The phone was low on battery then when charged kept looping on off without a round windows connection light coming on. the screen in between turning itself on and off showing a battery and antennae icon with a cross next to both "x". I think there was an alert before it went funny - NYY or TYY alert. I think something inside the phone has been turned off - otherwise phone keeps looping on and off. Ultra messaging comes up then next G Te;stra then Windows Mobile then the icons then off.
A lot of problems seem to happen with the blackjack after an update or installing 3rd party apps or ringtones.
Try to do a hard reset and restore factory defaults. With the phone off... press and hold the UP on the dpad then press the power button while keeping UP depressed. That should replace the current running OS, with the default system stored in the ROM.
See if that works.
If not... Try to Enter flash mode / boot mode in i607. With the device off, press
"right soft key" + "side camera key" + "power" at the same time and wait for it to load.
It should force it into Bootloader mode. If you can't get into Bootloader mode, your Blackjack is done.
Sell it on ebay as a dead phone due to a bad flash. Someone may want to buy it for spare parts or to try and fix it.
Hopefully the Samsung update didn't die while copying over the files. When during the process did it die (Early, midway, toward the end?). If it is toward the end you might have the updated firmware in your ROM, just have a bad install.
Good luck.
First off how old is the phone? How long have you been experiencing this problem. If it is under warranty you will want to have it serviced that way. If you need further assistance let me know. Please take a moment to accept and rate my solution accordingly.
Thanks,
Lee
Hey
