Question about Dometic RM2652 Refrigerator
Dometic rm2652. wont work at all.
I replaced the battery , in our rv today. now the fridge wont work on 110 or propane.
    Top Expert:
  • Dometic Master
  • 7,401 Answers
Check wiring
Posted on Oct 14, 2017
  • 999 Answers
SOURCE: my rv fridge will build up ice and freeze food too cold
The thermister for the temp control is a likely culprit. Eric
Posted on Jul 07, 2009
  • 62 Answers
SOURCE: Dometic Rv fridge will get cold on a/c power but
does the flame ever got out if not ,the tsat is not the problem. It could be that the flame is not hot enough or the flue has a restriction
Posted on Jul 25, 2009
  • 9 Answers
SOURCE: I have a Dometic RV fridge that wont get cold. it
It sounds like your cooling unit is going out. Here's a couple of things to check. Do you smell any ammonia when you open either one of the doors? When you look at the rear of the fridge, do you see anything that looks like rusty water that has run down any of the metal tubes and dried up? If the answer to either one of these is "yes", then youll need to start looking for a new fridge or replace the cooling unit on the one that you have.
Posted on Jul 26, 2009
  • 332 Answers
SOURCE: Dometic RM2652 will not cool on A/C or Propane
Ammonia is just what you a re smelling as the coolant is ammonia based Your cooling unit has leaked and is done for- Sorry I had to be the one to tell you
2 choices Replace the refer or Replace the coiling unit, I would suggest replacing the refer and having a new warranty
Posted on Mar 10, 2010
SOURCE: i have a dometic dm2652 rv fridge. its new and is
The DM2652 comes with an optional cooling fan to help with cooling the amonia. The fan cycles on and off as required as it has a tempeature sensor (thermistor). We turn ours off at night by removing the inline fuse (glass tube fuse 3 amp) located in your outside acces panel. The fuse is located in a black fuse holder with a re wire connecting both sides.
Posted on Aug 18, 2010
Give Arcticold a call. We will help diagnose the problem free of charge. I would help on this site but will require a lot more info. Toll free 1-888-782-6665 I have attached a video that may help. 88bf4c61-06e7-40b5-9515-34afd5643a3d.jpg Store
Mar 28, 2014 | Dometic RM2652 Refrigerator
Freezer works fine on propane but not the fridge
You may wish to check the flue clear anything that you find. Old birds next etc. Also make sure the flame and orifice are clean free from debris or rust. Propane should burn blue not orange. Incorrect gas setting if the flame is orange. Some yellow at the tip is ok. Proper adjustments are critical. Have you tried the unit on AC?
Other tips I have read indicate possible freezing in the back.
Defrost freezer completely as some here mentioned and restart see if this helps. Here is a good RV forum I saw good tips worth investigating.
If your not comfortable cleaning the jets and adjusting the flame have a professional do this. Safety comes first!
Freezer works refrigerator doesn iRV2 Forums
Dometic RM 2652 Refrigerator/Freezer is not working. Light works, 110 and propane are fine. Are there steps in trouble-shooting problems with this refrigerator? No visible leak or obvious problem. It's in...
Dometic refrigerator lp gas electronic Model # 3662. Same problem. gas works fine and power is there. as lights on top of frig work.... not even trying to be cold. Same suggestions as 2652? How to bypass thermostat? and will try relay after... thanks.. Bob in Canada<input id="gwProxy" type="hidden" /><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden" /><!-- from fixya rte -->
Aug 02, 2010 | Dometic RM2652 Refrigerator
3 way dometic RV fridge RM2612 won't work on propane or 12 V
Check any fuses/circuit breakers in harness from battery. That battery should supply 12 volts dc to fridge lugs/terminals at bottom of fridge on outside behind vent.
If battery is good and hooked up properly but no 12 volts to fridge, then you will have to trace back to battery for broken /bad wire. If you want to test quickly, just run 2 jumper wires from battery to those 2 lugs marked + and - Battery + to + (pos)at fridge, and - battery to -Neg at fridge. That should allow you to run it on propane or 12 volt. Remember, running it on 12 volts will kill that battery pretty quick, unless it's being charged. When you are plugged in, the converter supplies the 12 volts to your fridge, as well as should be charging your battery.
Jun 18, 2010 | Dometic RM2652 Refrigerator
Have dometic fridge in in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Oct 23, 2009 | Dometic RM2652 Refrigerator
My rm2552 fridge wont run off of 120 volt power but runs fine on propane any ideas?
I have a dometic rv refrigerator its gas/electric it worked 6 months ago. But can't get it to work now.
Sep 02, 2009 | Dometic RM2652 Refrigerator
Rv fridge problems
have a dometic rm2852 fridge . does not switch over from 110 volt to gas automaticlly. it will click but not ignite. can you help?
Jul 09, 2008 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
138 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
