Cars & Trucks Logo
Anonymous Posted on Jun 12, 2012
Sound not comming out of rear speakers - 1995 Oldsmobile 88
Anonymous
Level 3:
  • Master 4,399 Answers
  • Posted on Jun 12, 2012
Anonymous
Master
Level 3:
Answers
4399
Questions
Helped
876309
Points
13003
Thanks for choosing FixYa. More then likely, you have a wiring issue. I would advise you to check your speakers first though. If they both went out at the same time, probably a wiring issue. If the speakers don't work, then change them. You can hook your speakers straight to a power source to see if they are working or not.
I have a 2000 Oldsmobile alero and I can't get any sound out of my rear speakers good speakers and connection just can't get any sound out of them
Installing/Replacing rear speakers in a 2002 Pontiac Grand ...
? 5:11
https://www.youtube.com/watch?v=aiWwA6bXvhE
Nov 30, 2010 - Uploaded by Turbo231
Installing/Replacing rear speakers in a 2002 Pontiac Grand Prix GT DIY ... same as a 2000 grand prix ...
How to remove back speakers and install in a 98 02 ...
? 17:50
https://www.youtube.com/watch?v=pIxGeqy9QYI
Feb 26, 2014 - Uploaded by Can't Kill Me
How to remove back speakers and install in a 98 02 Oldsmobile Intrigue. Can't Kill Me ... 6x9 Rear Car ...
OLDSMOBILE ALERO 2000 speakers - Sonic Electronix
www.sonicelectronix.com/oldsmobile-alero-2000-car-speakers.html
OLDSMOBILE ALERO 2000 speakers - find speakers that fit your ... sound. This size is capable of delivering exceptional mid-bass that can't be found in smaller ...
how do you replace rear speakers? - Aleromod.com
www.aleromod.com > ... > General Help > Audio, Video & Security
Feb 13, 2013 - 20 posts - ‎7 authors
I just tryed it and I have no idea how to take that plasic thing out! ... I replaced the deckspeakers on my alero as well as my friends and didn't .... remove the rear deck...next thing is that if you have monsoon sound let ... Get better aftermarket speakers and then say ehh...i wanna go back to the weak stockers. Stero Question
May 21, 2013
Monsoon and aftermarket speakers
Sep 9, 2011
Aftermarket Headunits, Wiring Harnesses
Feb 19, 2004
Installing Aftermarket Radio, 2001-2004
Nov 20, 2003
More results from www.aleromod.com
I have a 2000 oldsmobile alero and I can't get sound out of my rear speakers good speakers and connection just no sound
2001 Oldsmobile Alero Car Radio Stereo Audio Wiring ...
www.modifiedlife.com/2001-oldsmobile-alero-car-radio-stereo-audio-wi...
Easy Plug and Play Wiring Adapter. ... 2001 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram ... If you can't find your car audio wire diagram, car stereo wire diagram or car radio ... Right Rear Speaker Positive Wire (+): Dark Blue ... olds alero and I have replace the stock stereo and have found that the sound out put ...
Request a Oldsmobile Car Radio Stereo Wiring Diagram
Dennis my 1995 lincoln towncar JBL radio quit producing sound the system comes on fine but I get no sound could u help me please, what is the problem?
The Amp in the trunk might have blown,
Town Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Pink/Light Blue
Car Radio Accessory Switched 12v+ Wire: Yellow/Black
Car Radio Ground Wire: Black/Light Green
Car Radio Illumination Wire: Light Blue/Red
Car Stereo Dimmer Wire: Blue/Red
Car Stereo Antenna Trigger Wire: Blue
Car Stereo Amplifier Location: Trunk
Car Audio Front Speakers Size: 5? x 7? Speakersir?t=modilife-20&l=as2&o=1&a=b00009uhre
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Orange/Light Green
Left Front Speaker Negative Wire (-): Light Blue/White
Right Front Speaker Positive Wire (+): White/Light Green
Right Front Speaker Negative Wire (-): Dark Green/Orange
Car Audio Rear Speakers Size: 6? x 9? Speakers[img src="http://www.assoc-amazon.com/e/ir?t=modilife-20&l=as2&o=1&a=B00009UHRE" width="1" height="1" border="0" alt="">
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Gray/Light Blue
Left Rear Speaker Negative Wire (-): Tan/Yellow
Right Rear Speaker Positive Wire (+): Orange/Red
Right Rear Speaker Negative Wire (-): Brown/Pink
Check the fuses
24851106-prgqozi4aluuon54ixeydqz4-5-7.gif 24851106-prgqozi4aluuon54ixeydqz4-5-0_0.jpg
How to find rear speaker wire on nddn w56 dvd player?
well, if you look at the rear speaker and write down the colors
that be it.
or login to alldata.com click auto/radio/sound.
1helpful
Rear speakers have no sound
No speakers are not fused.. It is most likely a speaker wire that has gone to ground so they would have to be traced to each speaker to see if you can find the short
2answers
What would cause the driver side front door speaker and the passenger side rear deck speakers not to work. When if fade the sound all the way to the front with no sound in rear and with the balance turned...
Check the speakers if they work. Connect the speaker terminals using a short wire to a 1.5 volt battery (AA or any dry cell batter) and listen if there's a thumping sound when the wires are connected to the battery terminals. If there's no sound, your speakers are busted. If there's a sound, check if the wires are okay. Use the same method with the battery with the wires from the back of your stereo. Make a small cut on the wire and attach the short wires you used earlier.
2answers
1998 bravada has six radio speakers; two dash speakers and two in the front doors speakers plus two rear doors speakers. the front doors speakers work good but no sound come from the dash speakers or the...
Did it fail while you had vehicle, or like this when you bought it? Could be bad radio or wiring harness was chopped up when previous owners had an aftermarket radio installed. They probably just slapped the OEM radio back in when selling car. And didn't put all the OEM wiring back in.
1helpful
Radio harness diagram for 95 chevy tahoe....rear
check wiring on passengers side near the rear hatch speaker, the rear door speakers are run through them also. i had the same problem and it was a unplugged connector at that location
2answers
Stereo problems
sounds like a speaker problem, but it could be the stereo itself. it could have a damaged circuit board. the only way to find is to test the speakers/head unit.
Top Oldsmobile Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you an Oldsmobile Expert? Answer questions, earn points and help others
