Question about JVC AV-30W776 30" TV
JVC TV WENT OFF. TURNED IT ON AND THE LAMP LIGHT STARTED BLINKING
WATCHING TV. IT TURNED OFF. WHEN I TURNED IT ON THE LAMP LIGHT STARTED BLINKINK THEN THE POWER LIGHT STARTED BLINKING. NO SOUND OR PICTURE
  • ladywinn
    ladywinn May 11, 2010
    They do not use lamps in 30inch tvs it is either solid picture tube or it is a lcd.
  • JVC Master
  • 5,138 Answers
If the Fan is clogged up with dirt set will not run fan must be working.
Posted on Dec 01, 2008
Mitsubishi wd-73c9 status light blinking orange won't turn on
may need the lamp replaced pt# 915B403001
Recommend Phillips, OSRAM or Mitsubishi original (as from experience others will not work or will have very short life)
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73C9
Mar 08, 2015 | Mitsubishi WD-73C9 73" DLP TV
I have a jvc hd52z585. while watching tv it turned off and the lamp light and the power light are blinking at the same time. i have unplugged the tv for a couple of hours. when i plugged it back in it does...
very easy.
there is 1 thumb screw behind left speaker grill.unscrew it to remove the grill.the lamp is behind that.after changing the lamp,go in to CUST.MENU,scroll down to reset lamp timer. Best price for lamp is pureglare.com. Inspect the lamp for internal glass particles for 100% verification of being bad. Also at the root of the glass stem in the middle look for bubbling of the glass. This is another sign of a bad lamp.
May 20, 2011 | JVC HD-52Z585 52" Rear Projection...
I have a JVC LT-42X579 TV. I got home tonight and
This is common problem of the failure of power supply board inside TV. You need technician to figure out this problem.
Aug 13, 2009 | Televison & Video
JVC 62" tv cut off and won't turn back on. red light blinking?
easy fix. here is your lamp part number TS-CL110UAA and your lamp door maybe hidden behind your front panel. check your lamp before you order one.. and shop around for the best price on your lamp. if you want to rebuild your lamp its cheaper and only a little more difficulty.. if you run into problems use our fixya chat..
Mar 16, 2009 | JVC HD-61Z786 61" Rear Projection HDTV
TV suddenly shut off, blinking red light in power button
The TV's power supply capacitors probably went bad.
Check with a mobile tv repair co. to see if it is worth fixing.
Dec 20, 2017 | JVC GD-V502U 50 in. Plasma Television
Sony KDF-46E2000 - Screen Goes Blank
You definitely have a bad lamp. Sony rates the lamp life at between 4000 and 8000 hours. There are 3 things that effect the lamp life, listed in order of importance:
1) number of times the lamp is turned on and off. Every time the lamp is first fired, it takes life off the lamp. Customers I see that turn the TV on in the morning, leave it on all day and then turn it off on the evening can get up to 12000 lamp hours
2) ventilation. Be sure you have at least 6 inches of open space all the way around the set and that the vents are clear of dust and debris.
3) power. If the power is interrupted when the set is on, there cannot be a proper cool down cycle. The fans will run after you turn the set off to properly cool it down, if the power is lost this cannot happen. If your power is unreliable, buy a small UPS to let the set finish a cool down cycle
Occasionally a lamp will faill before the average lamp time due to being defective. from your purchase date it sounds like you got about average lamp time. Be sure to purchase AN ORIGINAL SONY LAMP as a replacement, becuase the aftermarket lamps are bad news, Be sure to rate this solution. Thanks!
Oct 13, 2008 | Sony KDF46E2000 46" Projection HDTV
Blue light and lamp light flashing, no picture.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
Apr 21, 2008 | JVC HD-52Z575 52" Rear Projection...
JVC AV-30W776 30" TV Logo
149 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
