Question about ASUS 865G (MBAS-P4P800VM) Motherboard
I need a diagram showing placement for the case power switches
I put the guts of a Spresso into a gaming tower and cant get the power switch wires configured correctly. it turns on and then once turned off it needs to be junped live to get it started again. can u show a blown uo diagram showing placement of a HDD LED, reset switch,power led,m/b switch?
I have the same problem like shoesteve, by that link is not work at me. Please post a link if someone know other site. Thanks for eventualy help.
Posted on Oct 30, 2009
    Novelist:
  • 93 Answers
The manual for your MB is available at the ASUS website, as a PDF file. This is a direct link to the manual:
http://dlcdnet.asus.com/pub/ASUS/mb/sock478/p4p800-vm/e1338_p4p800-vm.pdf
The info you need is located on page 1-28 and 1-29 of the manual.
Cheers
Nick
Posted on Dec 01, 2008
Need wiring diagram
Wiring diagram for a 3-way switch, one of the many wiring diagrams showing different methods of wiring a three way switch circuit. This electrical wiring diagram shows power into light switch Box #1 – wire to light from switch box #1, and from switch box #1 to three-way light switch box #2.
Jan 06, 2016 | Holmes Products Heating & Cooling
How do I get the wires out of the old 3 speed ceiling fan switch so I can replace it with a new one?
Usually, there is no way to remove the wires from the switch. Turn off the circuit breaker that powers the circuit going to your fan. Then, match up the new switch with the old one to make sure you have the correct one, with the correct amount of wires. Mark the placement of of these wires with masking tape or draw yourself a diagram. Next, you need to cut the wires as close to the old switch as possible, and strip back about 1/2" of the insulation on these wires. Now connect those wires to the leads (wires) coming from the new switch with small wire nuts or crimp fasteners. When connecting the cut wires to the new switch leads, follow the same pattern as the old switch (refer to your masking tape labels or your diagram). Now you can secure the switch to the fan casing with it's locknut, and carefully tuck the wiring back inside. Re-secure the casing to the fan.
Aug 01, 2011 | Speed Ceiling Fan 3-speed Switch By...
Power botton will not turn pc on.
I suppose your power switch has broken or the wires inside has gotten of position such that power cannot reach.
Feb 10, 2011 | Rosewill ARMOR Gaming ATX Mid Tower...
Can i take the mother board out and put it in a gaming tower medium size..
you can if the power switch/reset bottun/power led/hdd led are not proprietary and banded together into a single **** plug. and if the mounting holes and setup will accept a gateway motherboard. but the power switch pin setup is what is the deciding factor in this switch. two wires going into a two prong female little black plug. the same for power led, reset switch yada yada. your gaming case is going to have these. if they match, then go for it it will work. oh and be sure to check the distance between the processor heatsync and fan combo to the power supply. some cases bunch them too close together and in some cases they wont fit in the case, i.e. the powersupply being 2 inches into where the cpu cooler unit should be :(
Jun 04, 2010 | Gateway LX6200-01 PC Desktop
My sound card doesn't work in my dell since we switched towers we put my mother board and guts into a differnt tower now says n sound card can anyone tell me how to get a sound card or a free download ?
You switched everything,including the hard drive with the windows on it ,correct? If so , then either the sound card is lose from the slot, you accicently disconnected a wire,or left one off for the sound?
Here is your Dell link for downloads. http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&os=WW1&osl=en&catid=&impid=&SystemID=DIM_CEL_3000
Mar 09, 2009 | Dell Dimension 3000 PC Desktop
POWER SWITCH REPLACEMENT
Post the type and model # of your motherboard. I don't think there is any generic way to hook them up. You will need to find it in the manual. Have never seen a MB manual that does not show the pin placements.
Jan 21, 2008 | ECS C51GM-M Motherboard
Power switch replacement
Well unfortunately you cant get one to buy for any case or tower, what you will need to do is get your self a new case(tower) or simply find an old case and take one out from it..
Jan 19, 2008 | E-Machines eMachines Desktop PC
Compaq for Evo D300 Motherboard
The manual can be found here. There is a numbered diagram inside. http://www.eserviceinfo.com/downloadsm/5105/Compaq_Evo%20300-500.html Hack
Jul 09, 2007 | Compaq (281946-001) for Evo D300...
ASUS 865G (MBAS-P4P800VM) Motherboard Logo
250 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
