Acer 5570z laptop will not power on. nothing happens when depress on switch. removed battery, ac, etc as others advised and still nothing. Ac adapter light flashes when plugged in to lpatop, steady green light when unplugged. Unit not under warranty, geek squad said motherboard is out. What should I do? Thanks.
  • elproducto1 Jan 25, 2009
    When I hit the power button it does not turn on right away. What I do to turn it is first pressing the left side of the button and then press the right side. If it does turn on then repeat. Thanks Acer.
  • 64 Answers
It sounds like defective video card or motherboard.
Posted on Dec 01, 2008
My acer aspire v5-431 won't power on what do I do?
1. remove the battery and try AC only
2. Is the AC power supply warm?
3. Is the power light on but the computer is unresponsive?
1. Battery may have a short stopping the laptop from booting, replace the battery.
2. The AC power supply may be defective or the connector on the laptop is broken, replace the power supply/take the laptop to a shop.
3. The laptop may be in Sleep/Hibernate mode, press and hold the power button for up to a minute.
If nothing happens/is fixed at this point, Warranty/replace/take it to a shop
Apr 12, 2014 | Acer Aspire ASV5-431, V5-431 Charger,...
Dell latitude 610 AC adapter issue or battery pack issue or both?
It could possibly be the power jack that is inside the computer. This item is typically soldered onto the motherboard and it is what your ac adapter plugs into.
Dec 21, 2007 | Twinhead SlimNote N12PI Notebook PC
I have a acer 5741. I have tried many times to charge it but it wont charge no matter how long i leave it plugged in. It is stuck on 10%. When I plug it in it says its charging but nothing actually...
1. Unplug AC adapter. Shutdown
2. Remove battery, Connect AC Adapter
3. Start windows7. Remove Microsoft ACPI-Compliant Control Method Battery under device manager , battery
4. Shutdown, Remove AC Adapter, Install battery, Reattach AC Adapter.
5. Power up -
Now Plugged in and Charging.
Aug 04, 2011 | Acer Aspire 5520-5908 Notebook
My acer aspire 4740g does not power on. i have removed the battery and directly connected to the power supply but still does not turn on.
Problem description:
The laptop is completely dead. When you plug the AC adapter and press on the power button, nothing happens. The laptop has no signs of life at all. None of the LED lights is working.
Possible cause:
1. AC adapter failure.
2. Power jack failure.
3. Motherboard failure.
Possible troubleshooting steps and repair solution:
1. Test the AC adapter with a multimeter. It's possible that you have a failed AC adapter. If you don't have a multimeter, test your laptop with another known good AC adapter.
Acer Aspire 4740 AC Adapter
2. It's possible that power jack (socket where you plug the AC adapter) is broken. Remove the motherboard and take a closer look at the power jack. In some cases you can fix the jack by resoldering it on the motherboard. In other cases you have to replace the jack with a new one.
Using a multimeter, test if the power goes to the motherboard through the jack.
3. If replacing the AC power adapter and jack on the motherboard doesn't help, most likely you have a bad motherboard. Replace the motherboard.
Apr 21, 2011 | Acer Aspire 4235 4240 4535 4535G 4540...
No response
First follow procedure to try to reset the power.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 23, 2009 | Acer Computers & Internet
Acer laptop shut of during power outage .
From the Acer website:
Product
Notebook
Issue
Power Issues or Will not Boot
Solution
If the notebook does not power on:
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a ‘power reset' of the notebook.
Also, depending on whether your power went down "clean" (quick and stayed off), or went down and quickly came back on and off many times. Or when it came back on "clean" (came back on quick and stayed on), or it came on then off many times, your power supply may have been damaged from the power surges Are you having any problems with any other appliances?
Feb 07, 2009 | Acer Aspire L100 PC Desktop
Acer 3000 Will Not start
From what you've described so far, it appears the motherboard has failed. Additionally you can remove any other components you can easily access such as hard drive, optical drive, memory and any cards. If there is no change with all components removed then it is most likely the motherboard.
Jan 28, 2009 | Acer TravelMate 803LMi Notebook
EasyNote will not power up
remove the battery and try to power on using AC power only, if the pc turns on its the battery thats faulty
hope this helps
regards
Nov 19, 2008 | Acer Aspire 5610-4648 Notebook
Computers & Internet Logo
43 people viewed this question
David Payne
David Payne
