will not spin.
There is a clutch assembly under the tub that controls the tub and the agitator. It sounds like the problem is with that.
Jan 19, 2014 | Maytag Washing Machines
Clothes washer tub spins on wash
sounds like u have a problem with the "brain". The agitator and spin cycle should never run at the same time. therefore it leads me to A: brain issue B:problem in the actual transmission of what cycle should be running. You will continue to smell the burning rubber due to the issue being one of the two explained above. Does it ever NOT spin? If this is the case the likely hood is that it will be a solenoid.
Apr 21, 2013 | 2000 Honda Accord
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Jan 02, 2012 | Washing Machines
Kenmore 90 series 11026912690, agitator makes loud noise
If the problem is just the agitator not working, but everything else does, you may just have a worn agitator cam assembly, worn agitator dogs, loose agitator bolt, or all of the above. The following link explains what agitator dogs are and how to access them:
http://www.fixya.com/support/r3608577-replacing_agitator_dogs
Whirlpool manufactured washers (such as Kenmore) use a split agitator design. The top half is known as the "auger, while the lower half is the agitator. Between the two pieces is a cam assembly, with small teflon teeth known as "dogs". There's also an agitator bolt that holds the entire assembly to the center post.
If the auger (top half of the agitator) is slipping, I would suspect the dogs or cam assembly need to be replaced. The part number for the dogs is included in the link I provided. For a little more you can purchase the entire cam assembly which includes the dogs, the cam, the cam seal and thrust bearing.
If the entire agitator appears loose or slipping, check the agitator bolt to ensure it is tight. DO NOT overtighten as this can restrict movement of the agitator or damage it. Tighten until snug.
Replacement parts (if required) can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable and offer great service with competitive pricing, so shop and compare. The first three sites I listed also include helpful exploded view parts diagrams to assist you in locating and properly identifying the parts you need. If you do not wish to order parts on line, use the part numbers from the Sears website and go to your nearest appliance parts retailer. These parts are commonly sold as part of their in-store inventory.
NOTE: Other causes can include a broken motor coupling, bad gearcase (transmission), or worn clutch assembly. It does not sound like the problem is associated with any of these components however.
If the motor coupling were bad, the washer would not spin at all (whether you held the agitator or not), but would still have the ability to drain.
If the gearcase (transmission) were bad, the washer would either not spin, or may spin with assistance (meaning, if you gave the drum a spin by hand to get it started).
If the clutch were bad, the symptoms would be similiar to that of the gearcase and the tub would probably also have problems stopping.
This problem sounds like it may only be associated with an agitator that could be loose, causing an off balance tub. Read through the information provided and let me know if you have any questions. I hope this is helpful to you.
May 28, 2010 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmors 110 keep spining
The tranny should either spin or agitate not both
Nov 02, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore Mod 110 keep spinning
the holes are sapose to be there it filters the lint out.it sounds like you have a bad transmission.
Agitator not turning during cycle
Well, it sounds like you've done your homework. My first suspect would have been the agitator dogs too, but you said they were fine. Another likely suspect would have been the motor coupler, but you said the washer spins during the spin cycle. If the coupler was bad the unit would fill, but wouldn't agitate or spin. Plus, it would make an awful noise. I would have also suspected a clutch assembly, but you said the wash tub can spin. Normally, when the clutch goes bad, the drum won't spin, or spins slow. Another suspect could have been a bad lid switch, but the washer would have filled and stopped, without agitating or spinning. The only remaining suspect that I'm aware of is the gear case (transmission). Checking under the washer can give you some clues. Normally, when a gear case starts to go bad, they leak an amber colored oil. You may find puddles or drips under the washer. If you see no signs of oil the gear case could still be defective, however. But, before you go through all the trouble, double check the agitator one more time. Completely remove it from the tub and check the under side to ensure the grooves that grip the top of the gear case shaft have not been worn smooth. I hope this may have been some help to you.
Jul 09, 2007 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
198 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
