SOURCE: Need driver for Western Digital Scorpio
Hi raider4123,
The Western Digital Scorpio (WD2500BEVS) doesn't come with a driver, but I have an idea that perhaps you may have a pin setting wrong, making the drive not recongizeable. Here is the information on setting the pin on the back'
If that doesn't seem to solve the problem, then I'd run the WD Lifeguard software, that will detect any problems and correct them for you. You can find that software HERE.
Good Luck,
And don't forget to leave a rating.
Thanks
Mark
SOURCE: Acer Aspire Hard Drive failure
any laptop Hdd will work as long as you know whether it is SATA or IDE.
The casing around the Hard drive will be different, but can easily be put onto the new drive, but be careful of static and dont drop it
SOURCE: Western digital Scorpio 120 G
Actually there is no solution, the hard drive is bad.
What I ended doing was recording the partition in iso. ( I had a Factory Partition)
Got a new hard drive 160G scorpio unfortunately it does not come with installation disc.
Installed Vista, and with vista created a partition and then installed the contents of the factory partition.
SOURCE: its a western digital WD passport 750GB portable
Usually what has happened here is the usb interface has failed. The little hard drive with all your data is perfectly fine but the interface can no longer talk to the computer.
There are a couple of fixes. One is to send it in to WD who may or may not preserve your data. You can buy another passport and take the drive out and put it into the new drives enclosure. And third which is the way I've been fixing these is to go buy a usb drive enclosure. These start at $15 and up. Then you just take the drive out of your passport, plug it into the enclosure and you are back up and running.
This type of failure is common to all manufacturers.
The enclosure swap is something you can do yourself. The hardest bit is actually opening the case on the passport. Any computer shop should be able to do it for about $40 or less.
Testimonial: "Thanks for the help, will go and try one of the three solutions you have suggested"
you have not stated what is not working so i have to guess you need an overhaul
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to have an end so any faulty leads will end up with a computer error
hope this helps
Hi Anonymous, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
