Washing Machines
Problem for Washing Machines
Generic problem for all Washing Machines
Error code help
By Dirty duds on Dec 01, 2008
Hi Mike. You seem to know codes, so here goes. My Kenmore Elite top load (just 2 years old) was off, when suddenly it began beeping slow at first, and then almost frantically. I saw that it threw an error code....C9. I unplugged the machine in hopes of resetting it, but when I plugged it back it, there was a rather ominous spark. Waiting for the repairman to come Tuesday. Any clues or insight?
Thanks
Solution #1
posted on Dec 01, 2008
Not Rated)
mike73
Rank: Guru
Rating: 89%, 96 votes
I assume this is the cabrio version not a calypso, (kenmore washers are whirlpools) C-9 is the last step of the diagnostic test. fault codes start with F or are a two letter code like Sd for over suds, dL Door Lock etc. I have noticed a spark also when plugging in some of these machines, but still worked fine. to see if there is a real code stored - use any one key other than power start and cancel while machine is off and press and hold for 4 secs release for 4 press for 4, release for 4, press for 4, release, you should see all lights come on. then after a few seconds if it has a code you should see it. press same key again and it should start diagnostic test- where it uses the C codes for steps. power and cancel should get you out this. for your code list there is a service book inside the machine on the front panel upper left side. (pop top lid up with putty knife). OR for all your whirlpool made products go to www.servicematters.com click technical reference, technical library, tech sheets/wiring diagrams enter model number (kenmore number after the "110.")
hope this helps
Mike
Was this helpful?
Yes
No
Popular Solutions for Washing Machines
Questions and Unsolved Problems for Washing Machines
Answer
Are there any new washing machines made that still have direct drive. That means that the agitator... (More)
Answer
Whirlpool Cabrio WTW6300 worth the $$?
Answer
I have a Neptune TL FAV6800AW Washer that makes a tremendous grinding sound during the wash cycle.... (More)
Answer
I am renting in new appartment with Whirlpool AWM6100 - how do I set it up to do washing - basics??
Answer
i have a bosch maxx 1000 (wfl2000au/30) machine will not spin. pupm impeller was jammed by a bobby... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Washing... Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
