Question about Olympus m:robe MR-100 Digital Media Player
Olympus mr-100 mp3 player
When i turn on my mrobe it says "Invalid/Missing File", then it freezes like that until the battery dies. (but i can still use the player as the portable harddrive as long as i don't 'turn it on'.)
  • 2 more comments
  • Jeremy Hansen Oct 03, 2007
    there are two solutions to the "invalid/missing file" problem.
    1) push the reset button located on the bottom of the player (about the size of 7MM pencil lead).
    2) reinstall the m:robe program (reprogram the player). you'll have to find the program on the internet (it's out there somewhere), plug in your player and basically run the program to reprogram it.
    3) call olympus?
    3) call olympus?
  • Cutaldo Nov 21, 2007
    I cannot play anything...i got a screen message: Invalid/Missing File. I use to play it with no problem but now is not working...
  • John Johnson Jul 07, 2008
    I formatted the MR-100 and was getting invalid file and it stop working.
    I disconnected it from the cradle and connect the USB directly into the MR-100. I got pass the invalid file and it hanging up. I loaded some music to the MR-100 and it began to work but would not come up the the Mrobe logo. I was able to get to mount back in the cradle. I then started with the oldest firmware and ended with oldest firmware upgrade to the MR-100. The firmware puts it back into the right format. It's working again. Hallelujah!!
This is a photo of the inside of the M-robe. I tried the suggestions you gave with no improvement. I did notice that the other end of the hdd lead where it connects to the mother board was not straight in the board socket
When you remove this lead from the motherboard, make sure you don’t bend it or stress it out of shape. before you attempt to put this lead back in, make sure the small plastic lock strip is lifted out of the way. Then press the lead firmly back onto the receptacle. Then lightly press the plastic lock strip back over where the connector is on the board here. If you have completed this connection correctly and no other damage has been done, your M-Robe should start up. Good luck
Graham Everson
gdprassem@gmail.com
Posted on Jun 20, 2008
I AM OF SUDAMERICA... ME TOO SEE IN MY mrobe THAT SIAD "Invalid/Missing File", I DID restart button Y NOTIHING. EVERYTHING FOLLOWS EQUAL. CAN I DO?
Posted on Aug 17, 2007
If your m:robe is frozen there is a very little hole on the bottom of it that you can poke the back in an earing or a pencil lead into. This is the restart button and everything should work fine
Posted on Feb 10, 2007
Hi. My name is Natalie. I got an m:robe for my 16th birthday at MTV'S TRL. Today, I just plugged this in to my computer and i deleted songs, put some in, and now, its saying INVALID/MISSING FILE. After you...
okey..try this..i got the same problem and i managed to rectify tht using this method..check it out anyway...first of all try to format your player in ntfs filesystem and http://www.esnips.com/doc/b15238f2-5133-43e4-b8c4-353375b77088/System_Index extract the files to your player and then
install the m:trip software from
http://downloads.olympus-europa.com/consumer/mrobe/m-trip/ENG/mtrip_english.zip
after tht install the firmware http://www.olympusamerica.com/files/oima_cckb/MR100_FirmSysUp_213.exe..before installing the firmware make sure tht u reset the player ..after following all the instructions of the firmware try to synch the player to check whether it detects music and finally restart your m:robe to take effect..!!
Dec 29, 2009 | Olympus m:robe MR-100 Digital Media Player
Hellooo im having m-robe and i formatted it and i need a music loader that can load music on it
This is the software that was provided with the player.
Jan 27, 2009 | Olympus m:robe MR-100 Digital Media Player
Olympus mrobe
unzip it, drag the System Folder and the Index.mum filedirectly onto your m:robe. then pull it off the dock. you might have topush reset.
and then freshly install the m:trip software from
aftertht install the firmwarehttp://www.olympusamerica.com/files/oima_cckb/MR100_FirmSysUp_213.exe..beforeinstalling the firmware make sure tht u reset the player ..afterfollowing all the instructions of the firmware try to synch the playerto check whether it detects music and finally restart your m:robe totake effect..!!
Oct 09, 2008 | Olympus m:robe MR-100 Digital Media Player
Olympus m:robe 100 missing file
Sep 12, 2008 | Olympus m:robe MR-500i MP3 Player
M:robe error invalid/missing file
hello, i had the same problem. recently, i had deleted all the files off of my mr-100. i downloaded this file.
Once you unzip it, drag the System Folder and the Index.mum file directly onto your m:robe. then pull it off the dock. you might have to push reset.
i couldnt get the "invalid/missing file" screen to go away for a while. if you slide the hold button into the hold position and then push the little reset button on the bottom, it will remain off and you can put it on the dock, then it will connect to the PC.
Aug 15, 2008 | Olympus m:robe MR-100 Digital Media Player
!!!!!!!!!!!!!!HELP ME PLEASE!!!!!!!!!!!
well u can charge with the comp thing, just leave ur mrobe off and plug it in while ur computer is on
Feb 04, 2008 | Olympus m:robe MR-100 Digital Media Player
having the same problem because i losted my headphone and my mr-100 does not work, how can i use it with the other headphones
Nov 06, 2007 | Olympus m:robe MR-100 Digital Media Player
Help!!
upload the firmware again
Apr 13, 2007 | Olympus m:robe MR-100 Digital Media Player
Olympus m:robe mr-100 mp3 player
4 small (tiny!) screws ... one either side at top and 2 at bottom, then pull the case away from the unit , catching the rubber bit that will fall out of the 'phone socket!. the 2 stickers are actually on the hard drive (bottom of unit) you just shove a flathead jewellers driver in the grid to the right and move the arm up and to the right. THIS SHOULDN'T REALLY WORK, BUT IT DOES!
HELP
Did you go to Olympus's m:robe site and download the firmware and install it again?
Feb 01, 2007 | Olympus m:robe MR-100 Digital Media Player
Olympus m:robe MR-100 Digital Media Player Logo
650 people viewed this question
Top Olympus Audio Players & Recorders Experts
pankaj rautela
pankaj rautela
leoz
Level 1 Expert
Are you an Olympus Audio Player and Recorder Expert? Answer questions, earn points and help others
