Question about Goodman Heating & Cooling
Goodman: My Power Venter (aka Heat and Draft Inducer) won't start
FURNACE:
Made by: Goodman
Model #: GMPN080-4
THE POWER VENTER (this is what the Goodman manual calls it but other websites refer to this as the Heat or Draft Inducer):
Made by: FASCO Industries 70219565
Type: U218
Volts: 115
RPM3400
Customer Part #: B2833001S
I have been troubleshooting this all day and this is what I have learned:
The Thermostat is ok.
The Indoor Blower (Main Blower) is ok. I can turn on just the fan from the thermostat and it turns on.
Everything was working fine and then something happened. I have not moved any wires or made any changes.
Here are the sequence of events:
I turn on the heat from the thermostat.
The Thermostat clicks telling the furnace to turn on the heat.
The furnace has a humming sound coming from it. This is the Power Venter/Heat Inducer trying to turn on. The indicator light blinks three times. The panel explains that this means:
"Pressure switch failure to close. check venter, pressure switch, vent blockage"
The humming sound will stop and then begin again but nothing happens. Also during this time a burning smell is coming from the power venter. It smells like burnt plastic but I am not sure what it is.
I attempted to move the fan blades on the Power Vetner with a screw driver but the fan blades are not accessible.
My next step is to remove the Power Venter, open it up and clean it.
Any suggestions will be greatly appreciated!
  • 1 more comment
  • MikeS5643 Dec 02, 2008
    Thanks for the feedback. I solved it! The problem was that the fan was stuck. I uninstalled the power venter and stuck my finger into the fan and dislodged whatever made the fan stick. It took quite a bit of pressure. After that it spun freely. I have no idea what was causing the fan to be stuck so hard. I reinstalled the power venter and everything works. Does anyone know what would cause the fan to be stuck?
  • MikeS5643 Dec 04, 2008
    I thought I did but the problem continues to exist. This time I removed the power venter and the fan is rubbing against the case therefore there is some friction which is preventing its from spinning freely. There is enough friction to not allow it to start spinning when the thermostat asks for heat.
    Any ideas how I can fix this? Can I take it somewhere and have them repair the fan. The motor and everything else is fine.
  • Anonymous Mar 21, 2014
    on a call for heat the induced blower starts momentarily and then shuts off. the two green led's blink rapidly and nothing else happens
  • 108 Answers
The power ventor most likely needs to be replaced. But be advised. Goodman normally will not sell parts to anyone but a certified technician. I had to show my masters certificate to buy parts from their outlet. This is a part that has a high rate of failure.
Ray
Posted on Dec 01, 2008
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
How do I light pilot light?
There should not be a pilot on a direct vent furnace. When you turn up the thermostat for heat the 1st thing to happen is a venter motor should start, it should vent for approximately 45 seconds, the air switch will verify a vacuum in the burner box, then a spark igniter should start clicking to start the pilot, then the flame rod will verify the pilot, the igniter will stop clicking, and the main burner will ignite and remain on until the thermostat has satisfied the set point. These guideline steps must be satisfied before the controller advances to the next step. The 1st step is the venter motor running, sometimes the motor will stick over the summer months, spin it manually to unstick it. PS, nothing runs if the fan door cover is open, as that shuts down the power to the whole furnace.
Oct 02, 2015 | Coleman Gas Fired Mobile Home Furnace,...
Year model by serial number
So.........it's a GSW 50 gallon which you either bought in Canada or smuggled in.
Even if you have a model with a shutter damper without a fan this is NOT a Power Venter and will need standard through roof flue pipe/chimney to establish draft and vent CO and exhaust gases atmospherically AKA Natural Draft. It will NOT vent sidewall without a fan induced draft
Sep 07, 2014 | Water Heaters
Problem with furnace not kicking on.
could be one of a few diff issues. firstly, the air pressure switch may be failing. check to ensure the inducer motor is providing enough air flow for the air switch to close. if inducer motor isn't creating enough air flow the faults is within the motor. If the airflow is enough, then fault maybe the air switch. you also need to check for any blockage in the exhaust. ensure no debris is blocking the vent going to outside
Jan 21, 2014 | Goodman Heating & Cooling
Power vent on oil furnace keeps running
The vent motor starts with a call for heat from the thermostat. They are actuated by a separate relay that may be arched closed. Kill all power, turn the stat way down and turn the power back on. If it starts when the thermostat is NOT calling for heat, find and replace the relay.
Nov 25, 2013 | Heating & Cooling
Furnace won't start after replacing filter
check for disconnected wires . There may be a sensor in or near the unit you touched that is causing the problem
Feb 18, 2013 | Goodman Furnace Draft Inducer Blower ...
I turn my thermostat to the HEAT position, I hear the Thermostat click and the Furnace begins to hum but no air comes out of the vents. Also if i turn the fan to the ON position air will come out of the...
need to go to furnace and watch it...if your hearing a hum the enducer draft motor may have failed...it should start first if there is no fault codes...reset unit by unplugging furnace or in some cases turning power switch off...turn thermostat on heat and watch unit ..the small enducer draft motor should start first the a ignitor glows and the should light...goodman units have a control board with a light on control board when it fails should flash a code and on the door or inside on lable should give you what that code is...hope this helps good luck
Jan 07, 2011 | Goodman GMS90703BXA Heater
What is the model number for the Draft Inducer Motor Goodman GNP075-2REVB Furnace
I think you must mean GMP075-2rev8 check this link for parts listing:
http://site.famousparts.com/goodman/PDF/RP-169C.pdf
Johnstone supply which has many locations in many cities sells Goodman and stocks parts, and available mailorder http://www.johnstonesupply.com/corp/Default.aspx
Feb 18, 2010 | Goodman Furnace Draft Inducer Blower ...
Common terminal location on a goodman furnace
White wires are commonly the common connection (sorry for the pun). L2 is also considered the common leg. You did not mention if you are looking for high voltage or low voltage common. L2 is your high voltage leg. If the power venter ties into the thermostat circuit, W on the circuit board is the common terminal.
Dec 01, 2009 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
669 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Tim Whalen
christian nielsen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
