Question about Pool & Spa
How to turn on hot tub
I have a spa city ''superpac'' deluxe series M30 model hot tub in the home I am staying at (we just bought this home and the hot tub came with it) however the instructions are really not helpful and it does not tell me where the power (on) button is - I looked all over and around the hot tub for the button and I can not find it.
Could you help me?
    Problem Solver:
  • 11 Answers
Check at the plug in if it has a normal plug like in your home first. Should be a set of buttons there, called a GFI. One is test, and the other reset.Push reset to see if spa comes on. Most spas dont have an actual on button. Check breaker box for popped breaker also, maybe tub is having problems, and needs a service call. Also larger tubs ussually jave a gfi or fuse box outside, close to tub. Kirk
Posted on Feb 17, 2009
2 Suggested Answers
SOURCE: how to turn on hot tub
Hot tubs do not have an "on" button. They are preset to heat up to 100 as soon as the breaker is turned on.
Posted on Sep 10, 2010
How do you winterize a hot tub? QCA Jewel Model SUV M7
this is taken right from a jewel series QCA hot tub manual.....Winterizing
In very cold weather you may not want to venture outside to use your spa. In this case, you may move it to a heated area, or leave it as is until the weather warms. If you do leave the spa unused for a long period of time in severely cold weather, you should winterize the spa to avoid accidental freezing due to a power or equipment failure.. Follow these easy steps: Turn power to the spa OFF. Drain the spa. Use a wet vac to **** or blow out the air injectors, water jets and water suction fittings. Add 1-3 gallons of RV antifreeze, depending on the size of the spa, to all the air injectors, water jets, suction drains, and filter. Caution: Any lines not receiving adequate antifreeze are subject to freeze damage!
Dec 29, 2011 | Qca Spas Jewel Series Topaz Plus Hot Tub
I have a 15 year old Hydropool Gold Series hot tub that I bought used a month ago. We got it all hooked up and working great but was told the timer never worked so it ran 24/7. Yesterday my husband turned...
If you can find the points on the timer try sanding them down. If they were burnt and stuck the spa would have run continuous. When you pulled the timer you may have broken them free but a burn would have kept them from making contact. I hope this helps, if not you might try reversing the leads coming into the timer or wherever you unhooked it to take it out. good luck.
Dec 05, 2010 | Qca Spas Paradise Hot Tub
My hot tub i dont no how too turn it on or turn the heat up
There should be an independent circuit breaker to control the tub, most commonly a 50 amp GFCI breaker. (Has a "test" button on the breaker itself) It is usually located either in the vicinity of the spa in a gray box, or in the main circuit breaker panel of your home. In rare instances, they may have used a "fuseless disconnect" either in the spa equipment compartment, or within the vicinity of the spa. (at least 6 ft. away from spa) The disconnect is simply a removable lever that you pull out to disconnect power to spa. I would advise you search for a breaker or disconnect. If you locate the breaker, switch it off, then back on. If you locate a disconnect, pull it out, ensure that it is inserted in the correct way, then re-connect it. If that doesn't work, check for a GFI on the equipment pack itself. It would have a "test" and "reset" button on it. Press the test, then reset button. You should hear a distinct "click" when the test button is pressed, and the reset button should stay in once pressed after that. If it does test and reset properly and the pump, etc doesn't work, then you have a problem in the control pack. (Either a fuse, or a component that an average consumer cannot diagnose or repair.) That being the case, you should call a qualified spa technician. Hope this helps.
Dec 31, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
Kohler bath whirlpool turns off after 1 second
When you say turns off, is it tripping the safety circuit?
Dec 26, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
I bought a home and my coleman spa 400 series has a problem, the jets 1 don't come on, jets 2 do. the water isn't heating up. was wondering what the problem could be
Pump one is the pump that does all the work in your spa. It handles the heating and filtering. If pump one does not work, It will not heat. It is likely pump one is gone but a technician would be needed to determine if it is the pump or the spa pack.
Dec 23, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Savannah spas
probably a dirty filter!! take it out turn tub off to reset turn back on with filter out and c if nthis solves problem if so replace filter.
Nov 20, 2009 | Qca Spas Jewel Series Topaz Plus Hot Tub
GFCI alarm stays on
Open your drain valve under the unit to break any air lock that will have gotten there when you drained the tub.
Sep 30, 2009 | Qca Spas Dream Series Dream Master Hot Tub...
May 31, 2009 | Qca Spas Paradise Hot Tub
Hot tub wont stay hot
Contact Maryland Hot Tub Repair - Pool and Spa Service and set up a Diagnostic service call. Here is there contact info: Maryland Hot Tub Repair - Maryland Pool Service - Maryland Spa Repair Pool Parts - Spa Parts - Hot Tub , Pool and Spa Repair - Pool Opening - Pool Closing - Pool Service 410-304-2463 http://www.maryland-hottub-pool-spa-repa... or see them on
May 20, 2009 | Jacuzzi DX50-959 Elara 7242 Salon Spa...
Pool & Spa Logo
5,224 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
