Question about Acer Computers & Internet
How can I connect external 5.1 speakers to my Acer 5920 Laptop
  • scoochypooch Dec 02, 2008
    In response to discolute: I'm hooking up Logitech X-530 computer speakers. Also any thoughts on how to stop the sub from humming?
  • decosolute May 11, 2010
    Are you hooking up 5.1 computer speakers or are you running it to a component unit?
  • 29 Answers
Welll.... you can hook multiple speakers up in parallel if you wish... but it will still be stereo... just through more speakers that's all.
You will need an external sound card if you want real DD5.1 sound. An excellent choice for a laptop is the Audigy 2 ZS video editor. It's an all-in-one device.. audio in/outs, video in/outs, 5.1 sound, 4 port usb hub, firewire connect and a few more things. The neat part is that it hooks up with one simple usb cable.
http://us.creative.com/products/feature.asp?category=1
Posted on Dec 01, 2008
Need factory settings aspire 5920
Laptop computers can be wonderful devices, except when the need to troubleshoot arises. Acer laptops are no different. A quick way to fix many problems with an Acer laptop running Windows is to reset it to factory settings. Resetting your Acer laptop to factory settings can eliminate slow operating, registry problems, virus problems, spyware issues and more. And a factory reset of your laptop may reduce the need for a full reinstallation of Windows.
1.Back up all necessary data to an external device such as a disk, flash drive or hard drive
2.Make sure all programs are closed and shut down your Acer laptop by opening your Start menu and selecting "Shut Down" from the options for shutting down and restarting windows.
3.Detach any external hardware such as an external hard drive or printer.
4.Press the Power button to boot your Acer laptop.
5.Press "Alt + F10" on your keyboard when the Acer screen appears at the start of the boot up process. Wait a moment while Windows loads the reset files.
6.Select "Restore System from factory default" in the Acer eRecovery Management window.
7.Click "Next" on the next screen to continue. Click "Next" on the following destination information window. This will pop up a notice telling you that resetting your Acer laptop will erase all data and restore the laptop to its original settings and configuration.
8.Click "OK" in the notice window to proceed with resetting your Acer laptop.
9.Wait while your Acer laptop is reset to factory settings.
Sep 06, 2011 | Acer Aspire 5920-6727 Notebook
Acer 5920 Sound Problems
You need to download and install the latest RealTek drivers for you laptop... Go to Acer site and get the correct version
http://us.acer.com/acer/service.do?LanguageISOCtxParam=en&miu10einu24.current.attN2B2F2EEF=3750&sp=page15e&ctx2.c2att1=25&miu10ekcond13.attN2B2F2EEF=3750&CountryISOCtxParam=US&ctx1g.c2att92=453&ctx1.att21k=1&CRC=2054404012
Feb 17, 2010 | Acer Aspire 5920-6335 Laptop
Acer 5920 aspire wont start
1. Remove laptop battery, optical drive, hard drive and ram. Remove external peripherals as well.
2. Make sure AC Adapter is not yet connected to the laptop. Pressand hold on the laptop’s power button for 10 seconds to drain the powerflea.
3. Connect the AC Adapter for laptop to a known good power outlet, check ACAdapter power LED if it is on. Try to sense if AC Adapter is not makinga bit of noise when it is plugin to the wall power outlet.
4. Connect now the AC Adapter tothe laptop. Check if AC Adapter LED stays on when it is connected tothe laptop. If the LED stays on means the AC Adapter is fine. If the ACAdapter LED turned off check the AC Adapter pin that goes to the laptopAC socket if it is loose.
5. If AC Adapter stays on after connecting to the laptop try topower on laptop. If no power LED comes on then this is motherboardproblem.
6. Before replacing the motherboard there is one checking needs todo. If you can open your laptop bottom part then good, do this whenlaptop is not connected to any power source. Try to reseat the laptopCMOS battery then try to power on laptop after, if still fails thenreplace motherboard. I hope this helps.
Jan 19, 2010 | Acer Aspire 5920-6727 Notebook
My Acer 5920 Laptop is about a yr old. It is not switching on. The power light blinks for about 5 secoonds and then nothing happens. Please let me know if anybody has a solution to this.
Try removeing the battery, memory and Hard drive. Press and hold the power button for 30 seconds.
Re-install and reseat memory Harddrive and battery.
Try powering up the unit without the battery and any external devices.
Sep 11, 2009 | Acer Aspire 5920-6727 Notebook
Problem in external speaker when connected to acer 5738Z LAPTOP
The audio jack on the laptop is for headphones and most likely cannot it cannot deliver sufficient power to drive unpowered speakers.
Check the audio jack with headphones, if the volume setting is high and you still can't get sounds from the headphone and the mute switch is not selected then the audio amp in the laptop is faulty.
Jul 07, 2009 | Acer Aspire 5920-6727 Notebook
ACCER aSPIRE 5920 NOT TURN ON.
is this a laptop? do you have an external monitor plugged in? do you have an external monitor to use? if it is a laptop then plug in an external monitor if it is not already plugged in, or if you already have one plugged in then unplug it.
May 26, 2009 | Acer Computers & Internet
Acer 5920 external speakers problem
Did you buy the speakers for computer using?
If not buy a USB audio output interface to drive the speakers.
Nov 18, 2008 | Acer Aspire 5920-6727 Notebook
Sound problem - Acer Aspire 5920
I assume you are using Windows Vista as ships with Aspire 5920's. Try the following to make sure that Windows is using the correct output options:
  1. Click on the Start Menu and go to Control Panel
  2. From Control Panel click on Hardware and Sound
  3. Click on the heading Sound and the sound configuration box will appear.
  4. The first tab is called Playback and allows you to select a playback device.  You should find your external speakers and internal speakers listed.
  5. Click the external speakers and then click on the "set default" button to make sure that the sound is played back through those instead of your internals.
Nov 06, 2008 | Computers & Internet
External speakers for acer laptop 5220 series
Hi there
On acer laptop you have already speakers. but you want to connect external speakers then please find
that three conector in your laptop and connect you external speakers on one of them. please try each connector and you are able to connect external speaker.
Thanks
Robert
Sep 24, 2008 | Computers & Internet
Computers & Internet Logo
83 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
