Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
When use water dispeser water comes out from behind the refridge
No water coming out of dispenser.water flows from tubing channel at base of rear of unit.water line appears to be broken in refrigerator wall.need schematicfor repair.
  • lostinyork Dec 02, 2008
    I don't know if I have the same model, it is model ed2chqxkbo5. I checked the water line out of wall to frig, I checked the water line that comes in and out behind the crisper, it has water in it and is not frozen. I even checked down below in the basement and did not see the water line. There is a handle on the water line valve, but today was probably the first time I moved the frig. (yes it was dirty). I looked at the mechanism n the front to make sure that all the pieces were operating properly and it appears to be okay. The ice maker is working and the light is working.????
    President:
  • Whirlpool Master
  • 2,651 Answers
No real "schematic" available showing how hte water lines are run, but illtell you that they start at teh rear of machine,incoming water, form there they travel to the water filter and into an opening under the refrig side. can be viewed by removing hte lower crisper(theres a holding tank) from ht tank goes back out nad heads for the door assy, so a simple trace of water lins will determine point of leak, usually a fiting or hte water lineitself has dry-rotted, in which case needs replacing, hter are no "hidden" lines with refrig, ohter then within the freezer door,and even that can be removed and replaced if ness.
Posted on Dec 01, 2008
Water is leaking under fridge when I use the water dispenser
This means you have a cracked water line tube coming from the valve. The water valve will be in the rear near the compressor, likely made of blue plastic. If the fridge has an icemaker, there will be two fill tubes coming off of the valve, the water dispenser line will be the larger of the two... depending on the model, there will be a quick disconnect behind the kickplate below the freezer door, disconnect the water line there and replace that section back to the valve... Water Line 5210JA3004U
Jul 18, 2016 | Refrigerators
My water stopped dispensing but I can feel air like it's trying
Sometimes the plastic tube is the door freezes. If you remove the front grill at the base of the refrigerator you should see a tubing disconnect.
these are fairly easy to disconnect either by unscrewing the plastic nut or pushing in on a ring around the tubing. if you disconnect this. just hit the water dispenser actuator for a very short time. if water comes out the tubing is frozen in the door and you will have to shut down the refrigerator for a while and let it defrost. if you don't get water there then perhaps the water reservoir in the refrigerator is frozen. It is located behind the crisper drawers.
Jul 24, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
Hi. The water flow is very slight. I have changed the filter to no avail. I have well water and suspect that something might be clogged or there must be a pump someplace? The water flow into back thru the...
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Oct 04, 2009 | Refrigerators
Ice continues to be made, about a week ago, the part that turns the ice to crush it or dispense it doesn't work, it also takes about 2 minutes when water is activated before it will finally dispense, all...
Open the door and hold the door switch down and try the ice dispenser. Do you hear any thing. Take all the ice out of the bin and try. Anything? Take the bin out and try. Anything? The motor is behind the back cover where the bin sits. See if you get power to it using a voltmeter. If your are, probably bad motor. If not dispenser switch.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see how fast the water comes out when you try the dispenser. If it's slow here there is a valve our water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again. It it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Aug 21, 2009 | Refrigerators
No water comes out of ice and water dispenser. gsh25jsrfss refridge no water is flowing to icemaker or water dispenser.
Either the inlet filter is plugged, or the valve is not opening. You will have to trace the water line to access these.
Jul 06, 2009 | General Electric GSH25JSXSS Stainless...
My refrige does not dispese water
disconnect the line to the water dispenser at the water inlet valve on the back where the water supply comes in and try the dispenser. if you hear the valve work but water doesn't come out, the valve is bad. If you don't hear the valve, the dispenser switch is bad. If water does come out Your water line could be frozen in the door. You can disconnect the line under the unit before it goes into the door at the bottom hinge. Push the dispenser button and see if it comes out there. If it does leave the door open till it thaws.
Jul 01, 2009 | Refrigerators
I have a sub zero 611 and water is accumulating behind the vegetable drawer in the channel that is there.Where does it come from and how do I make it go away
sounds like you have a blocked drain tube....when defrost system kicks in the melted water runs down a tube into a tray adjacent to the compressor and is evaporated by the heat. when the tube becomes blocked the water has nowhere else to go except overflowing and out through the refridge vent down the back and onto the floor of the refridge.
If you are hand with tools i can explain a procedure to fix this problem, If not call a service guy :)
Jun 23, 2009 | Sub-Zero Bottom Freezer Refrigerator
Icemaker not working,water pours from dispenser side
it could be water valve or ice maker that has gone bad.check all connectins to icemaker and tubing to icemaker and water valve.
Mar 20, 2009 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
Slow water flow on Whirlpool Gold 25.6 cubic
The water line tap may be screwed back into the water line or you did not sufficiently poke a hole into the water line with the tap. We had the same problem. Shut off the water supply, remove the tap from the line and check the size of the hole. my bet is the hole is very small. Either drill out the hole with a drill and replace the tap (with a new rubber grommet) or add a tee into the line with the proper size compression fitting (that is what we did) and the water will flow freely..
Apr 20, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Kenmore 46462 Front Load Washer
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
95 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
